Question about Car Audio & Video
Radio will not continue to play when key turned off
I have a 2010 gmc siearra when you turn off your ignition your radio should continue to play ,,,instead it goes off when ignition is turned off,,,was in body shop from hit on drivers front fender,,door,,front corner of bed ,,and rear bumper
    New Friend:
When you turn the key off just wire it into what ever is still on
Posted on Jul 21, 2013
Testimonial: "as anyone who knows anything about newer trucks,,cars,,most optioned with systems that keep certain options on untill a door is opened,,then all goes off ,,,now,,,is there a relay,,code ,,or something to retreive this option"
MY RADIO STAYS ON WHEN I REMOVE THE KEY and close the door
radio stays on after removing key from ignition - Car Talk
community.cartalk.com/.../radio-stays-on-after-removing-key-from-ignit...
Mar 4, 2012 - this just started today and when i turned off my car and removed the keyfrom the ignition, the radio stayed on.
04 F150 - Radio stays on after key removed & door open ...
www.f150online.com/.../323659-04-f150-radio-stays-after-key-removed...
Mar 2, 2008 - You know how you can take the key out of the ignition (after turning off), and radio continues until you open the door? Well, yesterday I opened ... More results from www.f150online.com
Oct 22, 2015 | Chevrolet Astro Cars & Trucks
My 2002 GMC Yukon just completely shut down while
The timing belt broke and the engine died so no power brakes nor steering. (Assuming the milage is over 100,000)
Oct 18, 2014 | 2002 GMC Yukon
I have a GMC Acadia 2010 and when I turned off the SUV the radio don't turn off
has it always been this way, as some vehicle's do have this ridiculous system , some go off when the ignition key is removed completely , if this is a new issue i'd think the ignition switch could be the issue, as not cutting power off completely, so i'd start with getting the ign switch checked out
Jul 20, 2014 | 2010 GMC Acadia
How do i reset 2010 GMC Yukon XL security system
30 MINUTE RELEARN PROCEDURE
  1. Turn ON the ignition, with the engine OFF.
  2. Attempt to start the engine, then release the key to ON, vehicle will not start.
  3. Observe the SECURITY telltale. After approximately 10 minutes, the telltale will turn OFF.
  4. Turn OFF the ignition, and wait 5 seconds.
  5. Repeat steps 1 through 4 two more times for a total of 3 cycles/30 minutes. The vehicle is now ready to relearn the Passlock Sensor Data Code and/or passwords on the next ignition switch transition from OFF to CRANK.
  6. Important: The vehicle learns the password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
  7. Start the engine. The vehicle has now learned the password.
If this doesn't work, it is possible to bypass the security http://vatspasslockpasskeysecurityhelp.yolasite.com/
Mar 24, 2014 | GMC Yukon XL Cars & Trucks
How do i check if strarting problems is caused by key or igination switch
if there is no oil light or if the radio don't plays it could be a bad ignition switch.
Jan 09, 2014 | Mercedes Ml Ml320 Ml350 Ml550 Ml63 Chrome...
Radio stays on car turned off
there is a push pin in the ignition when the key is taken out the pin closes and radio etc goes off. spray some wd40 in the ignition and pushe key in and out a few times should free it up.
Sep 26, 2013 | Honda Cars & Trucks
My radio won't turn off
FAULTY RADIO ON OFF BUTTON
Feb 27, 2012 | 1996 Volkswagen Jetta
When key is turned in the ignition nothing happens. The radio comes on, the lights come on and the dash lights up.
Battery is to low on charge to turn the engine over or the starter relay is bad.
Apr 12, 2011 | 2010 GMC Terrain
Radio stays on when I turn car off. Keys are not in ignition and radio continues to play.
Hi, if this is an aftermarket radio that was added or if someone has changed the wiring, the radio may not be wired properly. Has there been any work done there before this started?
Feb 26, 2011 | 2003 Honda Civic
Radio continues to play when key is in off position, out of vehical and doors are closed. What could cause this?
may be a defective contact at key cyl electrical switch be like if you were to turn key back and the radio stays on replace ignition switch wiring switch hope this helps you
Jan 15, 2011 | 2006 Ford Freestar
Car Audio & Video Logo
27 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
