Need a part number for contactor on ruud UAMB-024JAZ
Anyone know the contactor part number? or what specs are so I can id a replacement contactor?
22yooper
  • 828 Answers
SOURCE: replace contactor
On single phase your incoming power lines go to L-1 & L-2, the lines to the compressor go to T-1 & T-2. With A/C current it does not matter which one goes to which side as long as the line goes to the L side and the compressor power lines go to the T side. As long as the coil voltage is correct any contactor will replace the original.
Posted on May 29, 2008
  • 16 Answers
SOURCE: The outside fan motor (OFM) will not turn off.
You probley have both power wires hooked to the bottem or power side of the contactor switch, one should be pluged into the bottem of the contactor, and one to the top, so when the switch opens, it breaks contact between the two wires (turns motor off).
Posted on Jul 03, 2009
jumptrout51
  • 3361 Answers
SOURCE: I am thinking about purchasing a Ruud UANL -024JAZ
All brands have issues at some point. You should be satisfied with RUUD.
Posted on Sep 28, 2009
gear001
  • 59 Answers
SOURCE: RUUD M/N UAND-024JAZ;heat operation issue
Its a wiring problem.
w = white
r = red
y = yellow
g = green
c = brown or blue
check how the furnace is wired, it should match the new thermostat you installed.
www.fastacservice.com
Posted on Oct 18, 2009
  • 141 Answers
SOURCE: Need a part number for fan motor on UAMB-024JAZ
the part # is 51-23055-11 i can get you that motor and cap and ship it to you
Posted on Apr 08, 2010
Testimonial: "Great response. Appreciate the help. "
Need model number or part number for capacitor for RUUD UAMB-018JAZ
capacitor is labled on side in mfd and voltage rating. may have to turn cap. in its bracket to rea.
Oct 24, 2013 | Ruud UAMB Air Conditioner
Uamb-048jaz ruud a/c stopped working what should i check
is outside fan running tells you if contactor is made if so change capacitors on compressor. if not running check transformer,& thermostat.
Sep 01, 2013 | Ruud Heating & Cooling
what supplier do you have ? SQUARE D. +SIEMENS+TELEMECANIQUE?
God bless you
Jul 21, 2013 | Heating & Cooling
I have a Ruud AC Model UAMBO48JAZ That has started to have a hum when it is running it is cooling and has been checked for freon. Could it be the capacitor?
More than likely, it is the hum of the coil in the contactor. Generally, residential uses 24 volts to energize the coil built into the contactor which pulls in a set of contacts (hence the name contactor) to send 220 volts to power the compressor & condenser fan motor. Contactors are relatively inexpensive... so if the noise bothers you, replace it or have it replaced. Put your mind @ ease, the humming noise will do no damage.
Jul 27, 2012 | Ruud UAMB Air Conditioner
Ruud compressor relay not working a/c
Hello,im assumimg you are referring to the contactor coil on the oudoor unit. First you must verify if the coil is receiving 24 volts from the thermostat at the coil terminals, if not there is a problem with the low voltage circuit, possibly a a open thermostat wire or a fuse blown on the indoor control board. If ther is 24 volts at the contactor coil and it does not engages then the contactor coil must be replaced
May 24, 2012 | Ruud UAMB Air Conditioner
Our ruud air conditioner will not go on no fan zero checked the breakers etc, what do i do?
Hello, if the outside unit is not running start at the outside disconnect box and verify if you are getting 240 volts, if you are continue to the contactor coil, check for 24 volts at the contactor coil if there is 24 volts and the contactor does not energize then it must be replaced. If you do not have 24 volts then the low voltage ( thermostat) wiring must be checked out for a short circuit, loose wiring, or the thermostat might be bad. Also, you can check for 24 volts at tjebcontrol board between the r and c terminal if no 24 volts then you have a bad transformer.
Apr 28, 2011 | Ruud UAMB Air Conditioner
it sounds like your fan connector is on the same side of the contactor where your high voltage enters you should have 3 wires 1 wire for each pole of the contactor and 1 wire off the capacitor does the compressor run all the time too? try turning the power switch off on your indoor air handler / gas furnace if the power goes off the fan goes off then it could be low voltage wiring
Jun 30, 2009 | Ruud UAMB Air Conditioner
Replace contactor
May 29, 2008 | Ruud Central System Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
