Question about Haier XQJ50-31 Top Load Washer
Retarder ratchet slips during wash cycle
Hi. During the wash cycle, the retarder ratchet wheel turns when the motor is turning "anti-clockwise". It makes a grating sound. I'm pretty sure this is not meant to happen! It doesn't happen always. There is an adjustment screw which stops the brake pawl. Maybe adjusting this screw might help the problem? Any ideas? Thanks
    Top Expert:
  • Haier Master
  • 12,223 Answers
See the diagram attached. God bless you
Retarder ratchet slips during wash cycle - a97f8fba-6989-43a5-8b4e-40fe809568fb.gif
Posted on Jul 21, 2013
Testimonial: "thanks ernesto, but this diagram is not for my machine"
3 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Posted on Jan 19, 2010
SOURCE: My Haier HW-C1460TVE-U washing m/c keeps giving (CLrF) ERROR Code
Anyway, my machine shows an error code "clrf". I just spoke to someone at Comet, and apparently this means there is too much foam in the machine. The machine will then refill with water and try to rinse it out, but if after that the machine still has too much foam in, then it will stop the cycle. Hence why my clothes are still wet (although I'd not realised they weren't rinsed properly either!).
I have not been using excessive amounts of washing powder, and usually use powder tablets or the liquid tablet sort, so they are a set amount and I don't do anything daft like stick 6 tablets in! I find it ridiculous that this would cause a problem with the washing machine, as I've used them perfectly fine with other washing machines.
Anyway, the advice from Comet was to keep trying different washing powders until i find one that foams less.
Posted on Mar 20, 2010
3350 actros retarder not responding
check the switch under the accelerator pedal , switch in the dash or column to turn it on, fuse for the retarder
take it to a service center for a proper diagnosis
Oct 26, 2016 | Cars & Trucks
DAF CF 85
check the wiring to the retarder and retarder controls ( accelerator sensor --brake sensor etc ) finally have the unit inspected by a service centre dealer.
Apr 12, 2014 | DAF fodil Cars & Trucks
Name of the retarder fitted to Iveco heavy vehicles
Jakebrake,
Exhaust brake,
I cannot remember the name for the electrical retarder.
Apr 10, 2014 | Liquitex Slow-Dri Fluid Retarder Acrylic...
Rinse Light flashes on Miele W829 novotronic
Remove all the load and try to move the drum manually clockwise and anti clockwise. If you notice any friction check the motor separately and the agitator assembly separately.
It could be due to alignment shift causing a wobbly motion or a failure of the bearings.
Check these links:
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.htmlForreplacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html.
Jul 29, 2012 | Whirlpool Washing Machines
Kenmore 80 didn't drain during the spin cycle and leak underneath machine. Makes buzzing noise in the wash cycles.
The pump is likely damaged if it was leaking. Look for a ring of melted plastic on the face side of the pump. Check to make sure the hole is not rounded where the motor shaft enters the pump.
I'd replace the pump just to make sure the washer doesn't flood some time in the future even if the pump turn out to be ok now.
Vlad,
First Choice Appliance Service. Sacramento, CA
Jul 05, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I have a Maytag Model A412, series 11 washing machine. After the machine fills with water the machine appears to start its cleaning cycle but the agitator doesn't work. The water starts & the...
if this is a two piece agitator,it should behave like a ratchet turn freely clockwise and catch counter clockwise if it doesn't catch the agitator "dogs " are shot this is a verry inexpencive repair
Jun 08, 2011 | Washing Machines
Washer fills and goes to agitation cylcle, but weak to no agitation. Upon final spin cycle, began making a loud rapid ratcheting sound and did not spin at all. Machine did drain. I did not observe the...
The direct drive coupling between the motor and transmission has stripped out.
It must be replaced.
This video will help in the repair.
http://www.youtube.com/watch?v=WLPGs2UMUJc&feature=player_embedded
Feb 03, 2011 | KitchenAid KAWS750L Top Load Washer
Speed queen top load washer does not agitate properly
you need to see if the motor turns one direction during wash and the other during the spin. If so, your gearbox is faulty and needs replacement. If motor only goes in one direction at all times, then very possible, the timer is faulty.
May 29, 2010 | Washing Machines
Motor makes noise shortly after starting, makes normal sound level during main body of wash, then makes noise again during what I'm guessing is the rinse cycle. Not sure if it is a pump or motor problem....
Make sure the sprayer arm is turning freely, check for something stuck in the base of the sprayer arm (food or utinsel) preventing it from turning.
Sep 22, 2009 | Dishwashers
Haier XQJ50-31 Top Load Washer Logo
46 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
