Question about Luggage & Travel
Luggage number lock - Luggage & Travel
I have forgotten the number lock code on my hard shell equator suitcase and can't get it opened. how do I rectify this.
Posted on Feb 17, 2014
How to Reset t tsa lock on a Mia toro luggage
How do I set a Mia Toro luggage lock? - Fixya
www.fixya.com/support/t26581106-set_mia_toro_luggage_lock
Apr 30, 2017 - Release the reset button after you set the numbers to the new combination. ... If you still can't open the lock, contact Samsonite Customer Service at .... TSA lock on Eminent Osmosis Luggage, three digit TSA lock (HOW to ...
Amazon.com: Questions And Answers: How do you set the luggage ...
https://www.amazon.com/forum/-/Tx1WRFLRQIYMJR0/ref=ask_ql_ql_al_hza?asin... Jun 20, 2016 - Mia Toro Metallo Composite Hardside 26 Inch Spinner, Blue, One Size ... The factory setting is 000 make sure lock is set to this press the reset ...
How to Set A Luggage Lock / LuggageFactory.com - The Travel ...
https://www.luggagefactory.com > ... > How to Set A Luggage Lock Sep 10, 2014 - TUMI: TSA Combination Padlock: Make sure the combination is set back to (0-0-0), the factory setting if new, or the existing combination if it has been used already. Make sure the mechanism is unlocked. Press and hold the button on the side of the lock. Select a new combination.
how to Reset tsa lock on Mia toro luggage Google Search
Jul 26, 2017 | Locks & Locksmithing
TSA opened our lock on our Delsey luggage, I now am unable to lock the suitcase. How can you reset the lock on the Delsey luggage after unlocked by TSA?
1. Look for a small recessed button below (on the bottom side) the TSA key access.
2. Push in the button with a paper clip or pen.
3. While the button is pushed, change the combination to the desired numbers.
4. Then release the button and the combination has been reset.
I also found this, but it needs to be open/
http://www.ehow.com/how_6927475_reset-tsa-lock.html
Dec 08, 2015 | Delsey Helium Shadow - 25 Trolley Luggage...
How do I can unlock dial lock
The master dial lock is the world's best selling combination padlock.The lock uses three digit combination of 40 numbers.allowing for 15,00 possible variations
.Follow these step to unlock dial lock. 25284217-gdc3ufgmlwaqnv2deqjxyac2-5-0.jpg With the Combination Step 1 Turn the lock until the numbers read right-side-up. Roll the left-most dial until the first number of your combination lines up with the scored hash mark just to the left of the dial.
With the Combination Step 2 Roll the middle dial until the appropriate number lines up with the number to its left. Do the same for the right-most number. Your three-digit combination should now show, left to right, lined up with the scored hash marks.
With the Combination Step 3 Pull the body of the lock away from the U-shaped metal ring without turning any of the dials. The lock will click open to expose a hook. The hook spins 360 degrees so that it can be placed onto, and taken off, luggage.
Forgotten Combination Step 1 Pull the body of the lock and the U-shaped ring away from each other to put pressure on the mechanism inside the lock. Pull the body of the lock away from its attachment, or, if the lock is not attached, apply pressure on the U-shaped ring away from the body of the lock with your fingers. Keep holding a firm, steady pressure.
Forgotten Combination Step 2 Roll the dial closest to the U-shaped ring slowly, while keeping steady pressure on the mechanism. The dial will get difficult to roll over three consecutive numbers, and one of those numbers will click. You should feel and hear this small click, and that is the first number to your combination.
Forgotten Combination Step 3 Repeat Step 2 with the middle dial, and then the farthest dial. Leave the dial set when you find the click, moving onto the next dial. The combination will reveal itself, letting you pull the U-ring away from the body of the lock.
Resetting Your Combination Step 1 Hold the body of the lock so that the numbers face away from you. Set the combination and release the U-shaped ring.
Resetting Your Combination Step 2 Turn the hook of the U-shaped ring counterclockwise 90 degrees until the notch on the stem of the hook and the hole on the body of the lock line up. Push the stem of the hook down into the body of the lock as far as it will go.
Resetting Your Combination Step 3 Turn the hook another 90 degrees counterclockwise while it is depressed into the body of the lock.
Resetting Your Combination Step 4 Roll the dials until you have your new combination.
Resetting Your Combination Step 5 Turn the hook 90 degrees clockwise and raise the stem out of the body of the lock. Turn it another 90 degrees clockwise and push it back into the locked position. The lock now uses your new combination.
Sponsored Links
Luggage Trolleys Supplier
Supplies Made to Order from World's Largest Supplier Base. Top Deals!
www.alibaba.com $0.01 Web Hosting
Scalable, Secure Web Hosting. Try Our Award-Winning Service Now!
www.hostgator.com/1Penny Rooftop Air Conditioner
low noise, high static pressure. Made in China, Inquire Now!
www.airconditionings.cn Download Facebook Apps
Get The Most Popular Apps For The Largest Social Network. Join Now!
www.facebook.com by Taboola
Sponsored Links
Move Over, Turkey: 9 Side Dishes that Will Steal the ShowKraft Recipes See Another Side of Dubai in HattaDepartment of Dubai Tourism & Commerce Marketing by AFAR
Email Best Practices: Sending Emails That Won't Be IgnoredRackspace
TIP
  • Email yourself the password to your lock, and title the email "Luggage Lock." If you forget the password in the future, simply search your email for the term "Luggage Lock."
WARNING
  • Do not open a lock that does not belong to you. It is against the law.
REFERENCES
RESOURCES
ABOUT THE AUTHOR Christopher Michael began writing in 2004 for his college newspaper. He received a Bachelor of Arts in English and psychology, as well as a certificate in criminal justice from the University of Massachusetts, Amherst.
PHOTO CREDITS
  • Creatas/Creatas/Getty images
Suggest an Article Correction
How to Open a Combination Lock on a Samsonite Suitcase
  • How to Reset the Combination on an American Tourister
  • Airline Rules on Locked Luggage
  • How to Reset a TSA Lock
  • Reagan Airport & Luggage Storage
  • How to Prevent Lost Luggage
  • Cost of Shipping Luggage Ahead to Destination
  • How to Repair Wheels on Luggage
  • The Odds of Losing Luggage
  • How to Make Inexpensive Luggage Tags
  • Solutions to Lost Luggage in Air Travel
  • How to Measure Luggage
  • How to Expedite Lost Luggage Claims
  • What Are the Dimensions of Hand Luggage for Air France?
  • What Rights Do I Have If My Luggage Is Lost?
  • How to Store Luggage While Traveling in Italy
  • pixel.gifHappy Camper: Test Your Outdoors Knowledge
  • pixel.gifCruisin' Along the PCH: Test Your Knowledge
  • pixel.gifWhich U.S. Landmark Would You Be?
  • pixel.gifCan You Pass for a Proper Brit?
  • Nov 15, 2014 | Lands Phones
    Cannot lock
    Pick your number. Look at the inside of the lock. There should be a little "slider". Slide that - it sets your number and then your lock should function normally.
    Nov 12, 2013 | Samsonite Silhouette 12 Travel/luggage...
    Eminent luggage lock
    TSA lock on Eminent Osmosis Luggage, three digit TSA lock (HOW to change it to YOUR personal number)
    Put the code numbers to '000'
    Take the lock levers OFF the lock
    Push the round opening button UPWARDS.
    IMPORTANT :
    KEEP holding the button UP until you have changed the numbers
    Change the TSA code numbers to what YOU want
    Release the round opening button
    Now your case combo lock numbers have been changed.
    To lock the case put the two lock levers into the holes, spin the numbers and your case will be locked.
    To UNLOCK the TSA code spin the numbers to YOUR lock code, push the lock button UP and, hey presto, your case will open.
    If you forget your NEW lock number you will NEED to go through ALL the numbers, starting at '000' to '999', to be able to open the lock/case.
    REMEMBER to PUSH the ROUND OPENING button UPWARDS on EVERY number change.
    Only THEN, when it finds YOUR correct three digit number, will it eventually open the suitcase/luggage/baggage.
    Good luck
    Aug 31, 2013 | Luggage & Travel
    Number lock is forgotten on tolly luggage bag
    Jun 07, 2013 | Cell Phones
    I need to open a 4 dial brass combo lock. It is a Samsonite luggage lock. The patent number is 5,715,709. It is locked but not to anything. I would hate to throw it away, but if I can not open it then,...
    The patent number does not help at all, because it is the same on all luggage by Samsonite.
    If you could find a serial number that was unique with each piece, that could possibly cross reference a combination, but not likely.
    May 09, 2011 | Garden
    HOW TO CHANGE LOCK COMBINATION IN A SAMSONITE LUGGAGE OYSTER GL
    I forgot my locker combination and my luggage is locked.How can I open it??
    Nov 13, 2010 | Samsonite Silhouette 11 Hardside Spinner
    Reset lock on samsonite oyser luggage
    i hope you can help me!
    i went to change the combination on my locked Samsonite bag and when i closed it it would not open on that number.
    i have tried the past number as well as the new one and it still doesn't open. thank you if you can help please it would be appriciated.
    Carolyn
    Jun 09, 2010 | Locks & Locksmithing
    Set luggage lock
    the lock is currently set to 000. To set your own combination and with the lock in the 000 position, open the case and on the inside of the lock mechanism you will see a red tab. slide this tab to the left and then move the digits on the front to your desired code. ie 123. then move the red tab back to lock in this new setting as your own personal combination. close the case and then move the digits away from our setting of 123 and this locks the case. only if the digitrs are 123 in this example will the lock now open.
    Dec 24, 2008 | Locks & Locksmithing
    Luggage & Travel Logo
    294 people viewed this question
    Top Luggage & Travel Experts
    ray gallant
    Tom Chichester
    Dave braun
    Dave braun
    Are you a Luggage and Travel Expert? Answer questions, earn points and help others
