Music slider takes ny music to zero. I have already tried to fix through the settings and volume control
Damaged hardware is responsible for the most obvious iPod
sound problems. In such cases, Apple may be able to help you fix the problem,
depending on the status of your warranty.
All iPods have a one-year warranty according to Apple's
website.
Software problems can also affect your audio.
For example, downloading a non-certified Apple application
can stop your sound from working correctly.
Returning your iPod to its original factory settings fixes
many of these software glitches.
Plug in a different set of headphones and test the sound.
If that set works, your old headphones were the cause of
your audio problems.
If your iPod still doesn't work, proceed.
Remove an application on your iPod Touch if you installed it
right before your sound stopped working.
Hold your finger over the top left corner of the
application.
It will shake.
Touch the "X." Touch the "Home" button.
Restore your iPod to fix other potential software problems.
Open iTunes. Plug the iPod into your computer with a USB
cord.
Click on your iPod on the left-hand menu.
The iPod will be listed under the name you assigned it when
you first set it up.
Click the "Restore" button on the menu.
Leave the iPod alone while it restores. It may take several
minutes.
Test the sound once the restore is complete.
The iPod syncs after restoration.
Once the sync is complete, the process is over.
Contact the Apple Technical Support line at 1-800-275-2273
if your audio still doesn't work.
Have your iPod with you.
http://www.apple.com/support/contact/
iPod Video Headphone Jack Replace Hold Switch Fix Sound
in One
http://www.youtube.com/watch?v=slIo8PX06-s
SOURCE: How can I take music off and put new music on
The music that is on any mp3 player is a copy of what you have stored in the library of your computer music software so if you want to delete a song from your mp3 player you have to delete it on the computer then syncronise. This is the same if you want new music, you have to add to your library first. You cannot delete music using any of the controls on the actual mp3 player.
SOURCE: volume control
The only way to reset the lock code is to restore you Ipod back to factory settings through Itunes. Then you can reset the code.
SOURCE: i put music on my ipod shuffle and when i wanted
ther is many things to be checked
1 check ur headphone or use another headphone and check whether it is working or not.
2 if step1 doesnt work then reset ur ipod through internet and checkout .
3 if the 2step deosnt work then there might be problem in the ipod take it to the nearest apple care centre and get the problem solved. u get one year warranty for ur product
SOURCE: when i use the ipod touch speaker i can hear the
It sounds like it's definitely a problem with your iPod. . . Sometimes the connectors on the inside of the unit can go bad. I've not heard now this can be fixed though. I would try calling apple and seeing it the unit is still under warranty.
Using
a microphone with computer
To use any microphone with your
computer you will need to enable it in control panel. The following
instructions are for Windows XP but are broadly similar for Vista
and Win7
Click START, CONTROL PANEL, SOUNDS
& AUDIO DEVICES
Click VOICE
In the Sounds & Audio Devices
Properties window locate the SOUND PLAYBACK box and click the VOLUME button.
Make sure that there is not a tick (check-mark) in the MUTE box against
microphone in the list of devices and that the volume slider is at the top of
the scale.
Also make sure that the MUTE ALL box
isn't checked before closing the window.
Now click the VOLUME button in the
SOUND RECORDING BOX. Here you need to SELECT microphone as an input source for
recording (as opposed to un-checking mute in the playback
controls).
NOTE if microphone is not listed in the
2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and
place a check against microphone in the list entitled
'show the following volume controls' and then click OK.
That should be it.
