Question about Iomega ScreenPlay
My Iomega ScreenPlay HD won't turn on...
My Iomega ScreenPlay HD won't turn on. It doesn't even go into standby mode. Of course it is plugged in. Anyone have any ideas ?
SOURCE: Remote code for the iomega screenplay
I bought the JELLY Universal PC Programmable remote in Portugal for 10 euros. The code for Iomega Screenplay is 2297. See it here: http://www.wiltsgrove.co.uk/sub-category.php?ID=1709&CID=0026&PID=IR2005
Posted on Mar 30, 2009
leecom72
  • 4806 Answers
SOURCE: My Iomega Screenplay 500 hd was recently sent back
When you buy an external drive/enclosure combination from a drive
manufacturer (Seagate, WD etc) the drive usually comes formatted as fat32.
Because you have formatted the drive in NTFS the TV will not recognize the drive it has to be formatted in fat32 for the TV to recognize it.
Because of the limitations of Windows XP, you can not format any fat32 partition larger than 32 gig. (i think this also goes for Vista too but its worth a try)
The work around is to create/format the partition by booting up into
Partition Magic from their 2 floppy set that the program allows you to
create. Then you are not bound by this restriction.
You can also get partition magic on the hirens boot CD, and partition the drive that way.
You can also partition/format the drive by booting up from a Windows 98se or a Windows ME setup floppy and use the combination of the fdisk and format commands to create one large partition and format same.
Of the two, Partition Magic is easier as you have a visual interface to see what you are doing. But both work the same.
With older M/B's you may have to remove the drive from the external
enclosure to perform the actions as the drive may not be seen while in the USB/Firewire enclosure (bios limitation). The drive will have to be
connected to an IDE/SATA cable connected to one of the IDE/SATA ports on the M/B.
Regards.
Posted on Aug 20, 2009
SOURCE: Iomega Screenplay Pro HD - No Menu
I had the same problem with the Screenplay Pro HD. My Iomega was working fine and one day after exchanging files with a friend I got the logo, then the loading message and then it went into a black screen while the blue light kept blinking.
Obviously the connection to the TV was fine because the logo appeared.
I solved the problem by downloading and reinstalling the firmware.
I downloaded the firmware from the iomega web site.
Notice that during the installation process you get the message that it will delete your data and then shortly after you have the option to delete or keep it. Hang in there. This part is a little nerv wrecking.
Hope this helps.
Rainer
Posted on Jan 03, 2010
  • 71 Answers
SOURCE: Resolution not supported error on Iomega SCREENPLAY HD 500gb
Avi files should be 700 or below when playing on a conventional tv,625 or 525 prefered.
if set to hd format trough HDMI output the display warning will not appear has the iomega will upscale trough the HDMI output,and will suport any resolution.
Posted on Jan 20, 2010
SOURCE: Iomega Screenplay Pro HD Multimedia Drive works on PC but not on
If the blue light continues to flash after the screen goes black, then you need to reinstall the firmware. Look at http://screenplayprohd.wikia.com for information about getting the firmware and installing it.
If the blue light goes solid after the screen goes black then you probably just need to switch the NTSC/PAL selection. Press that button on the front panel several times, waiting a few seconds inbetween in press. If it continues to be invisible, plug the drive into another TV using the composite cables instead of HDMI to confirm if the menu comes up at all. If it does, reinstall the firmware.
Posted on Apr 06, 2010
Iomega screenplay director firmware
Iomega i ScreenPlay Director SPDHD - Lenovo Community
forums.lenovo.com > ... > Iomega Desktop Network Storage
Nov 16, 2013 - 5 posts
Hola, tengo un iomega screenplay director y hasta ayer me ... aqu?: Versi?n 1.4.0.92 del firmware de ScreenPlay Director: Leer primero Iomega Screenplay Director HD doesn't work on TV
Mar 15, 2015
Firmware Iomega screenplay HD500
Feb 9, 2014
How to find, download and install firmware on my i...
Jan 14, 2014
Iomega ScreenPlay Director error 12
Jan 10, 2014
More results from forums.lenovo.com
Dec 25, 2015 | Iomega ScreenPlay Director 1TB HD Media...
I need handbook for iomega 500 screenplay hd and the remote control
http://www.retrevo.com/support/Iomega-ScreenPlay-HD-500GB-Storage-manual/id/23594ci364/t/2/ download the manual from there
Dec 31, 2012 | Iomega Prestige 500 GB USB 20 Hard Drive
I would lke todown load a users manual for mynew screenplay mx2 hd media player s/nBBA1370FC1 MODEL 31971400 SPDHDMX2
The first link is the HTML version of it. This means it's not so much of a download as it will just show you the manual in your web browser. The second link is for the download, however, it is buried in a long list and you'll have to scroll down until you see it (it's a little below halfway down the page):
1.) http://www.iomega.com/support/manuals/mediaplayer/spmx2/en/main.html
2.) https://iomega-na-en.custhelp.com/app/answers/detail/a_id/14432#scrnply
I hope this helps you!
Sep 25, 2011 | Iomega 1TB ScreenPlay MX HD Media Player...
My iomega screenplay 500gb is not coming up on 2 of my laptops when i connect it via usb it comes up local disk and when you click it my computer just crashes and it takes a while to load up, it doesnt...
Try plugging in the player & powering it up fully (wait 2 minutes). Once fully booted, connect it to your laptop...this should work - if not, you likely have a problem w/ the hard drive internal to the player.
Feb 07, 2011 | Iomega 500GB Iomega ScreenPlay Plus HD...
I need to download iomega Screenplay 1T user manual
You should be more specific with which unit you have when asking questions about it.
ScreenPlay Director HD Media Player: User's Manual: View Online [HTML] http://www.iomega.com/support/manuals/hdd2010/spdirector/en/main.html
ScreenPlay Multimedia Drive: User's Manual: View Online [HTML] http://www.iomega.com/support/manuals/hdd2008/scrnply/en/consolidated/main.html#scrnply
ScreenPlay 60GB Multimedia Drive User's Manual: http://www.iomega.com/support/manuals/allhdd/screenplay/en/main.html
ScreenPlay HD Multimedia Drive: User's Manual: View Online [HTML]: http://www.iomega.com/support/manuals/hdd2008/sphd/en/main.html
ScreenPlay Plus HD Media Player: User's Manual: View Online [HTML] http://www.iomega.com/support/manuals/hdd2010/scrnplyplus/en/main.html
ScreenPlay Pro HD Multimedia Player: User's Manual: View Online [HTML] http://www.iomega.com/support/manuals/hdd2010/scrnplyprohd/en/main.html
ScreenPlay TV Link User's Manual: View Online [HTML] http://www.iomega.com/support/manuals/hdd2010/sptvlnk/en/main.html
ScreenPlay TV Link HD Media Player Director Edition: User's Manual: View Online [HTML] http://www.iomega.com/support/manuals/hdd2010/sptvlnkdir/en/main.html
Oct 10, 2010 | Iomega ScreenPlay
How do i download a manuel for my new screenPlay Director HD Media Player I have 700 Albums and it takes forever to scroll throught them on my TV
Downloadable Manual [652KB zipped HTML] http://download.iomega.com/english/manuals/english/screenplay-director-en.zip
Quick Start Guide [PDF 1.2MB] http://download.iomega.com/qsg/spdirector_us.pdf
Specifications https://iomega-na-en.custhelp.com/cgi-bin/iomega_na_en.cfg/php/enduser/std_adp.php?p_faqid=22159
May 25, 2010 | Iomega ScreenPlay
Nov 11, 2009 | Iomega ScreenPlay
Hope this helps.
Rainer
Jul 10, 2009 | Iomega ScreenPlay
Iomega ScreenPlay Logo
148 people viewed this question
Top Iomega Televison & Video Experts
Martin Murray
Chris Larocque
Are you an Iomega Televison and Video Expert? Answer questions, earn points and help others
