Universal Remote Control Set Up CoC
I have an older model Sanyo tv, and a One for All URC 5061 universal remote control. I need the set up code for the remote? Should be a 3 digit code based on the "simple" instructions on the back of the remote. PLEASE HELP...Thank you.
    Top Expert:
  • Televison & ... Master
  • 74,185 Answers
1072 1145 1423 10611178 1047 1171 1298 1316 1347 1349 1143
1157 1172 1208 1360 1024 1115. These are the set-up codes to check with Sanyo brand TVs. If you wish to get more, http://electrohelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Mosaic / Timeslide option. Try this link too. http://remotesearch.blogspot.com/
Posted on Jul 21, 2013
Testimonial: "Thank you very much for your reply. I actually was able to re-set the remote using instructions I had found on this web sight http://www.hifi-remote.com/ofaold/5060pro.html, earlier in my search, prior to coming here. Specifically step 2, "searching for your code". It did take approximately 25-30 times of repeating the same sequence before it worked. Just wanted to say Thank You, & maybe the link above will/can help someone else in the future."
  • 4 Answers
SOURCE: Remote Control Codes for Phillips TV using Jumbo Remote Control
TRY THESE CODES FOR PHILLIPS:
062 204 184 208 205 206 207 004 288 003 008
068 075 086 087 141 189
Posted on Jan 06, 2008
SOURCE: programming a universal remote control for a tv
The code for a Sanyo TV set should be 100. Press and hold the TV button on the remote while entering the code. The light should blink 5 times if it was accepted, and then you can test to see if it worked.
Posted on Feb 10, 2008
  • 4 Answers
SOURCE: INSTRUCTIONS NEEDED FOR THE SHARPER IMAGE - JUMBO UNIVERSAL REMOTE
Hello kls1996... programming your remote is rather easy. The easiest way (thanks to The Sharper Image Jumbo Remote being a LEARNING SMART remote) is to do the following:
1 - Point the head of your Sharper Image remote at the head of your Sanyo TV remote (nose to nose so the clear bulbs on each remote are facing each other).
2 - Press the "TV" button on your Sharper Image remote (located in the upper left-hand corner).
3 - Hold the "LEARN" button on your Sharper Image remote (located in the left edge under the volume buttons) until the red light flashes.
4 - Press the key on your Sharper Image remote (e.g. Volume Up or +VOL)... the red light will go solid (indicating that it is waiting for a signal from the other (in your case Sanyo) remote.
5 - Press the key on your other remote (in your case the Sanyo remote) that you want programmed in your new Sharper Image remote... the red light will flash rapidly again.
6 - Repeat step #4 until you have programmed each key.
7 - When done... press the "LEARN" key on your Sharper Image remote. Your Sharper Image remote should be programmed to operate your device (in this case, your Sanyo TV).
NOTE: You can program other devices such as your VCR, DVD, VHS, SAT, CABLE, etc. and not just one device.
Posted on Jan 16, 2009
the q guy
  • 393 Answers
SOURCE: Universal Remote used to control Digital converter box
I found that this website should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
if this helps please give a fixya rating as thats how we get paid.
Posted on Jun 12, 2009
SOURCE: Need the instructions and Code to Program universal remote control PHILIPS (Magnavox) and Magnavox TV.
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
Posted on Oct 19, 2009
I NEED SANYO TV CODES FOR A URC-4021B00 ONEFORALL REMOTE
Jadan, CODES FOR SANYO TV try 0154, 0240 0047, 0104 Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What is the code for Sanyo TV remote control One for All URC 3220
http://www.rockabilly.net/files/manuals/URC-4021.pdf
Welcome to Remote Central Universal Remote Control Reviews More
Codes for Universal Remotes
Aug 24, 2016 | One For All URC-4021 Remote Control
Total Control Universal Remote. URC 4140. What is the 4 digit code to operate the above TV
Search Results
    [PDF]Total Control URC-4140 - Universal Remote Control Codes
    www.remotecodelist.com/remotes/URC_4140_B00_and_B01.pdf
    UNIVERSAL. Remote control. URC - 4140 ... Your TOTAL CONTROL can operate four devices: a Television, ... The TV, VCR/DVD, SAT and AUX keys select the device.... 4. Enter your four-digit code using the number keys. The red light will blink twice.... To set up your other devices, follow the same instructions above, only.
    Codes and links for a number of universal remote controls, including Sony, RCA, ... GE Remote Codes, General instructions for GE Universal 3 and 4 digit remote controls. ... This manual may work for a number of Philips-Magnavox remotes. ... Total Control URC-4140, PDF Instruction Manual (remote also known as Crest .
Jan 13, 2016 | Sanyo 42 in. LCD TV
How do I program my sony blueray dvd player tpo universal remote control urc-r6
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Jan 08, 2016 | Sony Televison & Video
I do not have the one for all universal remote control codes for the older insignia flat screen tv
0165 0166 0210 0421 0611. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
Mar 20, 2014 | One For All URC-4330 Remote Control
Need Codes oneforall URC5061
What is the Brand name of your TV?
Oct 03, 2012 | Televison & Video
NEED set up CODES FOR MAGNAVOX TV
Many One-for-All remote manuals and code lists are available here: http://www.oneforall.com/support/manual . Fill in Universal Remote Control and then the model number in the drop-down menus. Then click on the link to the manual. (It's a pdf so you'll need Adobe Reader or a similar program.) The direct link to the URC-6131N manual (English version) is http://www.oneforall.com/uploads/support/9e15c67cf9731f8b8e9b376352f23493.pdf .
Try the following codes: 0054, 0030, 0179, 0024, 0186, 0187, 0386, 1254, 1454 for Magnavox TVs. Please note that universal remotes usually only have codes for devices released at least 6 months before the remote was programmed. If your TV is newer than your remote, you may need a newer universal remote. The URC-6131 gives it a date of Feb 2003.
I hope this helps.
Sep 22, 2011 | Universal Remote Control URC-6131N Remote...
Need codes for URC -3220 universal remote to match my signature 2000tv and sanyo TV
I can help you reprogram your URC-3220 Universal Remote for your Signature & Sanyo TVs.
Please review my Fixya Tip posts for:
  1. Searching for the proper codes, or
  2. Downloading the URC-3220 users manual / owners guide.
I hope that helps.
Feb 11, 2010 | RCA 3-Device Universal Remote
I need the code for urc3220 remote sanyo tv
I can help you with your URC-3220 Universal Remote Control issues.
The codes for Sanyo TV's are: 0154 & 0159.
For complete instructions on entering the URC-3220 remote codes, please refer to my posted Fixya Tip One For All URC-3220 Code Entry.
I hope that helps.
_______________________________________________
One For All URC-3220 Manual
One For All URC-3220 Code List
One For All URC-3220 Code Search
One For All URC-3220 Reassign Key
Dec 30, 2009 | GE JASRM24912 Remote Control
Code for remote
To program your URC-3021 remote control to operate your TV, the remote has a code search function.
To search for a code for your TV:
  1. On the remote control, press TV once.
  2. Press and hold SET until the LED blinks twice, then release SET.
  3. Enter 9 - 9 - 1.The LED will blink twice.
  4. Aim the remote control at the the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off.
  5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
Hope that helps.
Dec 08, 2009 | One For All URC-3021 Remote Control
How do you key in the code for the TV on a URC-3220 remote for a Sanyo TV?
URC-3220 One for All Big Easy 3 Universal Remote
I can help you to program your One For All Big Easy URC-3220 Universal Remote to control your Sanyo TV.
  2. Downloading the URC-3220 users manual / owners guide. This contains all the codes for the brands of devices your remote can control.
I hope that helps.
May 14, 2009 | One For All URC-3021 Remote Control
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
