Imation 320gb my imation portable hard drive was working fine a few days ago and now the blue light doesnt flash and my computer does not recognise my device when i troubleshoot it says the device driver is missing and it says apply fix i press it it does a searching thing and then just says device driver not installed
  • 23 Answers
If the drive only uses USB to power-up then most likely the internal power board has failed. If it has a external power supply, then you would want to test that using a multimeter to see if it is still outputting power. Alternatively the hard drive itself could have gone bad (when you plug it in to the computer can you hear the hard making repeating clicks - usually in a pattern). If the hard is still good it can extracted from the enclosure and put into a new aftermarket one such as this: 2.5" sata enclosure
Posted on Jul 23, 2013
SOURCE: Acomdata Portable Hard Drive
got an answer on ask.com
Posted on Feb 20, 2009
  • 7 Answers
SOURCE: western digital 320g elements portable won't work
Hey,
try connecting it o another computer and check
if not yet, use only the WD USB transfer wire supplied in the box.
because WD External HDD only recongize its own USB and none other.
Posted on May 03, 2009
SOURCE: Problem with Iomega Portable Hard Drive
get error message from new installed portable hard drive. Access denied. Using windows XP
Posted on Feb 21, 2010
SOURCE: PC not recognising Iomega Prestige 320gb usb portable hard drive
Does the drive show in Device Manager? Right click on 'My Computer' and select properties, the open device manager.. Navigate down to Disk Drives or Hard Drives, click on the plus sign and see if your drive is listed. If it is, then right click on the drive name and open properties for the drive. Click on the 'Volumes' tab and hit the 'Populate Button'. It may be the disk just needs initialising, then reformatting before you can use it. If it does need initializing, a wizard should appear to guide you through the process!
If this doesn't solve your problem, try using a different USB cable and/or USB ports on your computer, and ensure to unplug all other USB devices other than keyboard & mouse.
Posted on Mar 08, 2010
SOURCE: power light flashes but disc doent spin
no hablo ingles
Posted on Apr 28, 2010
I've got a samsung m3 portable that has suddenly stopped being recognised
it is not uncommon for external hard drive enclosures to fail. If its not working on multiple computers, this is probably the case. try it in 1 more computer and if it still doesn't work, I would do the following:
1. Open the enclosure to expose the actual Hard Drive and obtain the model number and note the size. if its a laptop hdd, its 2.5". if its a full size hdd like in a desktop pc, its 3.5". the enclosure may be screwed together but likely snaps together.
2. Google the model # to determine the interface and speed (likely SATA 3.0gb/s but could be SATA 6.0gb/s
3. Go to Newegg.com or Amazon.com and buy a new external hard drive enclosure ($5-$35) with the same interface, speed, and size as your hdd (use the filters on the left to narrow your search)
Home Computer Hardware Computer Cases External Enclosures
4. Put your hdd in the new enclosure and check if its working.
Mar 07, 2014 | Computers & Internet
Buffalo Ministation not flashing or recognized
Im having the same problem sound like your cable is not working or you need a new case because the pins are broken.
Jul 22, 2013 | Buffalo Technology 320GB MINISTATION TURBO...
My imation portable hard disk 320gb doesnt work or does not detect by the computer
Yourhard drive is properly dead.However there are stillhopes for hard drive data recovery.
Put the hard drive in a plastic bag to be compatible for the freezer. Freezingsometimes works to revive a dying hard drive, at least for a shorttime(Probable just about 20 minutes), but be sure that the bag is sealedtightly so that condensation and ice crystals don't form. Put it in your freezerfor 24 hours that will do the trick. While it's still cold, plug it into yourcomputer.And you may be able to view it in 'my computer'. And you may actquickly,because you may only have 20 minutes to recover your data off it andafter that the hard drive is completely dead.
If it fails, you will have to go to a recovery office where supply datarecovery service but let's hope not because it will cost you a lot of money andwhether they can recover data is not guaranteed.
Here is a tutorial to guide you how to recover data from hard drive.
Sep 13, 2011 | Imation Apollo (27223) 250 GB USB Hard...
Hi, I had problem using Imation 27390 apollo expert ux. The hardisk is in NTFS format, and work perfectly fine when i plug in computer with Windows Vista and 7. But it cannot be recognized by computer...
Windows XP has limitations on recognising too large NTFS disks. One of the solutions would be to format the entire disk as FAT32 or make a partition and format that as FAT32.
Feb 28, 2011 | Imation 27390 Apollo Expert UX 2.5" 320GB...
Sir/mam my imation external hard disk 320 gb is not detecting in any of my and my friend systems, i tried in windows xp/7, ubuntu. but not working. blue light(power light ) is glowing, while placing...
Unfortunately, external hard drives go bad. A 320 is probably a few years old, I replace mine about every 3 years to be sure. I know it sounds funny, but things work till they don't. Just because it was working yesterday does not mean it will work today. It is possible there is a setting in your XP or 7 to keep from seeing the drive, but doubtful it changed on both systems between yesterday and today.
Oct 30, 2017 | Imation (23780) 320 GB USB 20 Hard Drive
I have a 320gb toshiba external hard drive, i've been using it around 3 years without any trouble. A few days ago i lost the cable connecting it to the PC. I bought a few cables but no use. Doesn't...
This is because there is a connection problem between the external drive and the computer. If you have changed cables to no avail, you can open the casing of the external drive where you will find the hard disk inside. Unplug the two cables connected to the harddisk and replug it after a minute. Then try again. If it still does not work, then you need to buy just a usb enclosure and plug the harddisk there to be able to use it again.
Hope this helps. Thank you for using FixYa.
Jan 13, 2011 | Toshiba 120GB USB 2.0 Portable External...
I just got an Imation Apollo UX 320 Gb without need of power supply from my brother in law, as a gift. The problem is that he gave it to me without the cable so I connected it to my computer with a cable I...
try a shorter usb cable long ones typically dont flow enough power unplug all other usb cables and make sure your computer is up to date with all Microsoft fixes [if your using windows] it should either auto-play and pop up or be viewable from [my computer] i hope this works please vote
Nov 29, 2010 | Imation 27390 Apollo Expert UX 2.5" 320GB...
Western digital 320g elements portable won't work
Hey,
May 03, 2009 | Western Digital Elements powered by WD 320...
Computers & Internet Logo
David Payne
David Payne
