Question about Garden
Craftsman 4 0 eager 1
I need a new jet bolt, that holds the fuel bowl on, engine # 143.964006, M-917 386121 I am not sure what it is called, I thought it was called a needle value
  • 2692 Answers
SOURCE: can't find oil drain plug on eager-1 mower
Disconnect the sparkplug andf ground it. Turn the push mower on it side and scrap away all the grass from under the deck and look for the plug. If you cannot find one, drain the oil out from  the fill tube into a pan, buy turning it onto it's side into the pan.
Posted on May 06, 2009
  • 84 Answers
SOURCE: craftsman eager-1 3.75 mower will not stay running
the engine is not getting enough gas. when you hold down the primer you are bypassing this problem. to fix this simply adjust the carb's fuel screw, located on the side of carb, a little at a time until runs smoothly.
Posted on Jun 25, 2009
lasvegasrich
  • 65 Answers
SOURCE: Looking for a manual on a Craftsman Eager-1 .
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=131.90300&productCategoryId=1503700&brandId=0247&modelName=ROTARY-LAWN-MOWER&diagramPageId=00001&documentId=00035640&pop=flush
PARTS LIST AND PICTURE.. WHAT DO YOU NEED TO KNOW OR DO??
Posted on Aug 22, 2009
  • 16 Answers
SOURCE: craftsman eager-1 lawnmower will not start
Hi, The first thing I always check for is fresh fuel (less than a couple of months old) old unleaded may well be fine in your car but low compression engines fitted to garden equipment need fresh fuel. next thing to check is that the choke flap is closing fully, dont rely on the position of the control lever, remove the airfilter cover and see that the flap is fully closed, if it's cracked open just a little bit it will stop engine starting ( unless the filter is really dirty) another thing to check is that the blade is tightly secured, on direct drive mowers the blade acts as a flywheel. did you hit an obstruction the last time you used it, if you did you may have sheared the flywheel key(poor spark on points ignition or good spark but timing out of sync on electronic ignition. hope this helps, regards Tony (England UK)
Posted on Aug 31, 2009
#1 Taper
  • 1041 Answers
SOURCE: need an owners manual for a craftsman eager-1 walk
Try this site: http://www.manualsonline.com/
Jim
Posted on Dec 01, 2009
Snow blower dying out?
Its the carburetor. Needs to be cleaned. But try this first. On the bottom of carb is a round bowl with a bolt holding it on .If snowblower has gas in it clamp fuel line to stop fuel leakage. Remove bolt and pull bowl down slowly. Look in bowl to see if there is water at bottom under gas.To be sure dump out fuel and clean out bowl with clean rag and some air. Next place a small piece of tube in bottom of carb that you took bolt out to hold bowl on. Blow air in to remove any dirt and reassemble carefully and refuel carb and start engine. Good luck.
Feb 17, 2014 | Craftsman 21" 179cc* Single Stage...
Can not start snow blower
Todays gas is horrible for gumming up after a few months. You need to clean the carburetor.
This description is for many 4 cycle engines.. it Might help The jet in the Carb is gummed up. Take that 1/2" bolt off the bottom of the Bowl..That IS the Jet. Many times the Bowl will just hold in place with the Bolt out.. make sure the three holes are clear. 2 are close to the head of this bolt and you should have a 3rd real small hole where the threads end. Screw it back in...see what happens
Dec 11, 2012 | Craftsman Snow Blower / Snowblower Bottom...
I have a craftsman 5.5hp 3 in 1 Eager 1. Im having a problem starting it I've changed the spark plug and it still wont start any suggestions
Your carburetor probably needs a good cleaning. If it has the Tecumseh engine with the sideways carb on it, there is one thing to check quickly. Remove that brass bolt (main jet) on the bottom of the float bowl with a 1/2 inch wrench. Check all the tiny holes in it and make sure they're not clogged. You'll find one very very very tiny (I can barely even see it with my old eyes) hole right at the very top of the threads on that bolt and it gets clogged very easily with today's ethanol gasoline. If that gets clogged, your mower won't start. Also make note of the way the bowl is installed. It MUST be put on with the bevel side toward the hinge on your float or the float won't operate. Best of luck. I hope this helps.
James
Aug 25, 2011 | Craftsman Garden
Hi, I have a Craftsman Eager-1 5.3 3-in-0ne solid state enigine lawn mower..got it used but in almost new condition. worked great cutting 1 1/2 ft of very wet grass for a few hours (couldn't get to it...
Drain the fuel or when you remove the float bowl bolt (also the main jet), then hold up on the float to keep the needle on the seat so gas won't go everywhere. When you have that brass bowl bolt off, clean it! Use nothing metal on it. Pay close attention to the small hole in the bottom and along the smooth unthreaded part at the other end. Use carb/choke cleaner to blast gum and dirt out of those very small fuel orifices. I recommend installing an inline fuel filter also. A shut off valve is recommended too, that way if the needle in the carb sticks open, the crankcase won't be polluted with gas. Usual symptoms on a clogged lawn mower main jet though, are after pushing primer bulb, engine runs about 3 seconds. Try the brass bolt cleaning and post back if needed.
Jun 14, 2011 | Garden
My mower stops right after I prime the engine like its not getting any fuel. I have cleaned the flywheel, gapped the armature to .013 about the size of a business card. New plug, filter ect. I took the...
Make sure all the small holes that are in the brass bolt that holds the float bowl on the carburetor are clean and clear. Use no metal objects to clean it. You should find holes in the bottom of the bolt and along the top on the non-threaded part. This bolt is also the main jet of the carburetor.
Apr 23, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
The lawnmower starts for a few seconds, then dies.
Probably a fuel delivery issue. There is a brass bolt that holds the bowl to the carburetor on. It has an exterior washer, so don't lose. This bolt also is the main jet for the carburetor and can become clogged especially if old gas is allowed to evaporate in mower and no in-line fuel filter is used. Drain the fuel tank (or it will drain when you remove the bowl!). The bolt has very small holes on bottom and sides. Make sure they are clean and clear and the bolt is nice and cleaned up. Use no metal, and/or scraping on bolt. Reassemble (don't forget the carb body gasket) and engine should run if no other issues.
Please vote on this solution.
Sep 04, 2010 | Craftsman 675 Torque 190 cc 21" Push Lawn...
My lawn edger craftsman 3.5. h.p. will start ,THEN SHUT DOWN RIGHT AWAY.why?
Fuel delivery problem most likely. Fuel is getting INTO the carburetor but that fuel is NOT making it into the engine probably because...the Main Jet may be clogged. This is the brass bolt that holds the bottom bowl onto the carburetor. It has an exterior washer (dont lose it). Remove this brass bolt and clean all the tiny holes in the bottom and sides of it. Clean the bowl up nice (dont forget the main body gasket too) and replace it all....now the gas WILL make it to the engine.
Aug 31, 2010 | Craftsman Garden
I have a craftsman rider w/ a 12 hp tecumseh. it
Most surging problems today are caused by a 'lean fuel' condition caused by 'varnish' or debris in the 'main jet' of the carburetor. Many times the jet can be cleaned with a thin piece of wire commonly called 'tag' wire. It is smaller than the main jet hole and does not damage the hole. The main jet is commonly the nut on the bottom of the carburetor that holds the bowl onto the body of the carburetor.
If the body or bowl of the carburetor is plastic, then the best solution is to replace the bowl with a kit that is offered by the manufacture.
In some cases, the carburetor has an electric fuel solenoid, which when malfunctioning, will not allow enough fuel into the main jet to operate the engine.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 07, 2009 | Craftsman Garden
Craftsman eager-1 3.75 mower will not stay running
Jun 24, 2009 | Craftsman Garden
Garden Logo
73 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
