Question about Pitco Frialator SG14 Deep Fryer
The front drain is leaking
I need to change the drain valve, how do i change it
  • Pitco Frialator Expert
  • 683 Answers
Hi there.
Check first if there are no foreign objects hangings on the ball causing leak.
If you really need to change the ball valve, cling the jaw of a 14-inch pipe wrench on the neck of the valve connected to the fryer drain and turn it counter clockwise (***do this with no oil on fry tank and make sure that the tank is cold).
Wrap a teflon tape on the thread before installing the new ball valve.
Regards.
Posted on Nov 22, 2013
Drain valve leaking
Drain valve leaking, valve ball dripping, i need to change the all drain valve
Jul 21, 2013 | Pitco Frialator Kitchen Appliances -...
Miele G2020 leaking 2 spots help
please follow this steps and fix it. God bless you
Dishwasher Not Leveled
This is a very common reason for a leaking dishwasher especially if this was a new installation. The framing in a dishwasher is made up of mostly thin sheet metal, so if it is not sitting flat and level things can get distorted very easily.f3a0b0dc-c8b0-4678-bccb-f94392039827.gif
Door Seal
This is not very common in most dishwashers. To check this look for rips and distortion of the seal. If it is ripped or distorted you will need to replace.
Dispenser Seal
This is a more common place for a leak to develop. This is easy to check, remove the front panel and carefully inspect around the seal for water dripping or stainage. If any is found replace the dispenser gasket.
Water Inlet Valve
Usually it is the connection to the water inlet valve that ends up leaking. Check this connection ( there is usually some sort of adaptor between the valve and supply hose) for leaks. Check the connection on the back of the water inlet valve also. Ocassionaly a water inlet valve will leak around the solenoid in this case replace the water inlet valve.
Drain / Circulating Pump
Some dishwashers have separate drain and circulating pumps Some use one pump to serve both purposes. In either case you will need to check the housings for leaks along with all the connections. Some dishwashers have a seal that leaks down into the pump . This is easy and inexpensive to replace. Follow the tutorial on replacing the pump.
Door Latch
The door latch can become loose or misalinged. Check both the striker and the latch. To adjust the latch you will need to remove the front panel and adjust switch until properly aligned.
Door Hinges
They can cause problems, but this usually only happens from opening a heavy load of dishes on the door. Occassionaly a broken spring or cable occurs. You will need to remove the tow kick and maybe the front panel to inspect.
Jun 14, 2013 | Miele Dishwashers
Cold water leaks into tub when machine is off
Try to identify roughly the area the leak is coming from. This will eleminate some of the following
Hose Connections
Check the rubber washers or replace if the hoses are leaking at the WATER INLET valve
Door Seal
This is a common place for leaks. Carefully check by partially pulling seal inside out and check for punctures, pens, pencils... Additionaly if the door is not closing properly it may need a door adjustment. This can easily be done by loosening the hinge bolts on the front panel, adjusting and retighten. The seal is also known to get lightly snagged by zippers or rub by heavy items when close are being removed. This tends to cause the seal to get damaged at the six o'clock position. This is sometimes hardly noticeable but if it is leaking from the bottom of the door replace door seal.
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace inlet water valve
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is behind the lower panel, behind the back panel, and sometimes removal of the front panel. Hoses can be tightened. If hoses or pump housing is leaking replace pump .
Outer Drum
The outer drum is 2 halves bolted together some washers have a seal between others do not. If the washer is leaking between the seems disassembly of the washer will be necessary. The top panel, console, front panel, door seal, struts. 9696d86e-1b8b-4b2e-af2c-6f3a3ae921dc.jpg
May 23, 2013 | Siemens WK61420GB Front Load Washer /...
How can I get to the inside
If your dishwasher is Leaking check the following
This is a very common reason for a leaking dishwasher especially if this was a new installation. The framing in a dishwasher is made up of mostly thin sheet metal, so if it is not sitting flat and level things can get distorted very easily. Watch the video on leveling your diswasher
Door Seal
Dispenser Seal
Water Inlet Valve
Some dishwashers have separate drain and circulating pump. Some use one pump to serve both purposes. In either case you will need to check the housings for leaks along with all the connections. Some dishwashers have a seal that leaks down into the pump . This is easy and inexpensive to replace. .
Door Latch
Door Hinges
They can cause problems, but this usually only happens from opening a heavy load of dishes on the door. Occassionaly a broken spring or cable occurs. You will need to remove the toe kick and maybe the front panel to inspect.
Drain:
This is usually caused by a syphon effect or your drain line improperly installed. You can not attach your drain line from the dishwasher without having a loop in it. If you go directly under the floor with your drain hose, all water will drain out upon fill. Safest and recommended installation of drain hose is to your kitchen sink and attach the hose somewhere so it is higher then the bottom of your sinks.
be65763a-411f-4910-88d8-4712ce0a8d7e.gifda9b96d7-ebd5-4e03-8f4c-4d0c49063e70.gifGod bless you, Use the VOM very important
Apr 05, 2013 | Kenwood Dishwashers
Water from vent
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Dec 30, 2012 | Kenmore Elite 45986 Front Load Washer
GE front loading washer only leaks during stain wash cycle
Check for tips on the link below to identify parts and removal:
Sep 03, 2012 | GE Energy Star WCVH6260F Front Load Washer
My whirlpool duet sport is leaking from the front underneath. Not from the door. When the wash cycle starts it starts spraying water out the bottom. Does not do it when it drains.
Oct 11, 2011 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
My Frigidaire Gallery front load washer is leaking water from underneath. Ideas?
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Sep 03, 2011 | Frigidaire GLTF1240A Front Load Washer
Our washing machine is leaking at the front. What are the most likely causes please, and how can I fix it. It is a Hotpoint Aquarius Extra WMA36 1300 spin. Thank you
It is so common that water leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked from the front then the door gasket can be fault and needs to be replaced
please check this link:
http://www.espares.co.uk/advice/washing-machines/a/7/1397/how-to-replace-the-door-seal-on-a-washing-mac.html
If there is leak at the bottom as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Sep 01, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
I have a kenmore front load washer model number 4174104200 and water is leaking onto floor.
Can you describe WHERE the leak may be coming from? If the leak is coming from the front area of the washer, it may be the door bellow (rubber gasket), or the drain pump. You will need to open the door and pull back the folds in the rubber gasket and inspect for cracks or tears in the rubber. To inspect the pump, you need to remove the bottom panel under the door and look for any leaks inside the unit. The drain pump is in the front, directly under the wash tub. Also check all hose connections. If the washer is leaking from the rear area, check the fill hoses and drain hoses for cracks or holes. Make sure all hose connections are tight. The fill valve is another possiblity too. You will need to remove the top panel to view the valve to ensure it is not dripping. Please verify your symptoms and let me know. I hope this helps.
May 01, 2009 | Washing Machines
Pitco Frialator SG14 Deep Fryer Logo
157 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paulcarew
starztruck4u
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
