Question about Pitco Frialator Kitchen Appliances - Others
Drain valve leaking - Pitco Frialator Kitchen Appliances - Others
    New Friend:
  • 3 Answers
Drain valve leaking, valve ball dripping, i need to change the all drain valve
Posted on Jul 21, 2013
Drain valve leaks air -- no pressure in tank
Replace drain valve, its a 5.99$ at your local home depot, or hardware store. Cheers
Jul 26, 2013 | Porter Cable C2002 150 Psi 6 Gal...
Big leak
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Jan 18, 2013 | Washing Machines
Drain valve plastic slow leak 81V-80D
If the drip is coming out of drain valve: Put a hose cap over end of drain valve.
If water is seeping out of cracked drain vale, then replace it.
If the leak is seeping around previously sealed threads, then tank may be rusted beyond repair.
http://waterheatertimer.org/How-to-replace-water-heater-drain-valve.html
http://waterheatertimer.org/Leaking-water-heater.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 06, 2012 | RHEEM 30 GAL ELEC TALL Water Heater 6YR SC...
Water leak on floor of Kitchen Aid built in refrigerator.(KSS48QDX04) Pulled bottom panel but cannot see water valve. Probably needs replacing, but how do I access it? (water leak stopped when water supply...
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Check for tips on the link below to identify parts and removal:
Aug 22, 2011 | KitchenAid Refrigerators
WATER LEAKES OUT VENT HOLE AFTER CYCLE HAS COMPLETED
Jul 08, 2011 | Washing Machines
Iwdc6125 wont drain, how do i clear the drainage duct
It is so common that the drain blocks/leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important.
After cleaning of the drain duct/hose the washer must be placed with a slight tilt to the drain side to allow full drain of residual water.
If the drain valve is not working check voltage when the program to drain comes on, if not the controller also must be checked.
Jun 25, 2011 | Washing Machines
Water leaks when machine is filling, it is fine when spinning
May 09, 2011 | Hotpoint Washing Machines
We have a leak from the drain valve. Can we fix the valve with packing or gascket or is it better to replace the valve ?
If it is plastic I would change it out and replace it with a brass drain valve. Some may call it a boiler drain valve. Depending on condition of the valve you currently have will determine if it is repairable.
You have to drain it down to repair and it would just be as easy to replace it since you drained it.
Most hardware stores should carry this valve
Below is a link with some information about upgrading the drain on the heater to avoid problems.
http://ezinearticles.com/?Avoid-Leaks-At-The-Bottom-Of-Your-Water-Heater:-Upgrade-Your-Drain-Valve&id=267639
Jun 18, 2010 | Rheem 81VP6S/430126 Water Heater
Water Heater drain leaks and has caused rusting on tank
If you're sure it's the DRAIN, just get a garden hose cap for it (your other option is to replace the valve - drain tank, replace valve, refill).
NEVER CAP THE RELIEF VALVE DRAIN!
Sep 18, 2009 | Fasco Bradford White Hot Water Heater...
Kitchen Appliances - Others Logo
120 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
ray gallant
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
