Question about Pool & Spa
Intex sf15110 filter motor will not reset fromreset on cord. does the motor have a reset
Had a bad storm last night so assume motor shut off due to overheating as skimmer basket was full of leaves. It was off when I checked it this a.m. Left it plenty of time to cool. When I tried the reset on the cord nothing happens. Confirmed that outlet is working. The reset button does not feel as though it is clicking into position? What can I try and does the motor itself have a reset? The filter, Krystal Clear Sand filter 14" model SF15110, is new this season and is about a month old and was working fine yesterday.
  • 372 Answers
It sounds like your GFCI was knocked out. You can put a new plug on the end if you are sure to get the Common, Line, and Ground wires lined up correctly. A trip to a good hardware store should do the trick. If they don't have GFCI plugs then make sure that the receptacle is GFCI protected. (Ground Fault Circuit Interrupter).
Posted on Jul 21, 2013
4 Suggested Answers
Coastsider
  • 331 Answers
SOURCE: Pump and skimmer instructions on how to
Direction of flow is FROM the skimmer to the pump and back to the jet. Its easy enough to determine which hose is the "jet" hose and which is the suction hose. Put both into the water, or in a bucket and turn on the pump, find the one that is shooting out water, that's the jet hose. On these systems, filter replacement and cleaning is annoyingly frequent if you want it to work even remotely efficient.
Posted on Apr 14, 2010
jharwell668
  • 640 Answers
SOURCE: manuel neede for a intex
Below is a copy of the users manual for the krystal clear 635. It should have everything in that you need to set up your pool filter.
http://www.pooltoysource.com/images/pdf/RVR006.pdf
Posted on Apr 05, 2011
Geekman
  • 32281 Answers
SOURCE: can i use a sand filter with the intex krystal clear saltwater system?
Yes you can.
The saltwater chlorinator is connect to the outlet water pipe from the sand filter before the water returns to the pool.
Depending upon the model of the saltwater chlorinator It may need to be mounted horizontally or vertically, check with the installation instructions..
Posted on Apr 12, 2012
Why won't the breaker on the power cord of my intex krystal clear saltwater system reset?
Defective breaker or shorting pump. Disconnect the appliance from the cord. Does it reset? yes means your appliance is bad. No means that the breaker is bad. A cord with a breaker is not the way to safely operate the pump. You should use a ground fault protected outlet or a cord with a GFCI built in. Either way if the safety device continues to trip, you have a problem with appliance.
Aug 03, 2014 | Intex Krystal Clear Saltwater System Pool...
Will the impeller on the intex model sf15110 fit the intex model cs8111
Don't think so, take them apart and you will find out. Be sure to have a replacement shaft seal.
Jun 08, 2014 | AO Smith 1.5 hp 3450rpm 56J Frame 115/230...
How do you wire electrical line into filter?
Does the filter not have a power cord coming from the motor housing?
Jun 04, 2014 | Intex Krystal Clear 1600 GPH Model SF15110...
I have a Intex Sand Filter Pump SF15110. Can I upgrade the from the 1/2 hP to 1 HP motor
I have the same problem and put a 1HP pump on my system and too much flow. So you can not increase by that much. Need to stay at 1/2 HP and they are impossible to find. End up buying whole new intex system.
May 24, 2014 | Intex Krystal Clear 1600 GPH Model SF15110...
Pool & Spa Logo
230 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
