Question about Amana APO8JR 8,000 BTU Portable Air Conditioner"
Installation Question Instructions refer to two flexible hoses; there is one hose with the unit, and just one port on the unit. There are two adapters, instructions say put one on each hose. Hose came with one adapter already in place. Am I supposed to put the other adapter on the other end of the hose?
2 Suggested Answers
  • 15 Answers
SOURCE: dishwasher finished cycle, but still full of water
take some drainig liquid and let it sit in there over nite if that does not work take out the drain and take out the old grub manualy (i think what u want to put in the dishwasher is vinagear or draino something
Posted on Jan 17, 2009
Spot bot is blowing not sucking
This problem may be the same as I am having. The SpotBot recirculates the vacuum air back into the brush area when it is using the circular brushes. There is a short flexible hose deep inside the unit that connects from the clear plastic nozzles in the round brush unit to the end of the clear vacuum hose outside. Mine had a large tear in that flexible hose. This causes air to enter the hose and reduces the vacuum action, like cutting a hole in the side of your regular vacuum hose. The bad part is that I have not been able to find a replacement hose. It also takes a bit of repair experience to even get inside to where this hose is. Given the number of references to this type of issue, it appears that Bissell has a design flaw that causes the hose to break prematurely. Any response Bissell?
Jul 06, 2014 | Bissell SpotBot Robotic Wet/Dry Vacuum
I want to remove content control
REMOVAL
A/C Compressor Mounting
1. Discharge the refrigerant. Refer to MTC-111, "HFC-134a (R-134a) Service Procedure" .
2. Remove the front right wheel and tire assembly. Refer to WT-6, "
Rotation" .
3. Remove the engine under cover and the splash shield using power tool.
4. Remove the engine air cleaner and air ducts. Refer to EM-14, "
Removal and Installation" .
5. Remove the drive belt. Refer to EM-12, "
6. Disconnect the compressor electrical connector.
7. Disconnect the high-pressure flexible hose and low-pressure flexible hose from the compressor.
Jun 13, 2014 | Computers & Internet
How to locate AC condenser bolts and brackets
REMOVAL
Rotation" .
Jun 13, 2014 | 2004 Nissan Titan
Installation diagram
240 volt electric cord, and a flexible usually 4 inch, exhaust hose.
Install cord to drier.
Install flexible hose to driver using the clamps provided.
Install plug into the 50amp drier outlet.
Install the other end of the exhaust hose to the vent going outside.
Carefully move the drier back into position almost against the wall without crushing the vent hose..
May 07, 2014 | Dryers
Can't fit flexible hose onto dryer vent
An oval dryer hose can be installed by squeezing it back into the desired round shape as you fit it to the outlet. With time and infinite patience it can be done.
Feb 11, 2014 | Dryers
What is the drain size to run in copper for Zenith ZD300 dehumidifier. The inspector will not let us use a garden hose for drain as per you instructions. Fire hazard, we have to run a copper drain. What...
Fire Hazard? How can a rubber hose that drains water, be a fire hazard? This inspector is jerking you around. Since there are no copper fitting that will fit the connector, use a flexible stainless steel water water supply hose, that's normally used on an automatic washer. You'll wind up with 2 female ends, but that won't matter. Be sure there is a rubber washer in the end you connect to the unit's hose connection and only tighten it enough that it won't leak. If you over tighten it, it will crack or brake the plastic male connector.
Just for my own information, why is a building inspector necessary for the installation and approval of a portable dehumidifier? You can respond bu clicking on the Comment link. Thanks
Sep 19, 2011 | Whirlpool Dehumidifiers
How do i make it continue to run with no bucket so it does not fill and and so i don't have to empty it
Attach a length of garden hose no longer than 5 feet, to the threaded drain hose connection that was supplied with your unit, to carry water to the drain.
1. Remove the drain-hole cover on the back left side of your unit.
2. Connect a garden hose to the threaded drain hose connector.
3. Push hose connector tightly to the drain-hole on Rear Grille with the arrow on the tab pointing UP.
The hose attachment will accept a standard garden hose fitting.
Do not over tighten the hose when connecting it to the hose connector,
use a rubber washer and tighten by hand firmly without stripping the
plastic threads.
When being attached to hose connector drain hose connection,
do not bend or kink the hose. The hose should lie flat from the
dehumidifier to the drain.
Jul 04, 2011 | LG LHD45EL Dehumidifier
Replacing my rear brake pads & discs
  1. Disconnect flexible hose. Remove the union bolt and gasket from the caliper, then disconnect the flexible hose from the caliper. Use a container to catch brake fluid as it drains out. Torque: 30 Nm (22 ft. lbs.) HINT: At the time of installation, please refer to the following item. Install the flexible hose lock securely in the lock hole in the caliper.
  2. Remove caliper.
    1. Hold the sliding pin and loosen the 2 installation bolts. Torque: 26 Nm (20 ft. lbs.)
    2. Remove the 2 installation bolts.
    3. Remove the caliper from the torque plate.
  1. Remove 2 brake pads with anti-squeal shims.
  2. Remove 4 pad support plates.
INSTALLATION
Installation is in the reverse order of removal.
  1. After installation, fill brake reservoir with brake fluid and bleed brake system.
  2. Check for leaks.
Jan 13, 2009 | 1997 Toyota Land Cruiser
How do i take off the disc brakes on my 2001 toyota celica?
These instructions came from Auto Zone's website and their free, online repair guides. Just plug in your make, model and year and you can get exact instructions and pictures for your repair. Sweeeeeeet! Good Luck!
  1. Loosen the wheel lug nuts slightly.
  2. Raise and support the vehicle safely.
  3. Remove the wheels.
  4. Disconnect the brake hose from the caliper. Plug the end of the hose to prevent loss of fluid. Some brake lines have a union bolt and gasket type line attached to the caliper. Do NOT lose the washers.
0900c152801a856d.jpgRemove the brake hose union bolt with gaskets from the caliperHave a container handy to catch brake fluid from the disconnected lines.
  1. Hold the sliding pin and remove the bolts that attach the caliper to the torque plate.
0900c152801a856e.jpgRemove the two bolts that attach the caliper to the backing plate
  1. With two hands, lift up and remove the caliper assembly.
To install:
  1. Grease the caliper pins and bolts with Lithium grease or equivalent. Temporarily install the caliper on the torque plate with the installation bolts.
0900c152801a856f.jpgThe sliding pins should be greased with Lithium-based grease before installation
  1. Hold the sliding pin and tighten the installation bolts to 25 ft. lbs. (34 Nm) on the front wheels, and 14 ft. lbs. (20 Nm) in the rear.
  2. Attach the flexible brake hose to the caliper with new gaskets. Tighten the hose to 22 ft. lbs. (30 Nm).
Install the brake hose lock securely in the lock hole, in the caliper.
  1. Fill and bleed the system.
  2. Install the wheel, lower the vehicle and tighten the lug nuts.
  3. Before moving the vehicle, make sure to pump the brake pedal to seat the pads against the rotors.
  4. Check for leaks.
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Remove the wheels.
  3. Disconnect the brake hose from the caliper.
  4. Remove the bolts that attach the caliper to the torque plate. If applicable, hold the flats of the sliding pin with a wrench while loosening the caliper attaching bolts.
  5. Lift up and remove the caliper assembly.
To install:
  1. Install the caliper and loosely install the bolts.
  2. Hold the flats of the sliding pin with a wrench, then tighten the bolts. Tighten to 25 ft. lbs. (34 Nm) except on Celica rear calipers. Tighten the bolts on Celica rear calipers to 34 ft. lbs. (47 Nm).
  3. Connect the brake hose to the caliper, using 2 new washers.
  4. Fill the brake system to the proper level and bleed the brake system.
  5. Add brake fluid to the reservoir to fill to the correct level.
  6. Lower the vehicle to the ground.
Jul 17, 2008 | Toyota Celica Cars & Trucks
Installation
This is apparently a new product, and not having provided me with a model number, I was only able to ascertain that this is a dual hose model? If so, then I would assume that since there is no direct correlation between 1 hose and the other, that it probably doesn't matter, since both hoses are utilized for proper operation. Click the link below for more information.
http://www.rainbowappliance.com/Air-Conditioners-1/Danby-DPAC90061-9000BTU-115V-PORT-AC-DANBY-3340.html?utm_medium=shoppingengine&utm_source=yahooshopping&cvsfa=673&cvsfe=3&cvsfp=DPAC90061
Jun 03, 2008 | Danby 7,000 BTU Portable Air Conditioner -...
Amana APO8JR 8,000 BTU Portable Air Conditioner" Logo
15 people viewed this question
Top Amana Dishwashers Experts
Cleverer2
Charles T Nevin
Charles T Nevin
Mike
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
