Pioneer SA-1050 will no longer power up
Found a Pioneer SA-1050, visually it looked in great shape. They told me it, "ran like a champ". Got it home, plugged it into my turntable and two speakers, powered it up, but no sound. Starting trying out different settings. There are two Speaker buttons on this amp, an On and Off for A and B, which were on. Clicked on Off for both, got a blast of sound, then the amp powered down. Now there is nothing, dead, no lights, nothing. Opened the case, no burns from what I can see, no smell of smoke. Looks clean inside. Any ideas?
  • Audio Player... Master
  • 5,487 Answers
I would check the internal fuse(s) in the power supply. If they have blown replace them. If they blow again suspect a shorted power output device on the heatsink.
It's best to look at the soldering on the PC board, especially on second hand devices. This will show you if it has been repaired. If the soldering doesn't look like new, someone has been messing with it. They could have done anything to it, including fitting wrong parts, or fitting the right parts but not doing it right.
Posted on Jul 24, 2013
  • 31 Answers
SOURCE: Sherwood AI5010 no sound from either channel
Hi There DEKCAT
Its very unusual for both channels to blow......
I suspect that there is a blown power fuse inside the case......
There are fuses sometime located on the outside rear of the case and these can be easily checked to determine if they are blown..If you find one is blown please replace with the corrrect rated fuse,..... its current rating wil be on a small label on the case outside rear. like 1.0amp, or 1.5amp etc...
If you need to go inside the case please ensure the power plug is removed from the wall socket first.
You will find small glass fuses in the DC power supply feeds and probably one of these has blown, once again replace with the correct rated fuse.
Im not sure if your amplifier is a FET type or a large 32-40 pin IC type as if these are blown you will need a service person to do the replacement...
Please note there is a small relay that clicks 20seconds after turn on at the switch....if this click is not happening then there is problems with the timer circuit or the relay itself...
This relay controls the output to the speakers and as such stops all the sound output if its not working...so the first thing is to check all fuses, if they are OK then check the Relay operations....
Cheers From YUBEUT
Posted on Nov 16, 2007
robotek
  • 1512 Answers
SOURCE: Peavey KB 300 amp problems
Hi there.
You have have been unfortunate enough to experience an uncommon failure. The bass driver has failed. It is a Black Widow that can have the basket/cone/voice coil assembly replaced as a complete unit. The magnet unbolts from the basket and you bolt on a new one. Classic field service designed product. You will be able to get a new basket from a Peavey equipment stockist. Just ask for a 15' Black Widow replacement basket They cost about $180 here in Australia and you can easily change it yourself. Good Luck and happy jamming.
A FixYa rating would be great for my tech tip to you. Cheers
regards
Graeme
Posted on Mar 08, 2008
  • 8 Answers
SOURCE: TECHNICS SUPER BASS, DOUBLE BASS AND TRIPLE AMPLIFIER
Have you checked all circuit boards for good solder connections.
Also if the boards had been wet from anything, you might clean the boards and resolder all connections specially in the power supply and audio section.
Let me know.
Posted on Mar 06, 2009
lesliemurphy
  • 69 Answers
SOURCE: I have a Pioneer SA 1050. All the lights come on
check your speaker selector switch to see if its on the correct setting ie; speakers one ( not speakers 2 ) also check your speaker cables by reversing them, ie; put right speaker cable into left channel and vice versa with the left etc? check also to see if your amp is set to headphone output by mistake in which case no sound will come out until you select the speakers instead? good luck.
Posted on Sep 14, 2009
SOURCE: NAD 304 AMP...No Sound at all on both channels, Black marks on inner case.
i need a power amp. brand that has a 4ohms impedance that who will match my 307d2 4 ohms (pioneer) sub woofer that can use inside my house
Posted on Jan 13, 2010
How do I fix my problem I m having with my pioneer sa-1510 amplifier
You simply have a bad solder joint somewhere. A visual examination of the solder joints should show you the problem.
Mar 03, 2016 | Pioneer Audio Players & Recorders
Pioneer SA-5300 watts?
This ad claims 120 watts without any performance qualifications.
http://www.classic-hifi.net/product.php?id=74
Look at the back and see how much power it CONSUMES. Then back into something realistic, say, 40% of that divided between the two channels. Nothing produces audio wattage anywhere near the amount of raw power that it consumes. Heat eats up a lot of the power.
This set of pictures shows 85 watts power consumption.
http://urun.gittigidiyor.com/PIONEER-SA-5300-VINTAGE_W0QQidZZ29607046#aciklama
May 14, 2011 | Pioneer Audio Players & Recorders
My parents are getting rid of their Panasonic SC-HT700. The receiver is shot. The speakers and sub work perfectly fine. I was wondering if I could purchase a used receiver (found the SC-HT930 on ebay) to...
the speakers are 6 ohms, and it will be very difficult to find a receiver that is 6 ohm compatible. most home amps are 8 ohm, and will overheat and burn up when used with 6 ohm speakers.
the subowoofer is 4 ohms, but i am unsure as to whether it is self-powered, or if it is powered by the receiver.
4 ohms is the standard for car audio, and 8 ohms for home audio.
Oct 27, 2010 | Panasonic sa-ht930 Home Theater Audio...
Pioneer sa-1050 2 burnt resistors, cannot read
where exactly are these resistors located? any idea about the circuit board resistor numbers? sometimes burnt resistors do not go completely bad and is still possible to measure their values. why not take them out and try measuring their values. otherwise u have to b very specific about the rsistor numbers
Apr 05, 2010 | Audio Players & Recorders
Jun 24, 2009 | Pioneer Audio Players & Recorders
I have a pioneer vsx515-k 6.1 surround receiver that I like very much, and would like to see if I can get it fixed. There was a car accident that ran into a power pole in the neighborhood and knocked out...
hello my friend usually this kind of devices protects itself in a blinck of a second and you dont see anything wrong but take a look aorund the transformer,the fuse resistor the value is about 1 ohm or less you need to know some experience how to test a transformer fuse etc....i hope be lucky. saludos
Nov 18, 2008 | Pioneer Audio Players & Recorders
Can I go off road?
I think that the new 1050 is not as convidence inspiring as the older models, but I found it very stable when on wider forest service type roads. The rims are cast, so much more easily bent. My 1050 felt great as I would stand on the pegs and use my body more. Would slide it out to the side a few times, intentially, and did not feel out of control either.
Nov 10, 2008 | 2008 Triumph Tiger
Pioneer amph sa 9500 II
Hi yalazogeday
Your amp is fitted with two 2SD588A (NPN) and two 2SB618A (PNP) power transistors in the output stages. Click on the part for a place to get them from. These parts are no longer available from Pioneer, nor are the prescribed replacements. (the amp was built in 1978) Because of the unusual transistor package used, you may have to upgrade to a more modern transistor, and modify the mounting also.
robotek
May 24, 2008 | Audio Players & Recorders
PDP-4330HD
This exact same problem happened to me 2 weeks ago on my Pioneer PDP-4330HD, and it did indeed turn out to be the power supply. The good news is, you can get it fixed for free, because Pioneer actually recalled the power supply in this plasma and others a couple of years ago.
Here is a link to the announcement on their website concerning the recall. They say that they will do a free in home replacement of your power supply, but when I called the local pioneer repair place, I was told I would have to wait three weeks for an in-home appointment. I ended up taking it in myself, and it was fixed for free 2 days later. Now it works perfectly.
Here's the number to call Pioneer in case the link goes down:
1-800-421-1404
Nov 10, 2005 | Pioneer PureVision PDP-4330HD 43 in....
 Grubhead
Grubhead
