Question about Sea-Doo US 2011 GTI SE 130
High exhaust temperture warnong
2011 started today in driveway ran for few then high exhaust temp warning any ideas
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 118 Answers
You can't run those for for than 30 seconds because your not injecting any water thru the exhaust.
Posted on Oct 23, 2013
While driving down the road in my 2003 pontiac montana. The change oil light comes on and high temp warning light comes on. When the high temp light comes on the van losses all power.
Check the coolant first. Add as needed. Once full. heat it up in the driveway and check for leaks. 3.4 montana, I would guess the water pump. Change the T stat also.
Aug 09, 2015 | Pontiac Cars & Trucks
I'm having strange problems with my 2008 Chevy HHR LT - no dashboard warning lights come on and the installation of a new throttle body did not solve the problem (see details below).
sounds your variable valve timing solenoids are going out there easy to replace their on the top passenger side of engine you do have to remove the air filter resonator tube to see them, replace the intake and exhaust solenoid at the same time
Mar 08, 2015 | 2008 Chevrolet Chevrolet HHR LT
I replace a themostate couple weeks ago.then I replace water pump .few weeks ago.today. replace radiator. Ran good no problem.got off work note .crank car up .temp hand didn't move .then when I got to...
it sounds like thermostat got wedged open with trash and then mabe got stuck closed with trash. need to flush entire system with thermostat removed from system.
Aug 21, 2014 | Cars & Trucks
2004 silverado 5.3. It started a few times today fine (-35 c temp) but it seemed like it wasn't getting enough fuel. I put in a can of sea foam but that didn't seem to help. When I came home tonight, the...
have you change your fuel I have heard if you use a higher octane then go back to stranded that this problem will or can occur I suggest 95 octane 98 is as high as u want to go also make sure there is no air leaks
Dec 29, 2013 | Cars & Trucks
Idle is high at start - 1800 rpm. Seems like excessive white smoke from exhaust. Put into reverse and back out of driveway it has a regular shudder (bump bump bump) but not hard metal grinding sound.....
white smoke out of the exhaust would be a sign that it is burning coolant... if it goes away after it warms up, it could just be condensation inside the exhaust pipe. 1800 rpm is a very high idle, maybe have your IAC motor on the throttle body checked... check engine light? if so have the code read at your local auto zone.
Aug 09, 2011 | 1998 Toyota 4Runner
2002 TBird...very quickly temp guage rose to high and car felt like losing power...I stopped the car, turned off motor...after few minutes, started car again and it ran like there was never a...
NOT A SOLUTION, BUT TO LET YOU KNOW MINE IS DOING THE SAME THING! RUNS GREAT AFTER I START IT BACK UP. I DO SEEM TO BE HEARING A NOISE AT THE TIME THE ENGINE IS DOING THIS. NOT SURE WHAT TO DO??? DID YOU FIND OUT ANYTHING?
Jun 01, 2011 | 2002 Ford Thunderbird
Grand am running hot ----2004 se1 3.4l---changed water pump---radiator---thermostat---cooling temp censor
I would check to see if the radiator fan is coming on when the engine starts getting warm.
May 08, 2010 | 2004 Pontiac Grand Am
2004 titan engine shuts off without warning. usually restarts ok but sometmes won't start until you wait 5 or 10 min. At First I thought it ran out of gas, but guage showed 1/4 tank double checked this by...
Did some research for you on this problem. Go to this Titan forum link I am sending you.....First post sounds a lot like your problem. I'll still look around and make some calls....
http://www.nissantitan.info/forum_posts.asp?TID=2726&PN=1
Nov 27, 2009 | 2004 Nissan Titan
A red warning light on in the dash but do not know what it is for, it looks like a box with pipes entering it from both sides and lines radiating up from it. what is this light for please?
you may have high exhaust tempertures,that simbol sounds like the exhaust temp. light, you may beover fueling or have a faulty exhaust temp sensor
Nov 05, 2009 | 1990 Toyota Corolla
Sea-Doo US 2011 GTI SE 130 Logo
376 people viewed this question
Top Sea-Doo US Boating Experts
Richard Lilja
Richard Lilja
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Sea-Doo US Boating Expert? Answer questions, earn points and help others
