Washing machine wont turn on
Just finished replacing washing machine hub drive assy bearing,tube seal,and spin bearing. washer side will not power up. lid switch operates normally. I cannot hear any timing clicks coming from the timer. any sugestions
  • gospelstuff Nov 09, 2014
    I would first check the water pressure switch in the panel it has a small tube going into it. and if the diaphram is defective it will not allow or send the signal to go into wash cycle all u may get is clicks or nothing
    Top Expert:
  • Washing Mach... Master
  • 12,223 Answers
See this instructions and fix it. God bless you
User Control and Display Board
If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Enter your model number to see parts for your washing machine.
Help me find my model number
Timer
If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse
If the washer won't start the line fuse might have blown.
Thermal Fuse
If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder
If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board
If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly
If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly
If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem
If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord
If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Posted on Jul 21, 2013
  • 3 Answers
SOURCE: fisher paykal top load washing machine
I had the same problem. I unplugged the machine for a while (overnight) and it then worked properly when I plugged it back in. Probably just a circuit board issue that was cleared with the power removed.
Posted on Oct 14, 2007
farfield
  • 462 Answers
SOURCE: maytag top load washer won't pump water out=intermittent problem
If your lid switch was the problem I dont think (and I might be wrong) that it would spin in the first place.
Your pump may have a separate belt and it could be loose or worn out but this is on older models. The pump may not be turning or turning and not pumping. The pulley may be turning on the shaft and its not pumping. Give it a spin and see if you see it turning inside. If not replace it.
The motor and timmer sounds good because of the "spin" you discribed. So we are left with the pump or a filter if it has one.
Look in the lower section find the pump front right hand corner I believe. Trace the hose back up to the tub above nothing in between and you have eliminated the filter. I filter could be any shape but will either attach with 2 hoses or 1 hose and attached to the side or bottom of the outer tub.
I think your pump is probably stopped up, strings and lint especially if you have some older rugs, towels, and rags that are shedding or coming apart. You can try and clean it pretty easily Unplug. Then remove it and look inside it. Catch all the water you can and keep another towel close by. Examine the water. Looking for lint and the like. If its pretty clean looking and not turning freely look for signs of something wrapped up inside it.
Hope this helps. Please rate me accordingly and good luck.
Posted on Mar 10, 2009
  • 240 Answers
SOURCE: No Spin No Drain
Lid switch is most likely the problem, if lid switch is visible under lid on right side then this is older design and common problem switch.
if you have console frame covers on front sides, snap off from top, a screw is at bottom front corners of console, remove and pull console forward and fold back. If lid swich is hidden then you will see it at left on top of cabinet with console folded back. a 5/16 screw holds a green ground wire to cab. remove and switch will unclip with lid up. If lid switch was visible under lid then you need to remove 2 brass clips holding cabinet on top of base to back, pry with screwdriver to unclip. undo harness connection on cabinet top, this is your lid switch connection. sw body is held by 2 phillips screws, harness tube held by clips on underside of cabinet top. ground wire with 5/16 screw present at sw body. New versions of this switch have metel shield attached.
Posted on Apr 26, 2009
TheMobilian
  • 8220 Answers
SOURCE: Kenmore 90 tub spins excessively clockwise during wash cycle.
Improperly installed thrust bearing kit. Too many washers cause the basket to spin during agitation.
Posted on Jan 04, 2010
Testimonial: "Where is the "thrust bearing kit" and how can it be installed properly?"
SOURCE: KleenMaid Washing Machine shop manuals/repair instructions
There are manuals available but these only tell you about the parts of the machine and the different cycles etc. Its a workshop manual that you need and these are not discussed anywhere on the net, Im not sure these were ever produced.
Posted on Sep 12, 2010
Maytag washer roaring noise on spin
This may be the bearings and seals in the tub assy. This is quite common in the earlier Neptune machines . This is not a difficult job.....see you tube on replacement procedure
Jan 24, 2014 | Maytag Washing Machines
Automatic washer won't engage in wash cycle or spin cycle. Amana washer Manu model PALW880QAW1
Yes surely that could be one of the reason (due to over tightening) also i request you to carefully check if there is any crack on the body since it is a bit aged. Also try to apply lubricant to all the necessary joints and moving parts.
Thankyou
Apr 07, 2008 | Washing Machines
The machine doesn't spin properly and doesn't drain the water
see this causes and fix it. God bless you
Lid Switch Assembly If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Motor Coupling If the washer won't spin the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission. Another common problem is the lid switch.
Drive Belt If the washer won't spin, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin properly.
Door Lock Motor and Switch Assembly If the washer spin the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Drive Block If the washer won't spin the drive block might be worn out or may have come loose. Underneath the agitator the drive block connects the inner tub (the one that spins around) to the transmission. If the drive block wears out the transmission shaft will still spin but the tub may not - or it may spin slowly. This also usually causes a lot of noise. The drive block is relatively easy to replace.
Clutch Assembly If the washer won't spin, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Clutch Band kit If the washer won't spin, the clutch band kit might be worn out. The clutch makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. If the washer won't spin, this clutch band kit may need to be replaced.
Drive Motor If the washer won't spin the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged It will have to be replaced.
Tub Bearing If the washer won't spin the tub bearing might have seized. This is a common problem and relatively easy to replace.
Tub Seal and Bearing Kit If the washer won't spin the tub seal and bearing might have seized. This is a common problem and relatively easy to replace.
Bearing If the washer won't spin the bearing might have seized. This is not common. The bearing doesn't require any normal maintenance. They generally go bad when the tub seal fails and allows water to leak past into the bearing.
Basket Drive If the washer won't spin the basket drive clutch might be worn out. The basket drive sits on top of the transmission and engages with the inner tub. If the basket drive wears out the tub won't spin.
Basket Drive Hub Kit If the washer won't spin the basket drive hub might be worn out. The hub is a set of plastic gears underneath the agitator. The basket drive hub kit is easy to replace with standard hand tools.
Transmission If the washer won't spin the transmission might be worn out or defective. There are numerous more likely causes when a washer won't spin, which should be checked first.
Sep 28, 2012 | Hotpoint Washing Machines
What is the foot pounds for the front wheel bearings on a 1995 chrysler cirrus
Hello, If you Chrysler has replaceable wheel bearings and seal. This is the way it goes---pack the wheel bearing with new grease-install the bearing in the wheel nub--install new back wheel seal--coat the axle shaft with grease lightly, thing coat-----install wheel hub on to axle shaft...be careful here don't damage the rear hub seal------------insert front race washer---install axle shaft nut--tighten nut down wheel nut until it is firm with water pump pliers----spin the hub/with tire mounted.
(the wheel and hub will turn but not freely)----take the pliers and back off the axle nut 1/4 turn----now spin the wheel and axle hub, it should spin freely---now if doesn't spin freely---back off the axle nut about 1/16 or 1/32 (or just a little bit)-----now, spin the wheel and hub and if turn freely------------Now grab the top of the wheel/tire and move it back and forth.-----if there is some movement ---try tighten the axle nut just a little little bit, unit the one can barely feel some little movement in the wheel/tire and hub.-----------Now, spin the wheel/tire and hub and it should also turn freely.
If it does----install new and correct size of cotter pin and bent the ends around the axle nut.----
coat the inside of the hub cup with grease. Now, use an rubber or plastic hammer to install the cup on the wheel/tire hub. You are finished with one wheel bearing maintenance. Now do the other side.
I really don't know if you Chrysler Cirrus has replaceable wheel bearing. All the auto/trucks have replaceable hubs, that means that the replacement is total hub with axle shaft, sealed bearings, and seals. This is bolt to each wheel steering hub. This work to remove these one unit hubs.
Four bolts hold the axle hub to the steering hub. Hear is the problem!! it has rusted to the steering hub. Also, these hubs cost more than replacing bearings, races, seals to cool turn of $180 to $250+ I wish you luck in your replacement of wheel bearing on your Chrysler. GB..stewbison
Sep 24, 2011 | Chrysler Cirrus Cars & Trucks
Makes loud noise in spin cycle
The problem is that the seals are leaking and allowing water to attack the tub bearings.
You need new tub seals and bearings.....not as difficult as it may seem.
see u tube video on replacing maytag seals and bearings
Cheers Stan
Aug 12, 2010 | Maytag Neptune MAH6500A Front Load Washer
Machine making loud noise on spins cycle
Well, the only time the washer (speedqueen) is noisy on spin is if one or both the bearings are faulty. Normally when you get a leak, it means the hub/flange and seal kit need replacement and this also includes the top bearing because when soap suds leak past the seal assembly it drips directly onto the bearing. The acidic properties in the soap suds eats the grease in the bearing which ends up becoming defective. One can also get an anoying squeek if a bottom base gasket is worn or removed. This would be audible even on wash cycle.Conclusion, check the bearing on top of gearbox.
Jul 21, 2010 | Speed Queen AWS44NW Top Load Washer
Washing machine is really loud
It sounds as if the inner water seal has failed and allowed water to get into the bearings.. Rust on the bearings means they are no longer smooth..Hence the noise! Replacing the bearings (and possibly the shaft) is a big job. This is not an unusual problem with front lad washers. Too much detergent will shorten the life of the seal/bearings...Get quotes...Nomess
May 31, 2010 | LG WM2277H Front Load Washer
At start of spin cycle water splashes over top and runs down.
Hi, just fixed the daughters speed queen, same problem. The three brake shoes were worn allowing the tub to spin with the agitator.
replaced the shoes, washer fine. At first I thought it was the top ring. spent 30 dollars for nothing.
good luck
Mar 21, 2009 | Speed Queen AWS52NW Top Load Washer
Washing machine problem
Sounds like the upper bearing located in the outer tub seal is bad. It takes very little play at this bearing to cause what you are describing.
b739f41.gifThe area of this picture you are interested in is the top left. This is the tub seal assy.
Dec 28, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Slow to spin and making a loud noise.
Control boards don't growl, the fry out and die. Sounds like a drive train problem to me. If it's a front load machine, the spindle/bearing assy. has gone to washer heaven. If it's a top load machine... could be the transmission, brake/clutch assy. or the tub bearings. In either case, if it's less than 5 years old, the drive system will be warrantied through the manufacturer. If you could provide a make and model number, I could narrow this down to a fine point.
Dec 15, 2006 | Kenmore 43142 Front Load Washer
Washing Machines Logo
145 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
