Back up lights wont come on - Computers & Internet
  • 27,725 Answers
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
Testing & replacing the PC's power supply
http://www.youtube.com/watch?v=hbNxhvm0czs
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r
Allow the pins to dry.
They will air dry in a matter of minutes.
If reseating the memory did not resolve the issue try swapping the location of the memory.
If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
Check the memory module and memory slot contacts.
They are either copper tin or gold.
The colour will tell you which they are.
Mixing tin and gold can result in corrosion that prevents proper contact.
Look for any sign of physical damage to the memory module, memory slots or the motherboard.
Reseat the memory modules.
You should hear an audible click when they are in place.
Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard.
The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible.
Could be a problem with the Hard Drive or the Hard drives PCB
http://www.onepcbsolution.com/
http://www.youtube.com/watch?v=du0Qd_3wFWM
There is a connection problem such as a bad cable
for internal hard drives
Test all power and data leads that attach to your hard drive SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty although very rare for sata lead to fail
Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty.
or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Posted on Jul 21, 2013
It wont turn on just flashed red light and wont give the disk back
watch the lights on the front when you try to turn it on. If the blue light flashes yellow for a second, you have ahardware failure, so-called Yellow Light of Death. You can get the disc out by turning off the switch at the back, then hold down the eject button and turn the back button on again.
May 01, 2010 | Sony Playstation 3 (PS3) Console
My vaio wont turn on and the green light in the back keeps blinki
The green light blinking in the back indicates that the power supply went bad and is not turning on, go ahead and get the power supply replaced. Normally that light is supposed to be fully lit and green.
Apr 28, 2010 | Sony VAIO VGC-RB53 PC Desktop
Wont power up green light on back is on but
Most likely a failure in the internal power supply of the tower. Replacements are around $50 if not under warranty.
Oct 09, 2009 | HP Compaq Presario SR2150NX PC Desktop
The instrument panel waring lights started to blink off and on than today the anti lock light was on the trac light says its off. The air bag light is on. the speedometer needle jumped all over it wont go...
there should be a ground bar near the drivers seat sometimes located under the lower kick panel pull up the door sill push the carpet back look for corrosion here
Aug 19, 2009 | 1998 Buick Regal
Mazda astina pop up lights wont go back down
Try to check if there is something stuck to the motor of the pop-up lights mechanism. You can see it below the fenders. The fender liner should be removed.
May 27, 2009 | 1990 Mazda 323
Blackberry pearl wont stay on and red LED light keeps flashing
my phone wont stay on and when it does come back on it shuts right back off. the LED light on the front keeps flashing red. ive taken the battery out and everything and nothing seems to work. help please!
Apr 07, 2009 | RIM BlackBerry Pearl 8100
Left signal lights wont shut off all back running lights off
sounds like a turn signal switch on the column
Apr 04, 2009 | 1997 Eagle Talon
Water full light wont go out
Make sure the water dispensor is pushed back firmly as there is a switch that is operated by the dispensor. If this fails the switch may be faulty.
Post back if further assistance needed.
Thankyou for using fixya.
Nov 29, 2008 | Dryers
S80 backup light wont work
There are only 2 things to check other than the bulbs, 1st the back up lite fuse, and the 2nd the back up light switch on the trans, if the fuse is ok replace the backup light switch.
Nov 19, 2008 | 1991 Volvo 240
Computers & Internet Logo
David Payne
David Payne
