Question about Singer Quantum XL-6000 Computerized Sewing Machine
Motor I get a message that says "TUrn off, motor will not turn" and the needle stutters up and down in one place.
  • 1,271 Answers
Hi, look at the manual if you don't have one
http://c.sears.com/assets/own/02018600e.pdf
i have repaired a couple of these where the fault was the speed controller and motor driver board.. where are you located ?
Regards
Rob (uk)
www.electronicrepairs.co
Posted on Dec 29, 2013
I am trying to wind on a bobbin and keep getting an error message of E9 which says in the manual When Motor is locked it will not allow me to wind bobbin
The machine you're talking about isn't indicated. However, when the motor is locked it is trying to run the needle and feed dogs at the same time that it is trying to wind the bobbin. This cannot be done simultaneously.
*** The place where you place the bobbin must be set firmly against the bobbin.
***Some newer digital systems still need the hand wheel to be released by hand. (Turn it, push or pull it)
Sep 29, 2015 | Sewing Machines
Singer 400 will not power on
Try turning the power switch on with the embroidery unit in place, insert the foot control. Then turn the power switch off, remove the foot pedal and turn the power on again. If that doesn't work, try inserting the foot pedal with the power switch in the off position, withdrawing it, then turning the power switch on.
Your motor was designed to shut itself down if it overheats or if stitching was interrupted. For instance, if your needle hit something solid and the needle bent or broke.
Generally, it will go on again in 10 minutes to 2 hours, depending on what the cause was. Occasionally, it can take longer. Using the foot pedal tends to reset the motor. I discovered this by accident one night, when I assumed that it was a Reset port and gently stuck the eraser end of a pencil in it until I felt resistance, then withdrew it. The machine had only shut down for about 3 minutes, but it turned right on again.
Jun 29, 2015 | Singer Futura Xl-400 All-In-One Sewing And...
Sorry the needle is not going down,
Needles will not go down for:
1. The lock on the hand wheel isn't locking. Try this
a. Loosen the lock like you're going to wind a bobbin.
b. Loosen screw that is on the side of the lock. (sometimes front)
c. Tighten the lock just like when you're going to sew.
d. Tighten the screw that is on the side of the lock.(sometimes front)
e. Turn hand wheel by hand. Did the needle rise and fall?
2. The drive belt isn't moving the shaft.
a. Remove the top of the sewing machine.
b. You will most likely have to remove the panel on the end where the hand wheel is.
c. Turn your hand wheel to see if the belt is moving the shaft or is it broken?
d. Replace if you need to. (look at wear). Loosen the motor.
e. Make your motor run (foot pedal) slowly. Tighten the belt by pushing on the motor while it is running. When the motor is placed at the right place the motor will be moving with very little drag. (This will need a listening ear)
f. At this point tighten motor and retest for the speed and drag.
Mar 21, 2015 | Sewing Machines
Bernina 180 needle bar won't move up and down
This could be the needle bar clutch. Turn off machine. Unplug machine. Remove needle. Turn hand wheel in normal rotation 1/4 turn. Gently move needle bar up and down by hand you should feel a click and the needle bar will not move up and down easily now. Restart machine and test. If it works all is good. This is a result of the machine requiring professional attention. If you use basting stitches it will likely unclutch again.
Jun 15, 2014 | Bernina Sewing Machines
Empisal dressmaker 270d
Loosen your needle. Turn your handle towards you. You may have to turn a little hard. Now, throw that needle away.Take your fabric away and check the area where your bobbin goes and clean it out of fabric and thread. Now load your bobbin again and load a new needle. Pull your thread up from the bottom by turning the handle towards you while holding the needle thread with the foot down. Now look and place something under the foot and slide it forward while still holding the needle thread. The bobbin thread should come up. Let me tell you this though. Adjust the bobbin thread before you start. This is done by placing the thread in the carrier (usually unwinding counterclockwise) and place the thread under the tension spring. Hang this from your finger and bob it up and down lightly. It should fall about one inch. If it doesn't then loosen. If it falls too far then tighten.
Apr 27, 2014 | Sewing Machines
How to fix needle on a machine
Turn the hand-wheel counterclockwise until the needle is at the highest point. Lower the guide or presser foot. This will give the maximum room possible for working with the needle.
Turn the needle clamp screw counterclockwise until the needle comes loose. This screw is located on the side of the small
box, known as the needle clamp, that holds the needle in place.
Remove the old needle by pulling it straight down and then angling it outward. Place a new needle into the holding slot or needle clamp.
Tighten the new needle into place by turning the clamp screw clockwise until tight. Do not over-tighten the needle.
Here's a tip
Use a needle that is appropriate for the type of fabric you are sewing. Using the wrong needle may result in breakage and increase the number of needles to be changed
Over-tightening a needle can cause it to be crooked and break. Turn the clamp screw only until the needle feels stiff in place.
here's a link for a manual for the machine
http://www.sewingpartsonline.com/instruction-manual-euro-pro-9110.aspx
Aug 23, 2012 | Euro-Pro Shark 9110 Sewing Machine
Fixing a new needle on a sewing machine
Here's a tip
When you press the pad, the needle did not up and down. but the motor is running.
Your machine is in 'bobbin fill mode' - the needle mechanism is deactivated for safety when using the machine to fill a bobbin.
Turn the centre section of the handwheel on the right hand end of the machine clockwise whilst holding the outer section in place. You should feel it tighten. When it is fully tightened, both the centre and outer sections should rotate together when either the pedal is pressed or the wheel is turned by hand. The needle will be going up and down again now.
Hope that helps!
Oct 25, 2009 | Brother LS-2125 Mechanical Sewing Machine
Error 1 message will not leave
Hi - first, check your manual to see if the error is described somewhere. Follow the instructions. If the manual tells you to take the machine in for repair, try a couple things first.
Often when your needle starts to shudder, the thread is caught on something somewhere along the sewing path. Turn off your machine, change your needle, take all of the thread out of the machine and rethread it. Then remove your bobbin to make sure that there is nothing stuck in the bobbin case, or in the area where you insert your bobbin into the machine. Look around the sewing area to see if something looks out of place.
After you insert a new needle and rethreaded your machine, and before you turn the machine back one, try using the wheel to make a few stitches manually. Watch your sewing thread to make sure it is feeding evenly. If the needle does not move up and down correctly, or if you hear a grinding or bumping sound, you probably need to take the machine to be repaired. Otherwise, turn your machine back on. If the error message is gone, try sewing slowly for several inches - if all seems well, increase the speed a little at a time. If anything seems off to you while you sew - stop sewing immediately and look very carefully to see if you can find a problem.
Dec 20, 2008 | Kenmore 19365 Computerized Sewing Machine
1968 kenmore sewing machine
belts and oil it in any point that has metal to metal
Oct 02, 2017 | Sewing Machines
Singer Quantum XL-6000 Computerized Sewing Machine Logo
44 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
