Question about Dishwashers
8-year old kitchinaid dishwasher no power to touch panel
I have opened the door to expose electronics. Switch has approximately 84.x volts. Touchscreen has no power to any of the buttons. Model #: KUD102CRBS2
  • Dennis Jul 23, 2013
    After further investigation, I have found that it is, most likely, the control panel and touch pad. I have one enroute. If that does not fix it, I have to begin replacing the control cards, of which there are two.
  • 1462 Answers
SOURCE: Creda plan Integrated Dishwasher fault
door latch is in wrong position, split the door so you can see whats what and change the position of the switch
Posted on May 18, 2007
SOURCE: Miele G646 dishwasher. This dishwasher
Yes solved by pulling door apart. There is a small drain tube from the bottom of the ventilation vent, which had some blockage.
Cleared it put door back together and now works just like new.
Cheers
Nic
Posted on May 25, 2008
SOURCE: My kenmore built in dishwasher is leaking out the front
my kenmore dishwasher is leaking in the front, it is 8 years old...any ideas?
Posted on Nov 30, 2008
  • 338 Answers
SOURCE: Maytag dishwasher model #MDB6650AWW no lights on
if the door switch has power and you cant get the dishwasher to do anything then you will need a new control.. ..
Posted on Feb 20, 2009
SOURCE: Kenmore Elite dishwasher model 665 touchpad buttons falling off
WE HAVE THE SAME PROBLEM. DID YOU FIND A FIX FOR YOURS?
Posted on Mar 27, 2010
Whirlpool adp 6515ix dishwasher start button is flashing in 4 time cycles-what does this tell me please. None of the manuals indicate what the flashing could be signalling.
Error CodeConditionCheck/RepairShop PartsClean light blinks 7 timesHeater circuit failure. Control didn't detect the expected rise in water temperature.Check the heating element and related components (wiring and control board) in that circuit.
Heating element, Electronic control board, Thermistor, Circuit wiring
Console light blinks rapidlyThe control detects a stuck button on the control panel.A failed control panel or a malfunctioning electronic control board can cause this code. Check the buttons on the control panel using a volt/ohm meter. In most cases, the control panel must be replaced. If that doesn't solve the problem, the electronic control board might be at fault.
Control panel, Electronic control board
Start/Resume light blinks slowlyIf the dishwasher door is opened or power is interrupted during the cycle, the dishwasher won't start again until the door is detected as closed and the Start/Resume button is pressed.Check the door latch and switch assembly. A failure in the Start/Resume button also can cause this problem.
Door switch assembly, Control panel, Electronic control board
Clean light stays onThe dishwasher won't start a new cycle unless it detects that the door opened after the previous cycle.Turn off power to the dishwasher by shutting off the breaker and restarting. If that does not work, the door switch assembly is stuck and must be replaced.
Control lock LED is on but not accepting key pressesAccidentally turned on or control detected keypad problem.Press the Heated Dry key for 5 seconds to turn off control lock feature. If that doesn't work, replace keypad.
Keypad
Sanitized LED blinks at end of cycleControl couldn't confirm that the dishes were sanitized.Check voltage to the dishwasher and the temperature of incoming water. Check the diverter motor, the heater and the OWI/thermistor.
Diverter motor, Heater, Thermistor
May 23, 2015 | Whirlpool Dishwashers
Bosch dishwasher trips power supply when door fully opened after cycle completes
The dishwasher will have a wiring harness which passes through one of the corners or in the centre of the door. I would suggest that the harness has perished or weakened and exposed a live wire which touches the cabinet when the door is opened and it shorts out. Opening and closing the door after many years of use weakens the wires where they get continually bent back and forth during door opening and closing. Ive seen wires rejoined but the only sure fix is the replace the wiring harness.
Feb 23, 2015 | Bosch Dishwashers
No lights - Acts Like It Has No Power At All
see the diagram and pictorial and proceed with common sense:
1) test the fuse for open or band contact with VOM,see the diagram attached how to do it
2)check the switch door hook or door release button,when they are broken they do not touch the switch, and will NOT start. test for open
see the diagram
Jul 16, 2012 | Microwave Ovens
I have a Maytag Quiet Series 300 dishwasher that is approximately 2 years old. It has been working fine up until now. It has no power at all, no lights etc. I have checked all the power breakers and...
This dishwasher does not have an internal fuse in it unfortunately. Check for power to the dishwasher and if it definitely has 120 volts you need to order and replace the touch control at the top of your door on the dishwasher. This part common fails and cuts power to the entire unit.
http://www.appliancerepairlesson.com/
Good luck
Mar 02, 2011 | Maytag Dishwasher
My Maytag MDB9150AWS is no longer working due to what I believe is a electrical fire in the front control panel as there was smoke coming out of the top of the front panel. There were no flames but the...
My dishwasher (same make and model) had a similar problem except I did see some sparks coming out from th front on the side of it (on Thanksgiving Day no less - a lot of manual diswahing followed). What the problem ultimatly was is what I believe to be a factory defect. On the front door if you remove the inside panel to expose the wiring, I found where the door closes, the ruber coating on the bottom metal edge was worn away (from just years of opening and closing the door. There is a bunch of wires that run from the control panel to the power source and pump. Once the metal was exposed it comes in contact with these wires when the door is opened and closed and it was just a matter of time before they got shorted out. Fortunatly for me this happened while I was standing right there and was able to turn it off or this may have resulted in a fire. Also because of the quick shut off, none of the electronics or motors seemed to be affected. After respliceing the wires that were exposed, the dishwasher is working as normal. I plan to go back to Maytag to see if there is any complaints regarding this same issue.
Nov 03, 2009 | Dishwashers
My dishwasher has no power not even on the touch panel leds lights. I checked the connections.. Is there a reset button or a fuse i can replace or reset?
Check the appropriate breaker in your house electrical panel--push off, then on. If still nothing, look for a removable panel at the bottom under the door. Any internal fuses or breakers will be accessible there.
Sep 17, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Control panel cover falling apart
i looke dup your model and you seem to have the hidden control panel model. the manufacture is funny htat way they will only cover part if you have installedby auth servicer, i looked up the part for you part number 8531269 retails for about $70. its the enitre console assy including overlay. so although they cover it youd be better off buying it direct and installing your self for sure. simple enough repair, the screws (torx15) from the inner door panel come off and release the panel, everthing on the inside simply unsnaps and gets transferred to the new part. just remember to disconnect power first all live wires!
Nov 06, 2008 | Dishwashers
Neff Built in Dishwasher
take top off then side panel and hinge is exposed. to expose the part of hinge on door, take outer panel off door - just held in by screws down each side
Jun 26, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Dishwasher lights are all flashing
If you do have the Touch Control Electronic Pad, then you do have a problem, moisture related. You need to open the panel, use a Hairdryer to dry the panel properly and replace. This sorts many of these Touch Control Electronic Pad.
Nov 23, 2007 | KitchenAid 24 in. KUDI02IR Built-in...
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
