Samsung panel for UN55B6000VF
I have a 55 inch LED tv and last night I noticed that a horizontal black line had appeared on my sreen at the bottom. The sreen was "ghosting" images from the TV ad it has a white haze on the screen. I had someone look at it and he said the panel is bad. Your advice.....
davebies
  • 43 Answers
SOURCE: Horizontal (dashed) line across screen
On the KDFE55A20 this sounds like a bad Q-Box. I would get an estimate from a Sony authorized servicer as this part may be quite expensive. On the 55A10 model this may be the B-Block and is also quite expensive. Getting an on-sit estimate would be the first step I suggest. Again go with an authorized Sony servicer. Call Sony or go to Sony.com for customer service. Good Luck
Posted on Jan 06, 2008
SOURCE: LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
I unplugged the TV and now the picture is back.I read that the LCD's are vunerable to static build up so unless my daughter is using her TV I unplug it.
I was thinking about getting a large LCD for the family room but I'm not going to until they improve on this technology.
Good luck to everyone!.
Cheers.
Posted on May 08, 2008
SOURCE: Horizontal green line appears on screen
my maxent plasma tv has the same problem but it has green and red lines. I found out that hitting the tv from the back works. It used to last a long time but now i have to get up now and then to slap the tv on back with my hands! anyone with a long term solution?
Posted on Jun 12, 2008
  • 10 Answers
This should be repairable. It may be the LVDS Cable or the Main board problem. The only other problem is the T-Con Board.
Posted on May 23, 2009
  • 80 Answers
SOURCE: Vertical white line down centre of Soniq PT42SH plasma TV.
One of your "X" buffer boards is defective. In Panasonic plasma tv's they are located at the bootom of the set and connect directly to the plasma diplay panel via a thin ribbon cable. The board you want to replace will be directly in line with the discolored vertival line in the picture. The part number is on the circuit board and usualy starts with "tnp..." or "txp..."
Posted on Jun 01, 2009
I have a 55 inch Samsung LED TV that has horizontal black lines across the screen from top to bottom that jump randomly up and down. I need to know which board is bad.
You must do testing as outlined in the factory repair manual by symptom to diagnose this, if it was easy TV repair shops would be out of business.
Oct 28, 2016 | Samsung Televison & Video
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
HOW DO I REPAIR A SAMSUNG LED TV WITH HORIZONTAL LINES ON THE SCREEN?
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jul 08, 2015 | Samsung UN55ES6500 55 Inch 3D 1080p Smart...
My led samsung tv has a horizontal line and the upper right corner shows a white vertical lines
Not good. You may have a tab failure. A repair shop may be able to diagnose and repair this, but most likely the lcd panel is broken. The panel is the most expensive part of flat tv's. A new panel will cost more than a used tv.
Feb 02, 2015 | Samsung Televison & Video
Good day again my Samsung 55''un55es7500 led 3d tv has tin g oldish lines from top to bottom of left side of tv screen can you assist in fixing problem
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both LCD & Plasma TV screen are given with illustrations. You can get an idea about the fault to an extent.
Jan 17, 2015 | Samsung UN55ES7500 55 Inch 3D 1080p Smart...
Horizontal lines on SONY TV
the ribbon flat connection tapes that connect the led panel driver to the panel have prob delaminated
this cant be repaired easily and you would need to replace the panel
Dec 05, 2014 | Sony KDL40EX520 Bravia KDL-40EX520 40 Inch...
Samsung HPR4272X/XAA has 2 black bars going from top to bottom.
I really do not know there is the "Stuck Pixel Fixer programs" I think that Program Breakdown another IC. For this issue is absolutely the Plasma display panel have problem. You shall exchange it.
Apr 17, 2010 | Samsung HP-R4272 42 in. Plasma HDTV
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
Electro Med Services...
