Question about Yard Machines 11A08MB006 22Inch 139cc MTD OHV Gas Powered Side Discharge
Overfill oil yard machine is hard to star, blows blue smoke out of exhaust won't stay running. trying to restart is even harder than the first time.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,095 Answers
Sounds like the engine is tired. Blue smoke is oil burning. Hard starting is oil on the spark plugs and/or low compression. This also can be due to someone adding too much oil.
Sometimes, the carburetor Needle valve hangs u pa bit and the Crank case oil gets mixed with gas so now the oil level is high. Too much oil in a motor is bad too, that would cause theblue smoke too.
Posted on Jul 21, 2013
Just replaced air filter, fuel filter, and plug. Ran good for 10 minutes then started spuddering and died. Restarted right away and huge cloud of blue smoke came out. It spudders for a minute and dies
Blue smoke is oil. Have you checked you pcv? (Pollution control valve) it usually runs from one of the valve covers to the airfilter unit.
Apr 02, 2016 | Cars & Trucks
21 hp B@S engine exhausting blue smoke
sounds like blown head gasket.
does it have a fuel pump, if so is there oil around it (by the brass colored screen)
if so then you have blown head gasket
Oct 24, 2015 | Craftsman 46 In. 21hp Briggs & Stratton...
Blowing white smoke out of exhaust
sounds like it is still overfilled ,, oil is leaking on the back side of the piston .. or may be a blown head gasket and being overfilled was just a coincidence if it is a briggs motor I would be suspect of a head gasket.
May 24, 2015 | Husqvarna YTH2042 42" 20 HP Lawn Tractor...
Why is my 2000 kia sephia blowing blue smoke from the tailpipe. it has 86,000 miles. the check oil warning light is on even though the dipstick reads full.
The most common cause of blue exhaust smoke is oil leaking past engine seals and into the cylinders where it then mixes and burns with the fuel. This is most frequently seen in older or high mileage cars with worn seals and gaskets. It only requires a very small amount of oil leaking into the cylinders to cause excessive blue exhaust smoke.
Blue exhaust smoke only at start-up can indicate worn piston seals or damaged or worn valve guides which may also cause a rattling noise. An external engine oil leak can drip onto hot engine and exhaust parts causing what appears to be blue exhaust smoke. Other possible causes of blue exhaust smoke include: piston wear, worn valve seals, a dirty or non-functioning PCV valve, worn piston rings, an intake manifold gasket leak, worn engine oil seals and possibly even head gasket failure.
Oil leaking into the cylinders can cause a rough idle, misfire and fouled spark plugs. In addition, a reduction in power and oil loss can be indicators that the blue exhaust smoke is caused by an internal engine oil leak. Internal engine oil leaks can also allow fuel to mix with the oil in the crankcase which will degrade the oil and prevent it from adequately protecting the engine.
Operating a car with a severely dirty oil filter, air filter or improperly functioning PCV valve can also sometimes result in engine oil blow-by, oil loss and blue exhaust smoke. Periodically checking the engine oil level with the oil dip stick will indicate if there is excessive oil consumption. Higher viscosity engine oil can sometimes temporarily reduce the amount of blow-by; however, this is not generally recommended. Excessive blue exhaust smoke indicates a possible internal engine oil leak that should be inspected by an ASE certified mechanic.
Dec 08, 2014 | 2000 Kia Sephia
95 ford probe car runs ok but blows whitish blue smoke as accelerate
That is probably the head gasket leaking. White smoke is from antifreeze going through the exhaust. The engine compression is pushing the water out of the radiator.
Nov 27, 2013 | 1995 Ford Probe
Overfill oil
Did you turn the mower on end or over? If so change the air filter otherwise It sounds like the piston rings are worn out. Rings are cheep but unless its an expensive lawnmower I would just replace it.
Jul 20, 2013 | Yard Machines 11A08MB006 22Inch 139cc MTD...
2003 ford explorer blowing black exhaust and won't idle
black smoke is the sign of a weak ignition and or timing
Dec 18, 2012 | 2003 Ford Explorer
My mtd yard machine (leaf blower) started billowing white smoke. I shut it off and now it won't start again.
First check the oil level. If its overfilled correct it. Then remove the spark plug and turn the engine over. Replace the spark plug.
Start the engine. Use a prime ( squirt carb cleaner into carb) if you need to. It may start smoking again. Thats OK as long as you know there is oil in it and you dont hear any strange noises. Let the unit run for about 5-10 minutes and see if the smoke clears up. Once it quits smoking stop it and check the oil.
Nov 11, 2012 | Garden
Engine only runs with choke on. Blue smoke comes out and engine runs rough or not at all
sounds like you have a bad Ring on the Piston or a blown head possibly. Blue smoke means Oil is getting into the combustion chamber. Full choke means you have to give this 'broken' engine a lot of gas to compensate for it's problem.
Do you change the oil at least once a year? Filthy oil or a lack of oil will kill an engine
Aug 06, 2012 | Yard Man Garden
Have a toro self propelled. The engine cuts off as soon as it starts and prior to that it was blowing white smoke. It looks like there may be oil leaking under the exhaust, but can't tell where i
It could be that gas is filling the carb because the needle is stuck open. The excess can drain into the engine oil. If you check the oil and it's overfilled and runny, then you need to overhaul the carb and change the oil.
Oct 10, 2017 | Garden
Yard Machines 11A08MB006 22Inch 139cc MTD OHV Gas Powered Side Discharge Logo
140 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
