Akai channel I'm having problems connecting my gramophone to an amplifier trough phono input (it's an akai ap-m600 gramophone and jvc amlifier). The only time I hear something is when i turn the amlifier to a maximum, but even then the sound is really low. What should I do?
SOURCE: Receiver shut down only when using phono preamp
Since the protection circuit trips after 4-5 songs at high volume from LPs, it may be that the infra-sonic rumble common to phonographic recordings is driving your amp stages much harder than it sounds like they are driving. You can check this with watt meters for your speaker outputs, or by filtering such extremely low frequencies on the input. If you have an equalizer--especially an old one--it may have an infrasonic filter, or just cut the very lowest frequency available on the equalizer after running your phono pre-amp into the EQ and the EQ into your VCR2 input. This setup will verify if your problem is the infrasonic rumble, but I wouldn't use it as the solution. There are very quiet infrasonic filters available that would work better for the long term. And if you just cut the lowest EQ frequency out, you'll miss some good bass.
Posted on Nov 07, 2006
welcomejee
  • 10594 Answers
SOURCE: I have low volume on two channels of my STR DE975 receiver
I been replied you in chat thread, please check and feel free to ask any question.
Posted on Aug 20, 2008
SOURCE: Low volume from Akai turntable attached to Pioneer Surround Sound Receiver
If you receiver doesn't have phono inputs,you will need to buy an inline phono amplifier.Phono inputs have a built in amplifier,all others don't.Try Crutchfield.com.If they don't carry them,they will tell you who does.
Posted on Jan 27, 2009
SOURCE: muffled sound from speakers when connected to laptop via amplifier
You need to buy an analog to digital converter box if you want to get superb sound quality from your computer.
Posted on Mar 10, 2009
  • 3600 Answers
SOURCE: Hi ,Marantz SR7200 , i am getting an audible hiss
if your hooking up a phono input lead to a digital input lead it won't work analog and digital totally different setup. when you connect the leads up it just kills the input amp so there is no noise.
Posted on Jul 10, 2009
Turntable with built-in preamp won't play on phono channel on technics sadx950, but fine on CD channel. Is phono channel dead?
A turntable with a built-in preamp should not be connected to the phono input, because the preamp of the receiver or ampifier will be overdriven. The task of a preamp is to amplify the very low level of magnetic cartriges to the high level needed to work a line input and does some equalizing work to the signal. You can check if your turntable has a switch to disable the built in preamp (mostly they are low-end quality), otherwise connect the turntable to a high level input like "Tape", "AUX", "TUNER", "MONITOR", or "CD".
Nov 13, 2015 | Technics Audio Players & Recorders
I want to hook up a turntable to my Nakamichi AV-500 but don't see phono jacks. How do I do that?
if your turntable has an integrated amplifier you connect it directly to any regular input like DVD or CD. If this is a classic turntable you need to buy external phono amplifier. It is a small box with phono inputs and rca regular outputs you plug your turntable trough this box to cd or dvd input of the receiver. Can be tube or transistor amplifier. price vary from 20 to hundreds dollars.
Oct 14, 2013 | Audio Players & Recorders
Hooked up a sony turntable to a sony 5.1 multi channel but there is no sound
If you have no phono inputs on the back, you will get very little to no sound. Phono inputs have a built in preamp to amplify the signal. The only option is to go to a second hand store or ham festival to see if you can find phono amplifier, runs on a 9volt battery.
Mar 05, 2012 | Sony Audio Players & Recorders
How to wire Denon AVR 5600 as a separate amplifier in an existing system with a Pioneer SC-57
Do you mean for just 2-channel or what?
The Denon doesn't care what's upstream of it. CD players, other receivers, whatever. The Pioneer has analog pre-outs so you can slave any amps analog input(s) (except PHONO) to any channel(s) on the Pioneer.
Sep 13, 2011 | ATI AT2505 5-Channel Amplifier
Aai have the following AKAI Audio Stereo System and no Idea how to connect them. Please help Akai Model AP-D210 turntable Akai model CS-F14 Stereo cassette deck Akai model AT-K110 Fm Am Tuner Akai...
In general, outs to ins.
If nothing else, get the manuals for the preamp and the EQ. You'll probably have to pay for them.
Google it.
Akai PR-A04 preamplifier << This is the control center and where everything comes together.
Akai AP-D210 turntable (ONLY to jacks that say "PHONO"
Akai EA-G40 Stereo Graphic Equalizer (in the Tape 1 Out/In set)
Akai CS-F14 Stereo cassette deck (in the Tape Out/In set of the EQUALIZER) *
Akai AT-K110 Fm Am Tuner (to the Tuner inputs)
Akai DT-100 Audio Tuner (to the Aux inputs)
Akai PA-W04 Amplfier (to the amp outputs)
* This will allow you to Equalize the Tape on the Record or the Playback side.
Read some audio magazines or websites. Get to understand Tape Monitor Loops.
Don't use excessive EQ.
Mar 17, 2011 | Akai Audio Players & Recorders
Low volume through amplifier
Turntables generate a very low signal. Phono inputs on receivers containa pre-amp section to boost the signal to "line level" or the same level as other audio devices. I would suspect that you need to add that pre-amp section. Phono preamps are available for around $20 or so and are inserted between the turntable and the standard audio input on the receiver or amp.
Hope this helps,
Dan
Apr 15, 2010 | Cambridge Audio Azur 540A Amplifier
NAD 302 PHONO STAGE
Reverse your RCA input around and see if the problem follows, this will determine if the problem is in the turntable output signal or the preampsection of your amp. If it stays on the same channel, slightly move the RCA that's dropping out signal around. If the signal cuts in and out, you know it's just a weak solder joint on the input rca of the amp. If it does not change, your problem is deeper. Chances are it's a "cold solder joint" on the input section of the amp and would only be a labor type repair and no parts involved. That can be a double edged sword as well depending on how long it takes to find it. If you have to have it serviced, find a local shop that's been around a while, they are likely to be a little more insightful as to the exact problem quicker. Hope this helps
Jun 26, 2009 | NAD C372 Amplifier
I have Pioneer Amplifier with Phono Inputs. Also I have an Akai stereo Equalizer. I want to connect my Turntable to the pioneer amplifier through Akai stereo Equalizer to have a better sound quality. Is it...
hook the turntable "directly" up to the "phono" inputs. if it sounds normal this way, and not loud and distorted, then you have to plug the turntable up that way, directly to the reciever's phono input.
you can hook the eq up through the "tape in/out" jacks.
take the tape record out jacks, and hook them up to the input of the eq, and take the tape play input jacks and hook them up to the output of the eq. then, to use toe eq, select whatever input you want eq'ed, while also selecting "tape monitor"
Mar 07, 2009 | Kenwood Audio Players & Recorders
Not a good sound
you can't...the technics need to be pluged into phono..because the signal has to be amplified for it to play...phono channels on amps and dj mixers have an amp built in....
Apr 06, 2008 | Technics SL-1200MK2 Turntable
Mar 02, 2008 | Audio Players & Recorders
18 people viewed this question
 Grubhead
Grubhead
