Question about Dell LATITUDE Computers & Internet
Laptop screw lost shape and cannot be unscrew
I think i use the wrong size screwdriver on my laptop and now the screw has lost its X shape and is more like a O shape... the original X shape was for Philips screwdriver 1.4 mmm (so pretty tiny) what can i do to unscrew it! please help!!!!!
  • danny Jul 21, 2013
    Are you saying that if i bring my laptop to Radio Shack they should find a way to unscrew the "bad screw"? "
  • danny Jul 27, 2013
    I went to Geek Squad and they did an amazing job!!!! by the way, they were way way cheaper than all other places i tried ....
    Top Expert:
  • Dell Master
  • 12,223 Answers
You must locate in Radio Shack and fix it.
God bless you
Posted on Jul 21, 2013
Testimonial: "Are you saying that if i bring my laptop to Radio Shack they should find a way to unscrew the "bad screw"? "
None of the screwdrivers fit- also which screw- there are 2 to the right of oil receptacle
Probably "TORX" screws. These are screws with a "star shaped" insert to put the screwdriver into. A hardware shop should have them in a set of different sizes. They are put in to stop people from getting into an appliance to do home repairs lol.
Nov 19, 2016 | Vacuums
How to remove hard drive from dell vostro v131
Turn it over and look for 4 screws in a rectangle shape. One of them should have a disk icon next to it. Use a very fine screwdriver to remove them and slide the disk drive holder out. If you choose the wrong screws, just screw them in again.
Jul 27, 2014 | Dell Computers & Internet
Hard to unscrew the two screws on the needle plate
You need the "Z" shaped screwdriver to get at these screws properly.
There is a specialty driver for these as well ask your sewing machine store it comes in a kit.
Feb 02, 2014 | Brother Se400 Computerized Embroidery &...
I need to change the lightbulb on my em-s5002w Sanyo Microwave. What screwdriver size & style do I need for lower star-shaped screws
The star-shaped screws are called TORX and range in size from T-1 [small] to T-50[ quite large]. a set of inexpensive bits that fit a driver handle can be found at a hardware or auto supply.
Jan 24, 2013 | Sanyo EM-S5002W Microwave Oven
What exactly is the name of the tool to remove the one screw on the handle of the Electrolux Renaissance C134A vacuum?
It's not a particular tool, it's simply a type of screwdriver bit. They are called either "Torx" or T-Star and come in a range of sizes, e.g. T15, T20, T25, T30, etc.
I think the one on your vacuum is a T20, but it's hard to remember the size of every screw on every appliance. I've attached a picture below to assist you. If this isn't the right tool, please describe the shape of the recess in the head of the screw and I will post back with the correct answer.
Regards,
BElectric
Nov 11, 2010 | Electrolux Vacuums
Repair a pentax optio m30 Problem what size
Radio shack sells a mini screwdriver set that is quite extensive. You might find what you're looking for there. Take the camera with you.
May 24, 2010 | Pentax Optio M30 Digital Camera
Where is the turn signal relay on a chevy s10
On 95-97 and 1998, both the turn signal and hazard flashers are located behind the lower dashboard trim just to the left of the cigarette lighter. You can not get to it without taking apart the trim (stupid design). Or you have to drill a 2" diameter hole in the trim with a velcro cover so you would never have to do it again1999 and later it is under the glove compartment
to disassemble it without drilling
It's behind the panel to the left of the cigarrette lighter. You need a Torx 25 screwdriver and another screwdriver for those hex shaped screws, forgot the size. First unscrew the 2 Torx 25 screws beneath the steering wheel. Then unscrew the rest of those Hex screws on the bottom. The panels overlap, so be prepared for a lot of unscrewing. You do need to unscrew the middle black panel on the bottom, right beneath the cig lighter. It's held by two Hex shaped screws, one on each side and are hard to unscrew. Also you need to remove your spare change sliding tray to unscrew the last hex looking screw. Once you pop your panel off, the turn signal flasher is the right one. The Hazard flasher is the left one. You can find a replacement part at Autozone, and DON'T get the $184 Flasher switch, all you need is the signal flasher. It's shaped like a cylinder with TWO prongs on it.
Nov 03, 2009 | 1994 Chevrolet S-10 Blazer
Where blinker relay on the 97 Chevy blazer and what does it look like?
It's behind the panel to the left of the cigarette lighter. You need a Torx 25 screwdriver and another screwdriver for those hex shaped screws, forgot the size.
Once you pop your panel off, the turn signal flasher is the right one. The Hazard flasher is the left one. You can find a replacement part at Auto zone. It's shaped like a cylinder with TWO prongs on it.
Good luck and hope this helps
May 02, 2009 | 1997 Chevrolet Blazer
What size screwdriver is required to remove the screws on the braclet of a ladies accutron courchevel 26R28?
All screw heads in watch bracelets are usually 0.8mm - 1.30mm in diameter. In my experience screwdriver with the blade width of 1.00mm was good for unscrewing the bracelet screws in majority of cases. So, I would advise to buy a screwdriver with 1.00mm wide blade.
In case if you realize that the bracelet screws are a tiny bit smaller than your brand new screwdrivers blade - do not panic but use the sandpaper or any sharpening stone. Just a few strokes from both blade sides will reduce the width of the blade to the required size and you will be able unscrew the screws with ease.
In case if you brake the tip of the blade, use the same method as described above, just in this case reshape the blade. As the size of the blade is quite small, it is easy to do and takes very little time.
And,yes, the blade can be reshaped plenty of times, not just once or twice. In fact it can be reshaped and sharpened till you run out of metal.
Do not forget to rate, please.
Mar 12, 2009 | Watches
Computers & Internet Logo
Alun Cox
