Question about Boating
I have a shurflo 2088 403 144 motor runs, will not pump water
3 Suggested Answers
packrat1948
  • 528 Answers
SOURCE: shurflo pump 20psi 2095-204-112, in
Take the aerator off the faucet and see if that makes it work better if yes clean the filter in the aerator on the kitchen faucet.
Posted on May 12, 2011
  • 6468 Answers
SOURCE: shurflo pump just installed will not stop running
you should check the foot valve that would be at the bottom of the well pipe the fasted way to check it is shut off the pump and see if the system pressure drops down
Posted on Apr 01, 2012
Trouble shooting shurflo water pump problem
Try bleeding all the air out of the system or the new pump might be faulty.
Jul 09, 2016 | Shurflo 2088-554-144 Delivery Pump -...
Power to pump
put a little oil on it and turn it by hand a few times it gets dirty from sitting ,try it
Mar 28, 2014 | Shurflo Pumps 8005-233-236- Shurflo
If I use a small amount of water, the pump starts, but does not build pressure. The pump continues to run and acts if it is air locked or lost prime. If I shut the switch off and let the pressure go and...
Sounds like a well pump with a leaky foot valve. I beleive you are correct in that it air lockes then when you shut it off the water flows back eliminiting the air lock.
Aug 07, 2013 | Shurflo Plumbing
Shurflo pump just installed will not stop running
Mar 31, 2012 | Shurflo Plumbing
Extreme pro blaster 5901-2112 pump.will not pull water 6ft. Drained and ran rv anti freeze thru the past 2 winters and pump performed well last three seasons. Placing finger over intake side with pump...
I can't find your particular model pump but, in the picture shown, if thats yours, it looks like two pumps in one. Anyway, I'm pretty familiar with Shurflo pumps and they are diaphram pumps and, the antifreeze may have taken out the diaphams. I'd like to see a bigger picture of it.
http://www.shurflo.com/files/Education-Center/Product%20Data%20Sheets/Fresh%20Water%20Pumps/pds-Extreme%20SS%205.7%2012v%205901-0201%2011.pdf
The pump head should look something like this. I'd replace the diaphram assy.
Jun 15, 2011 | Shurflo Extreme Series High Flow Strainer...
We have just installed a new shurflo pump in our trailer. The pump is working but we cannot get it to stop and there seems to be air in the line. We have tried leaving the taps open but does not seem to...
Hello;
Water water everywhere.... The pump you installed has no way of knowing when to stop. Shurflo also has a pump with a pressure switch that senses pressure drop to turn on and back pressure to stop. I'm sure the dealer that sold you the one you now have will have the proper modell for your application.. Good luck and be sure to put a filter in the line coming from the fresh water tank. You should be all set with this recommendation._Ned_
Apr 16, 2011 | Shurflo Plumbing
Motor on reverse osmosis runs constantly
If this is a booster pump, many booster pumps like Shurflo have an adjustment at the top (allen screw) to back off on the pump pressure, turn to left to back off on pressure. If it never shuts off this can be an indication of a bad membrane, capillary tube, flow restrictor or automatic shutoff, causing all the water to run to drain. If you have low quantities of water, but pump always runs, this could part of the problem. Also high TDS (total dissolved solids) will cause the pump to work more. The higher the TDS 500+ppm the harder it is to produce quality water. With high TDS it's almost like taking muddy water, running it through filters and getting drinkable water. So the RO and pump have to work much harder to produce any quantity and quality of water.
RJ
May 01, 2010 | Culligan Under Sink Water Filter
Boating Logo
35 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
