Question about Garden
I have a john deere stx38 it will not fire put new coil and spark plug still no spark cranks good and magnets are clean what could it be
    Problem Solver:
  • 16 Answers
Did you set the gap between the magnets correctly. if not you may not be getting the voltage you need to create spark.
Posted on Jul 20, 2013
  • joseph profitt Jul 20, 2013
    Yup used a dollar bill for spacing
rwvanlue
  • 486 Answers
SOURCE: I have a John deere 317 tractor that does not start.
We will be testing for voltage to the points, coil, engine to tractor wiring harness, ignition switch
Tools needed:
volt meter to read 12 volts, or test light
1) with the points open: is there voltage at the connection wire at the points
If yes; adjust points to .020" and try to crank engine and check for spark
*** you may want to determine if condensor is connected to this wire also
if no
2) check point side (neg or - ) of coil for voltage
if yes, engine should start
if no
3) check for voltage at the + side of coil
If yes, coil is bad
if no
4) check wire connector from engine to frame wiring harness
if yes; engine should start
if no
5) check wiring on the back of ignition switch
if no
6) check that ignition switch RED or BATTERY supply wire has voltage
if yes; switch is bad
if no
7) check supply wire and circuit breaker connected to the battery side of the solenoid
if no; circuit breaker could be at fault or wire connector at battery supply
Posted on Nov 08, 2009
  • 21 Answers
SOURCE: john deere stx38 wont move transmission locked up?
Engine OFF, raise drive wheels and check if transmission is locked
Posted on Jul 14, 2009
wireguy212
  • 1627 Answers
SOURCE: john deere 425 mower won't start
The ignition switch module is likely to be the problem,they seem to quit for no good reason.The safety relays and fuses are built into the board that comes with the switch and will most likely fix your problem.
Posted on Apr 25, 2010
  • 13 Answers
SOURCE: john deere lane rider la135 wont start.
You don't mention if they are on and are bright or are week. Do they dim when trying to cranks the motor? I would start with checking the ground wire at the battery and where it connects to the frame. Make sure both are clean. From there, have the battery tested and then the starter.
Posted on Jun 10, 2010
  • 10 Answers
SOURCE: Have John Deere 165 riding mower. Strong crank,
Has it been outside? May be water in the fuel.
Posted on Jul 25, 2010
John deere tractor has no spark eng is fb460. i put a new spark plug and a new coil still no spark
Make sure you set the gap properly on the coil should be a filler gauge 10. Make sure the flywheel is clean at the firing point. And make sure there are no safety switches that have gone bad. Safety switch that go bad will cause a break in the circuit and will prevent the coil from allowing spark.
Aug 04, 2016 | John Deere Garden
Stx46 cranks or fires but will not start
sounds like timing is off or no fuel getting into the manifold . remove and check main jet or for fuel in the bowl.
Jun 16, 2013 | John Deere Garden
I have a stx 38 john deere and put on a new coil and have no spark at the plug
1. make sure the spark plug lead is connected to the plug
2. check the condition of the plug and make sure its properly gapped
3. test for spark plug making sure engine ignition switch, key switch, or kill switch is in the run position
4. crank and observe
if that doesnt work check where the coil attatches to the engine for rust buildup or moisture. if that is the case clean surface area and let dry in warm dry area for 4-6 hours and try again
Aug 19, 2012 | John Deere Garden
John deere lawn tractor 175. engine turns but No spark from spark plug
some of the safety switches will shut the spark off unplug the harness from the engine then crank it over if you have spark there is a problem with a saftey switch if you have no spark the problem is the coil
Apr 13, 2012 | John Deere Garden
I have a john deere stx38 and it has no spark and wont fire but engine turns over
Check the shear pin in the flywheel, replace if bad, should cure your no spark problem
May 28, 2011 | John Deere Pto Clutch For Stx38 And Stx46...
I have a john deere stx38, has no spark. Engine turns over fine but will not fire. JW
Check the HT lead for cuts or breaks and then replace it anyway then check the on/of switch for rest
Jul 09, 2010 | John Deere Pto Clutch For Stx38 And Stx46...
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
