Question about Garden
I4500 ROVER MOWER WONT START
I4500 MODEL STARTS BUT THEN WONT RUN
3 Suggested Answers
mikehowy
  • 177 Answers
SOURCE: after start mower wont run unless I press the primer bulb
carby service maybe required
Posted on Jun 07, 2010
  • 8 Answers
I got exasperated (sp?) with this happening on my last two mowers. New gas, spark plug, filter, etc. Ran fine for 10 minutes, then wouldn't run without the primer bulb being pushed in. In desperation, I wiped off the gas tank filler neck, put my mouth over the whole thing, and blew like h*ll. Now I couldn't say whether the mower got excited or what, but it started right up and ran fine (long enough for me to finish the front lawn). After all my frustration with this thing, I'm still kinda laughing at the fix, even if it's not long term.
Posted on Jul 02, 2014
How do you replac a sump gasket on a i4500 rover motor mower
if it is a horizontal shaft it is a matter of splitting the crakcase from the cylinder body or removing the sump . If it is a vertical shaft the engine will have to be removed and the crankcase separated completely
If you have no experience and the correct tools then best give the job to a mower shop.
Jan 26, 2015 | Rover Cars & Trucks
Briggs and stratton engine in rover lawn mower ....... the mower is about 7 years old and maybe used once a year.....the fuel primer button does not seem to be working... please help !
what size motor squirt some starting fliud in the carb and it starts up probably need to rebuild carb no i no you will have to rebuild carb and get this feul additive called sea foam follow the instructions on the can it will make a old machine run like new run to tank fulls through it
Sep 12, 2014 | Garden
Rover 75 2.0 td wont start starts with easy start wont run without it
hi
stop using easy start cos it will polish the cylinder bores and you will lose compression.
you need to do a compression test first and remove / test the gloplugs.
If the compressions are low it will require a rebuild
Jul 11, 2014 | 2000 Rover 75
Mower wont start
chech to see if plug bad make sure you are getting spark if it is spray some starting fluid in it see if it starts if it does checkfor water in gas if no rebuild carb should run
Jul 03, 2014 | Garden
Rover i4000 Q start
you will need to pull the top cover off the mower and follow the spark plug wire to the coil. when you pull the rope it turns a circlular drum that when it rotates near the coil will create a spark. you need to take some sand paper and clean the drum and the coil. there is probably some rust or film causing no spark.
hope this helps.
Feb 16, 2012 | Garden
I inadvertantly placed the fuel and oil mixture into the fuel tank of a 4 stroke petrol mower when it should have been unleaded fuel only. How do I rectify this problem. The mower is a Rover i4500 model...
It won't do any harm in fact it may do it some good. The only real side effect I can see is a little smoke comming out of the exhaust.
Terry
Feb 12, 2011 | Garden
My 2.5 range rover diesel wont start when cranking over diesel leeks from spill off return pipes tryed easy start no joy auto electrician said immobaliser wont let it start
immobiliser also cuts starter motor so probably ok i would check the fuel pump is delivering enough fuel take off fuel filter put container under it and put ignition on you should get a strong flow
Apr 28, 2010 | 2000 Land Rover Range Rover
Push mower runs then quits!!
My toro mower starts and will run for ablut 15 minutes and starts to cut out and eventually stop running. What could be the problem
Apr 01, 2009 | Craftsman Garden
Starts fine when cold, after running dies on idle then wont start
Sounds like the fuel filter is dirty and needing to be changed. It's cheap and easy to swap out.
Jan 12, 2009 | 2002 Land Rover Discovery Series II
Garden Logo
133 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
