Model # AWR1W1 Bose Wave Radio remote is not working.
I properly installed a new button battery in the remote control and it still does not work.
Fame_Guru
  • 483 Answers
SOURCE: Bose Wave Radio - Need IR Codes for cable remote
Check this manual,
this will guide you through the setup again :
http://products.bose.com/pdf/customer_service/owners/wrv3_guide.pdf
Posted on Mar 25, 2009
BillB-SA
  • 2761 Answers
SOURCE: My 10 year old Bose wave radio quit working.
There's a line fuse inside the radio, mounted on a PC board. CAUTION: disconnect the set from power before opening the case or poking around inside. The fuse could be bad, but these sets are notorious for losing the power transformer. If the fuse is ok then you are looking at a $100 repair fee from Bose. You might want to check out the new HD radios -- better sound, MUCH lower price.
Bill B.
Posted on May 19, 2009
BillB-SA
  • 2761 Answers
SOURCE: The remote for my Bose Wave radio-CD no longer
  • Reset the system by disconnecting the power cord from the wall for one minute, then plug it back in
  • Make sure you’re pointing the remote directly at your Wave® music system. If the system is placed above table-top height, be sure to angle the remote upward while pointing
  • Check for possible sources of interference with the remote’s infrared (IR) signal, such as bright lights or solar glare off of a window. Make sure nothing is blocking the path of the signal from the remote to the Wave® music system display. The remote will not work properly if there is something directly in front of the display
  • Wipe off the small clear lens on the front end of the remote
  • The remote is designed to work within 20' of the system. Greater distance may cause intermittent response
Posted on Dec 06, 2009
  • 382 Answers
SOURCE: CD does not engage to play/ on/off button does not work on radio
I hope it is still under warranty and can be replaced, Bose products are littered with problems.
Pool loading of the CD can be a simple lens cleaning or a defective laser/transport.
First step is to unplug for 10 minutes then replug.
Failing that find the nearest service centre.
Hope this helps!
Cheers,
Posted on Jan 22, 2010
Testimonial: "The solution worked for now.....I just need to find the nearest repair center for later."
veryverybusy
SOURCE: my 10+ year old Bose wave radio/alarm on fritz
Replace the 3 AA batteries that maintain memory & backup alarm function. That just may do the trick.
Posted on Apr 10, 2010
No sound Bose wave
I took mine back to the Bose store and they gave me credit on my Wave that was about ten years old toward a new CD wave radio. I would recommend taking it to the Bose store and see what they can do for you.
Sep 11, 2014 | Bose Wave Radio
Lost remote control for bose wave model number AWRCC1 will the additional bose acoustic wave music system remote control work
Check this site to get setup codes and model number of a suited universal remote control. It has many details you want. Check this site too.
Apr 21, 2013 | Bose Wave radio remote control - Graphite...
I have a Bose Wave music system model No AWRCC6, on which the volume control switch and the off switch of the remote does not work. The remaining features on the remote appear to be working correctly. The...
Possible this is poor contact by the button battery with the contacts.I am also having a similar problem, but if I squeeze the remote case just above the set of alarm buttons (this is over the battery) my on/off button tends to work as well as other buttons near the top of the remote. (Certainly is annoying that the radio is completely useless without the remote.)
Jul 24, 2011 | Bose 35504 Remote Control
How do I turn radio on? Is there an old-fashioned "on/off" button? The battery in the remote needs to be replaced but in the meantime,is there a way to turn the radio on?!?!?! Many thanks!
If you have new generation of Bose wave radio with no buttons on the top, it would be no other way, but with remote. Need to know the model number.
Dec 07, 2010 | Bose Wave Radio
Remote does not work, battery is good. Can I program my dish network remote? If so what codes can I use.
Sorry to hear about your original remote; we would be happy to help you with addressing your DISH remote to your Bose Wave Radio. Here is a list of some of the codes that we havefor Bose Wave Radio: 761, 664, 656, and 639.
Press and hold the AUX mode button until all mode buttons at the top of theremote come on, then release. Enter the number 2 then one of the codes for your Bose Wave Radio provided above. Press the pound (#) button, the mode light should flashthree times. Check that the code works by trying several different functions onthe remote to make sure it will properly operate your Bose Wave Radio. Keep in mindthat some codes may not be compatible with your equipment. If this is the case,please try the other codes listed for that device until you find one that iscompatible with your equipment.
We hope this helps you, and thank you for being a valued DISH Network Customer!
Phillip Chang
DISH Network Customer Service Representative
Nov 21, 2010 | Bose Wave Radio II
My remote for a Bose Wave Radio does not work any more. It just stopped one day. I replaced the battery and have made sure that the battery is properly installed (positive side up). I have unplugged and...
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience.
Aug 19, 2017 | Bose Additional Wave radio II remote...
The remote for my Bose Wave radio-CD no longer works. I have changed the battery and put a new battery into another Bose remote--no luck and I want to play my Christmas CDs! Help!
Dec 05, 2009 | Bose Wave Radio
My bose wave radio II remote is not working. I
It will work without the remote, but can ve very unconfortable. If you have a webcam or digital camera or cell phone with camera, then point it to the small lamp in front of the remote and press any button. If the light blinks or keeps on, then the problem may be on the radio receptor. If light is dark, then take it to an electronics store an ask for an INFRARED LED DIODE replacement. This should work well.
Nov 20, 2009 | Bose 35503 Remote Control
108 people viewed this question
 Grubhead
Grubhead
