Question about 2011-2013 Ford F350 F450 SuperDuty Dually REAR Mud Guards
Replace Front AxleIs the front axel on my dually the same as on my F350
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 49 Answers
Yes they are the same dana front ends. just remember to replace the yellow O-rings on the hubs and the big seal on the end of each axle shaft or you will have a vacuum leak and your auto 4x4 will not engage the front hubs
Posted on Jul 23, 2013
How do I adjust the camber on a 1994 Ford F350 xcab Dually 2wd?
take to shop, its cant be done without special equipment
May 27, 2014 | Ford F-350 Cars & Trucks
Hi: I have a 1991 F350 diesel IDI dually; I just had work done on the back breaks because the back breaks locked up on it. New breaks, new drums, and new bearings. Now when trying to stop when going...
Hi sounds like your front rotors are warped. Do you feel it on one side or both? Your brake booster may not working properly or doesn't get enough vacuum. That make the brakes drag a little bit and in a long run will make the rotor warpe. Check front callipers if they not seized first , mesure vacuum. If it's ok you have to replace front rotors and pads
Apr 27, 2017 | 1994 Ford F350 Crew Cab
Leaks gear 90 oil by the throw out bearing on my 1999 ford f350 2 wheel drive dually diesel
The only gear oil near the throw-out bearing would be in the transmission and the only way to the throw-out bearing is out the transmission front bearing retainer. I would check the vent first. It's on the transmission top. If that's free you'll have to remove the transmission and front bearing retainer to check the front bearing and seal.
May 07, 2011 | 1999 Ford F350 Regular Cab
Hear a popping noise when braking. Could this be
This vehicle does not have king pins. There are a lot of front end parts that go bad. Ball joints, stab links, sway bar bushings. Best bet would be to have a proffesional take a listen to it.
May 07, 2010 | 2004 Ford F350
Does the 1992 f350 dually 460 gas have an obd 2 plug?
No - This should have a EEC-IV plug on the driver side front fender near the starter solenoid.
Jan 29, 2010 | 1992 Ford F350
2004 ford f350 4x4 dually is very loose while driving
Well it could be that you need to have the steering box properly adjusted tightened up a bit when you put the new steering box on it has to be adjusted by someone that knows how to adjust it properly or you might need to put a stabilizer shock on the front end or if it has one already replace it.
Mar 18, 2009 | 2004 Ford F350
1992 Ford F350 Dually Diesel Truck Brake System problem.
Adjust your rear brake shoes. Then rebleed the system. Start at the master cylinder Bleed master first then the wheel furthest away from the master (right rear then left rear then right front then left front. Do that and your pedal should be good.
Nov 28, 2008 | 1992 Ford F350
2011-2013 Ford F350 F450 SuperDuty Dually REAR Mud Guards Logo
98 people viewed this question
Top Husky Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Husky Vehicle Part and Accessory Expert? Answer questions, earn points and help others
