Question about Dryers
Dryer overheats shuts off - Dryers
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 102,366 Answers
What make and model dryer?
Posted on Jul 20, 2013
Dv218aew Samsung dryer shuts off itselft after 30 seconds
Bad venting causing overheat? bad thermostats hi limit and cycling? thermal cutt off. bad moister sensor in the drum? giving wrong reading and cuting it off?
Sep 04, 2014 | Samsung DV218AEW Electric Dryer
Dryer will heat but seems to overheat and shut off.
If that is the style with the small heater in back up top the blower wheel is probably slipping.
Dec 27, 2013 | Amana Dryers
Affinity dryer model FAQE7001LW0 OVERHEATS AND SHUTS DOWN
Therm o resistor or air ducts venting needs clean out
if not that change main board
Aug 13, 2012 | Frigidaire Affinity FAQE7001LW Electric...
Dryer runs for 20 secs or so then shuts off
Dryers today are having more and more safety switches to shut them off in case of overheating, and to prevent fire.
Some are even up to six overheat switches and a fuse.
Unfortunately, along with the safety, came sloppier construction, which meant lots more lint collecting inside your machine.
Someone needs to take the whole dryer apart and clean it, because the accumulation of lint is causing one of the overheat switches to "pop".
I have cleaned several in the last few months that had up to 2 shoe boxes of lint inside.
Be blessed.
Sep 16, 2011 | GE Washing Machines
Dryer shuts off before cloths are dry,then then you have to wait about 10 mim before you can restrat dryer..cleaned vent duck to out side2 times to besure it was clean..cleaned venting back of...
Check motor for lint build up around motor. Will cause motor to overheat and shutdown on motor
overheat switch and will restart after cooling down.
Feb 11, 2011 | Dryers
Dryer won't start
if you take the back panel off the dryer there is a white thermal fuse with two wires on it. if the dryer overheats because of kinked or plugged vent it will overheat and shut down.
Mar 24, 2010 | Kenmore 63942 Dryer
Dryer overheats, already checked venting
Does the unit shut off when it overheats? According to the wiring diagram it could be the Heater Relay or High Limit Thermostat. See the wiring diagram for instructions on error codes and how to obtain them. It is easily found on their website. Hope this helps
Nov 25, 2009 | Frigidaire FEQ1442ES Electric Dryer
Asko T700 overheats and shuts off
replace the timer or temp sensor
Aug 27, 2009 | Asko T721 Electric Dryer
Dryer overheats & shuts off. Takes longer
Overheating usually occurs when air flow thru the duct/vent is blocked. Try removing your duct hose from the back of the dryer and clear it of any lint. Check the area where the duct connects to the dryer itself and remove any lint that may block air flow. Then go outside and make sure that the outside vent is cleaned out. Reassemble the duct to the vent and make sure its not crimped or bent. Remove all link around the lint filter and make sure its clean! Good luck!
Jul 04, 2009 | Dryers
Dryer runs for awhile, then shuts down.
I can think of two possibilities, the first one you should do regardless.
1. If the vent is blocked, the dryer will overheat and there are temperature sensors in the dryer that will shut it off. Make sure that the vent is clear all the way to the outside. If it has a plastic hose at the dryer, throw it away and replace with a metal one. Make sure that the vent hood on the outside is clean and the flap is opening freely.
2. The black shavings could be from the drive belt or the bearings on the drum. If either are bad, it could cause the motor to overheat, which would then shut off.
David
Mar 22, 2009 | Whirlpool Dryers
Dryers Logo
Top Dryers Experts
