I need to find the brand of Air conditioning condenser I have model number and serial number
I have a model and serial number for the Air conditioning condenser but the brand name is gone How could I find it?, Model # CCU10A36A-1 Serial number 1603H21670 please help me
4 Suggested Answers
  • 3 Answers
SOURCE: KELVINATOR AIR CONDITIONER
whats the furnace doing exactly is the filter clean ? does the blower come on if you just put fan on ? do you have pwer to the unit ?
Posted on May 30, 2008
motor1258
  • 6674 Answers
SOURCE: dometic duo therm a/c for rv
If it's a dometic try ( http://www.dometic.com/enus/Americas/USA/RV-Products/climate/ac-display-page/?productdataid=66932 ) and if it's a coleman/RVP try ( http://www.rvcomfort.com/rvp/products/rooftop/LP_polarMach.php )
Posted on Aug 29, 2008
  • 3 Answers
SOURCE: Carrier air handler tonnage?
That is a fairly large difference. It is usually ok to have the inside evap. coil and blower up to 1 ton larger than the outside condenser. That will make the unit slightly more efficient as well as less likely to freeze up on low airflow situations. It is not recommended to install a new condenser on an old evap coil. There has been a lot of changes to the design of the coils in the last little while. For example a 10 year old 2 ton coil may only have 3 cubic feet of volume but a new 2 ton coil may have 4 cubit feet of volume.
There are many factors that may have infulenced the decision on what size condenser to install. Many of which can only be done by visiting the home and doing alot of work, checking the duct sizing bioth supply and return, inspecting the insulation and windows of the home etc. etc. Most of the time that never gets done. You can blame the contractor for not doing a complete check, but at the same time you can blame the customer because many contractors that are that good loose the job to a cheaper bid that did not no any of the research. It is a catch 22 for everyone involved.
There is ALOT more to sizing equipment that many people think, sadly that also includes many HVAC contractors. Way too many people use "rule of thumbs" or flat out "guess".
Sorry for the rant but your queston can only be answered by a good well educated HVAC contractor visiting your home. That type of a contractor is getting hard to find these days in such a price competetive world.
Posted on Oct 14, 2008
Hi I just bought a Air Conditioner the serial number isA6X08F2A-1 it's not giving out water is that safe or that the way it's work brand is FEDDERS
Not too sure what the question is. If your weather is very dry, you may not get very much water out of the air, and what little comes out could evaporate, but under most conditions there should be some water (condensate) coming from the unit when it is on. Is there a visible drain hose from it on the outside? You may need to see if it is plugged up. If you can get it open to inspect it, push a wire or something up through the drain to see if you can open up anything that is clogging it. If it is plugged and water builds up in it, you are going to have problems.
Jul 23, 2016 | Fedders Heating & Cooling
P11 error code in my split air conditioning
I suggest that you supply more information such as model, serial numbers and any such numbers from the thermostat if there is one for the unit. This is too vague for anyone to answer. And include brand name as well.
May 24, 2016 | Heating & Cooling
What are the tons of a RUUD AC HANDLER MODEL UBHA-17J11 SO SFFA SERIAL NUMBER MOO500 03485 and what type of CONDENSER & TONS CAN IT HANDUE WITHOUT PROBLEMS?
You can find the tonnage in the model number which increases by increments of 12, so if the model number is 24 =2 tons. Model number on your a/handler is 17. Thats a ton and a half. Really should match the evap and condenser for the best efficiency. ...
Sep 24, 2015 | Ruud Heating & Cooling
Need Minimum Circuit Ampacity and the Maximum Fuse Breaker for the Condenser - Thak you
Serial numbers don't tell much.
Model. numbers describe the unit best an 18 in the model is for 1 1/2 ton,24=2 ton, 30 =21/2 ton 36=3ton etc
May 02, 2015 | Heating & Cooling
My EverStart portable air conditioning unit
sounds like you need to wash your condenser coil. Sounds like your compressor is kicking out on high head pressure. Once it cools off it starts cooling again take it out and give it a bath don't get the electric wet.
Sep 12, 2014 | Heating & Cooling
Keeps freezing
low air flow or low on refrigerant.
Jul 24, 2013 | Goodman Heating & Cooling
Vibration
Hi, you will find the model and serial number on the roof unit. This is the condenser. The serial number will have the date in it, but I would need to see it to tell you. If you can get it, I can tell you the year of the unit. Thank you,
Shastalaker7
Nov 25, 2011 | Dometic Rooftop RV Air Conditioner
I don't have a problem with my product...im trying to find out how many watts do my product use. Model #uamb-036jaz serial #6263f040410617
Brand: RUUD Manufacturer: RHEEM Model Number: UAMB-036J* Condenser Type: air-cooled Condenser Coil Model Number: RCGA-36A2 System Configuration: split-system air conditioner Cooling Capacity: 34,200 BTUHs per hour Efficiency: 12 SEER
10.5 EER Electrical Service: Single-phase Electrical Input: 3,272 watts per hour Voltage: 230 and 208
Jul 01, 2011 | Ruud UAMB Air Conditioner
How can I validate the tonage of my Ruud air conditioner? The model number is M0696. The serical number is RCBA-3/65AS17
you must have very old equipment are you sure of the model and serial number it might be a 69 if the serial number is the m0696. Tom double check those numbers.
Jun 28, 2009 | Ruud Matching Split Air Conditioner
Heating & Cooling Logo
251 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
