Question about Dryers
Last week, I started the dryer and as the drum turned, the dryer made a shrieking sound as loud as a fire engine siren. The noise has now changed to a loud rumbling, like a truck engine, whenever we turn the dryer on. It is not shaking or vibrating like its off center; and its heating and drying clothes; but the noise is way beyond normal. It used to be so quiet, you hardly knew it was running. Now it sounds like a Harley ideling.
  • Dryers Master
  • 15,639 Answers
What is the make and model? This could be the belt slipping, the idler pulley worn out, the fan may have come off the shaft to the motor, something stuck between the drum and the housing or the bearing on the drum. To check these things, lift the top off after you unplug it. The top clips onto the sides and the front and you have to lift hard to get it loose. If you pry on it be careful not to damage the paint.
Posted on Jul 24, 2013
Lumpy816
  • 246 Answers
SOURCE: Maytag Dryer Loud Shrieking Noise
Here we go. First unplug the unit. Remove the front panel by removing the 4 phillips screws just inside the door (on the hinges and just opposite). Next remove the greenish/ brown 5/16 screws that hold the front panel in. There are wires still connected (door switch and moisture sensor) but if you swing it to the side, you can leave them connected and still procede. Next, you have to reach underneath (very difficult to see this so you will have to do it by feel) There is a belt that wraps around the drum. On the underneath side of the drum as you follow the belt it wraps
around the motor pulley (small wheel) and the tensioner pulley (bigger wheel just to the right). Now with one hand, move the larger pulley towards the msaller one. This will give you slack and you can take the belt off both pulleys. Now pull the drum
forward. There you have the inner workings left. Now, there are 3 wheels. 2 black and 1 white. I would check the white one since you've already replaced the black ones. This is the pulley that provides tension when the motor is running (hence no noise when you take the belt off) I'm betting you'l find it does not turn freely (you should be able to spin it with your finger and have it coast to a stop insdead of stopping as soon as you take your finger off). You can get the replacement wheel from your local appliance parts store or on line from the manufatrues web site. However, if you do have to wait for the part, take the wheel off the shaft and wipe off the inside race of the wheel and the shaft for temporarily relife and useage.
Posted on Jul 09, 2008
MNTECH
  • 1543 Answers
SOURCE: Gas Dryer LDG7304AAE making horribly loud noise while drying
Solution for the Maytag model is most likely to replace the blower wheel. Remove the two screws on the front panel (just a couple inches off the floor) and swing the front panel up to allow you to unhook the top side of the panel from the clips at the very top of the front panel. You do not have to remove the wires, just set the front panel to the side. Blower wheel is at the lower left. The old wheel most likely no longer has a D shaped hole to match the motor shaft, and spins freely. Remove cover. Replace the wheel part number Y303836 for a LDG7304AAE which is held on the shaft with a spring type clamp. Reassemble. Not really very hard to do. On a difficulty scale or 1 - 10, I'd rate it a 3.
Posted on Dec 06, 2008
kachbibi1
  • 979 Answers
SOURCE: Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Posted on Jan 14, 2009
pumpkinman
  • 1144 Answers
SOURCE: Ge Dryer making loud rumbling noise
drum bearings are going up
Posted on Jun 19, 2009
TheMobilian
  • 8220 Answers
SOURCE: Dryer making clicking sound, humming and vibrating hard
Check this out:
55b4358.jpgAs you can see they ain't very hard to replace. It is not necessary to remove the gas assembly to replace these. You can get em fer $15 here
More repair photos HERE
Posted on Jun 17, 2010
Asko t701 dryer burning smell
Loud noise is not a good description. What does it sound like? The dryer has a belt that turns the drum, the belt can wear and slip, there is a also a tensioner pulley on the belt system and then there is the motor that turns the drum. The smell could be from the belt, however you should know that dryers are not maintenance free and you have to clean them at least annually because they can build up lint in the cabinet and that lint can get into the heating element and it can start a fire.
Aug 19, 2016 | Asko T701 Electric Dryer
Hp laptop hp 430
Maybe the cpu fan is fubar - check that out.
Mar 18, 2017 | Computers & Internet
My dryer is making a loud siren type noise and the drum turn is kind of clanky sounding too. It is producing heat and drying but I am concerned that something is wrong. I have an Amana LE8317W2 electric...
You will need to remove the top of your dryer and inspect the belt tensioner. If the idler roller has a bad bearing and sticks the roller will get a flat spot causing the noise you are hearing
May 08, 2010 | Dryers
Dryer makes loud noise when operated.
Get your model number and get a set of glides or drum bearings, whichever your unit uses. Don't let this go too long or your drum could be ruined.
Dec 01, 2009 | Washing Machines
Makes a shrieking noise about once a revolution
sounds like a belt but need more info
Oct 17, 2009 | Dryers
Kenmore Dryer 110 is making a loud squeaking noise.
Only a few things will make that noise. The squeaking is caused by a moving part having trouble turning while rubbing against a fixed part.
  1. The idler pulley is worn
  2. The drum support rollers are hard turning on their shafts
  3. The felt seals at the front or back of the drum is worn allowing metal to metal contact while turning
  4. An article has fallen into the housing around the blower wheel and the wheel is rubbing on it.
Listen for the frequency of the sound. The drum rollers and drum felts will squeak at the frequency of the tub turning. The idler pulley turns much faster as does the blower wheel. Knowing this will help pin down the cause.
The following link has valuable information on taking apart your style of dryer:
Sears Dryer Disassembly
Sep 20, 2009 | Kenmore Dryers
GE Clothes dryer squeaks
My ge electricryer sqeaks very loud and makes a thumping noise. it just started a cuouple of weeks ago.
Jun 19, 2009 | GE DWXR483EBCC Electric Dryer
KENMORE DRYER
Hello ENRIGHT11 Welcome to Fixya
My name is Huum,
You said,
DRYER MAKES VERY LOUD NOISE WHEN RUNNING. ALTHOUGH IT HEATS UP AND BEGINS TO DRY, IT STOPS RUNNING COMPLETELY AFTER ABOUT 5 MINUTES. IF YOU WAIT AN HOUR, YOU CAN START IT AGAIN, BUT IT AGAIN SOUNDS VERY LOUD (ALMOST A RATTLING SOUND) AND THEN SHUTS OFF AFTER 5 MINUTES
Faulty Blower Wheel
If you hear a great deal of noise coming from the blower area of the dryer when it is running, then the blower wheel could be defective.
The are many different designs for blower wheels and just as many unique failure modes. Vanes (fins) can break off the wheel and bounce around in the blower breaking more pieces. The blower can break around the coupler with the shaft. This can cause the blower to spin loosely on the shaft. The blower can form cracks which cause it to vibrate, etc.
You should also not be surprised to find foreign debris in the blower. The occasional bird, rodent or squirrel has been known to bypass the out vent cover. If they crawl into the exhaust tube the first thing they come into contact with is the blower wheel.
If the blower wheel is not spinning, or if it is missing vanes, it is not moving air efficiently. As a result, heat is not removed from the heat source and it can trip the high limit switch or blow the thermal cut-off.
Worn Belt
A worn belt can stretch and/or become brittle with age. The belt can then slip on the drum or motor to cause squeaking. If this is the case, the solution is to replace the worn belt.
The belt is not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, worn drum glides or worn drum rollers depending on brand and style.
When replacing the Belt is is a good idea to also change the Drum Support Rollers, Drum Glides, Idler Pulley and Clips. All of these items are economical easily changeable when replacing the belt. The upside is that your dryer will operate like new.
Recent Customer Symptoms:
Dryer makes loud noise when turned on. Dryer works and heats up OK but makes too much noise.
Worn Drum Glides
Some dryer models are equipped with Drum Glides. The front of the dryer rests on these glides. They provide a low friction surface on which the drum spins. After time however, this glides wear down. Much like an automobile brakes, these glides make a load grinding noise when they wear thin. This griding against the drum usually leaves a bare metal stripe that is visible at the point of contact. If the glides are worn, the solution is to replace them.
The drum glides not the only items that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, a worn belt or worn drum rollers depending on brand and style.
When replacing the Drum Glides it is a good idea to also change the Drum Support Rollers, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new.
Worn Rear Drum Bearing
Some dryer models are equiped with a Rear Drum Bearing. The rear of the drum rests on this bearing. It provides a low friction surface on which the drum spins. After time however, this bearing will wear down. If the bearing is worn, the solution is to replace it.
The rear drum bearing not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum glides, a worn belt or worn drum rollers depending on brand and style.
When replacing the rear drum bearing it is a good idea to also change the drum glides, drum support rollers, drum belt, idler pulley and clips depending on make and model. All of these items are economical and easily changeable when replacing the rear drum bearing. The upside is that your dryer will operate like new.
Worn Drum Support Rollers
Some dryers such as Whirlpool/Kenmore brands are equipped with Rear Drum Support Rollers. The weight of the dryer drum rests on these rollers. They provide a low friction surface on which the drum spins when in operation. After time however, these rollers wear down. When they wear, often times they begin to elongate and form a non-round 'cam' shape. The result is that when the dryer is turned on it creates a rumble that sounds as though you are trying to dry a pair of tennis shoes. This sound is usually the drum being forced up and down on the non-round wheels. If the rollers are worn, the solution is to replace them.
When replacing the Drum Rollers it is a good idea to also change the Front Drum Glides, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new. Whirlpool
Kenmore models have a dryer maintenance kit that contains all of these items in a single kit.
Thank You For trusting us with your question
Please remember to leave a
solved rating before you leave!
Jan 21, 2009 | Kenmore 63942 Dryer
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
Noise from dryer
drum has worn drum bearing dryer top AND rear panel must be removed to acess the rear of drum to replace drum
Sep 24, 2007 | Zanussi TC7102W Electric Dryer
Dryers Logo
80 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
