Question about King Post AC-9000RH Air Conditioner
Airco does not cool - King Post AC-9000RH Air Conditioner
Lg heatpump 6711a20003t - remote not switching aircon on,batteries good - also pressed reset button, still not working
Gee info on your LG is quite scarce!
I'm curious to know if you can MANUALLY turn it on?
It may be your Remote is defective? Here is a Link that MAY be helpful and MAY be just the Remote you need? No promises!
Universal remote control Airco 42530
Dec 24, 2017 | LG Heating & Cooling
Why is my airco not cooling?
I believe that error code refers to a defective Indoor Coil Temperature Sensor (Thermistor); probably an "open" or "shorted" condition.
Jul 08, 2014 | Heating & Cooling
Why does the air is coming out from the vent but it's not cold. It's like a regular fan?
Perhaps the cooling fluid from your airco leaked out?
Perhaps your thermostat is defect?
Could be lots of things. Most of the time when you have to ask these kind of questions, you better invite a technician to check what is wrong.
Jul 06, 2014 | 2008 - 2010 Chevrolet Captiva export Tan...
Engine code 2181 enhanced dtc for 2004 vw beetle 2.0 turbo
it is problem with cooling,check if two fans are running with airco on,
if yes,check codes again,look at freeze frame data,
look for temp and time indication,with engine temp and rpm,
if temp is not high,check fan motors resistance,
one broken with ohm too high?
May 13, 2014 | 2004 Volkswagen Beetle
Manual for Arctic Cool Air Conditioner Model #AP-08CR1FACS
hi there...I am MiLi,
I've a question about this, because I've a similar problem.
My airco is displaying this code E2, and I'm wondering what it means.
I don't have the manual anymore to look it up. And the Airco stopped cooling, it is blowing warm or house temperature air.
It is set to cool, but blows warm air.
Is there someone who can help me out with this?
I just want to know what this code E2 means and what to do about it.
MiLi
May 26, 2012 | Danby Heating & Cooling
The airco system has completely stop working. The 4 position switch only work on number 4 and bring outside air (not airco) into the cabine
check fuses first - if ok.
check for refrigerant in A/C - if ok.
check switch and wires - it may be bad.
Apr 14, 2011 | 2001 Jeep Cherokee
Dear sir i have an A12AW1 art cool when i use the airco in the winter outsite temp -10 °C the airco somethime stops althow the roomtemperature is not reached. The airco is also outside...
Not sure the specs of 134. But, at 20 to 30 degrees Fahrenheit your heat pump is not going to be working very efficiently. Now, the ice on the coil is another story. Possibly your defrost is not working BUT, you don't have backup heat anyways. Yes, you should have a low pressure error code, I don't think it's a refrigerant issue.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
May 26, 2017 | LG Heating & Cooling
How can i test if a standard built in condesate
Switch main power off.
Disconnect drain connection
Pour some water trough the drain in the unit.
Put a bucket under the drain.
Switch on the main power supply.
Put the airco on in cooling mode.
If the pump is working, water comes out.
Sep 14, 2009 | Heating & Cooling
My air conditioner runs cool as long as i am driving as soon as i have to idle it turns hot and my car wants to start running hot after about 2 minutes
Does the ventilator in front of the heat exchanger of the airco still work. Otherwise you only get cold by driving wind.
Please rate a woman....
May 07, 2009 | 2004 Chevrolet Cavalier
King Post AC-9000RH Air Conditioner Logo
44 people viewed this question
Top King Post Heating & Cooling Experts
Paul Carew
Tim Whalen
Are you a King Post Heating and Cooling Expert? Answer questions, earn points and help others
