Question about Bose CineMate 1 SR Digital Home Theater System - Soundbar,
Blinking red on bose cinemate 1SR and no sound ??
  • 7 Answers
SOURCE: Connecting my HDTV to my Bose Cinemate
If your BOSE system only has one audio input you will have to connect everything to your tv and like the other guy said there will be an audio out on the back of your tv, connect that to your BOSE and when you switch inputs on your tv it should send that audio to your speaker setup.
Posted on Apr 06, 2009
cjackHD
  • 71 Answers
SOURCE: same problem. Bose CineMate light went red and
If resetting this system and re-seating the interface (box with light) to the bass module doesn't fix this, you may need a new interface module. This sells for about $40-50 from Bose. If this is under it's 1-yr warranty, they should be able to replace this for free.
So just incase you haven't tried it: 1. Unplug the power cord from the bass module (sub-woofer) along with the interface module and wait at least 30+ seconds. 2. Re-connect the interface first- screw it in as tight as can be. 3. Re-connect the power cord, and try the remote again.
This is really the only solution, and it's exactly what their tech support will have you try. That's the one functionally weak point with that system, that little module needs to be adjusted and re-seated from time to time.
Posted on Jun 22, 2009
SOURCE: code for Bose cinemate surround system
We just got a Bose Cinemate system and have the same issue - none of the listed codes for the Synergy V work.
Has anybody got this to work yet?
Posted on May 23, 2010
SOURCE: code for uverse cisco box to bose cinemate series
hi i do have here a couple of codes for bose 4000, 2130, 2215, 2276, 6060,
5007
hope this helps! goodluck!
Posted on Jun 03, 2010
SOURCE: I want to program my
31933
Posted on Jan 27, 2011
I'm not getting any sound from a bose cinemate 1sr
You've either plugged into the wrong sockets, or selected the wrong input on the Bose, or the optical cable isn't inserted correctly or the cable is damaged.
Aug 27, 2014 | Audio Players & Recorders
I have a Bose Cinemate System and a new LG Plasma TV that it will not work with. The Bose system connects using red and white RCA connectors and needs it to be plugged into an Audio Out. The only Audio Out...
If you're using a Cinemate for HDTV listening you're missing out on multichannel sound. However, since it only supports analog 2-channel audio AND a TV or monitor is NOT a meaningful contributor to the listening experience, maybe you could extract the TV audio from the cable box where it ultimately originates in the first place. I'm sure it has a convenient and compatible RCA pair.
Dec 28, 2010 | Bose Cinemate Digital Home Theater System...
How do i hook my bose cinemate system to my lg tv?
If you lg has Optical Output, Which is a 20.00 Toslink Cable, You hook the cord into the Tv using the Optical Output Port then run to the optical in or DIGITAL In on the Cinemate, If you don't have the option to run optical Check for Red and White Monitor Out from the TV and Run into Red and White on the Cinemate.
Dec 15, 2009 | Bose Cinemate Digital Home Theater System...
Bose cinemate no sound
Yes it will work coming straight off the dirctv box. What kind of tv do u have that doesnt have an audio out. I have had to actually use rca splitters to get sound from bluray and cable box because the new samsung led tvs only have optical out. Dont forget the unit not being used must be off or u will have 2 source sounds at one time playing.
Jul 03, 2009 | Bose Cinemate Digital Home Theater System...
How do I get sound from bose cinemate while watching Bluray with?
You are right I checked the Manual online and there is no Optical in. The other tech was right in suggesting that, Cause it would be the next best thing to HDMI. It only has 1 Analog Audio in, So what I would Recommend is Plugging in all of your Devices to your TV and then 1 Audio cable from your TV to The Bose input. Although this will NOT transfer Digital Audio to Analog Audio. This means if you are going in HDMI then the Audio would most likely NOT transfer to the Bose. In this case you would have to hook up a set of Audio cables (Red and White) From the Blu-Ray to the Bose along with the HDMI. This will leave you with only Audio from the Blu-ray through the Bose. To go a step further you can purchase an Audio Splitter (or Video) then plug your Devices into the Splitter and then 1 cable out to the Bose and just Switch the Input along with the TV. Good Luck!
Apr 29, 2009 | Bose Cinemate Digital Home Theater System...
Remote control codes for a Bose Cinemate
I would contact ur nearest Bose dealer or Contact the company through the website to get a replacement remote, you will of course need the serial number for the product when you contact them, using a universal remote can make things easier but you will not be able to access most of the functions without the original
Mar 29, 2009 | Bose Cinemate Digital Home Theater System...
Code for Bose cinemate surround system
Feb 16, 2009 | Bose Cinemate Digital Home Theater System...
Bose Cinemate home theatre
The Bose codes for Comcast remotes for both the Cisco (labeled Xfinity) and Scientific Atlanta (labeled Comcast) DVR remotes are 31229 and 31933. 31933 worked with my Bose CineMate Series II
Jan 09, 2008 | Bose Cinemate Digital Home Theater System...
Bose CineMate 1 SR Digital Home Theater System - Soundbar, Logo
89 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
