Question about Razor Bistro Cycle
Razor Bistro replace back tire
The back tire is flat on my Razor Bistro. How do I change it?
    New Friend:
    Problem Solver:
  • 8 Answers
Get a rancher take pices out an make sure ur put it were the scurrs at an tire ur be rock an roll driveing
Posted on Jul 23, 2013
Razor Bistro scooter won't take charge - light stays red
i had the same problem with mine and it ended up being that one of the batteries was bad, there are two 12v batteries wired in series under the seat, usually you can tell which one is bad by looking at them, one of the batteries will be swelled up
May 09, 2012 | Razor Pocket Mod-bistro Retro Scooter
I have a 42cc homelite chainsaw that I put on my razor mini chopper when there is weight on back tire the bike won't go but as soon as I pick up back tire it will spin how do I solve this problem
If you replaced the motor on the original razor with the chainsaw motor, you may have a gearing issue as the load on the chainsaw is much less than the load on the razor.
Aug 31, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I need instructions on how to replace the rear tire on a razor electric scooter model E100
You can't change the tire it is a soild rubber tire molded to the rim. To replace it you have to buy a new rear wheel. Here is a website that sells it.
http://electricscooterparts.com/razore100.html
Jul 27, 2010 | Razor E100 Electric Scooter
Had a flat tire on my GMC Sonoma. Changed the
wheel rim damaged ?? locating pin for wheel not lined up
May 16, 2010 | 1993 Nissan Altima
How to fix flat tire.
Hi:
I have a rascal 3 wheel chair and the tire is flat on back, how do they come apart for repair, thanks.
Leroy
Mar 28, 2010 | Razor E100 Electric Scooters Red
How to change the flat tire? Can not remove tire off the rim. How i get the nuts off?
While there is road side assistance that can help in times of need. It's imperative that every driver should know about how to replace a flat tyre. After ascertaining that the tyre is flat, you should check the link which will guide you to change the flat tyre with the spare one, have a look
=> DIY 10 easy steps to change flat tyre
=> How to Change Flat Tire
Dec 16, 2009 | 1998 Volvo S70
I got a razor pocket rocket and my back wheel blew up. i have the replacement but i dont know how to do it pls help
Replacing the rear tire is a real nightmare.....you are much better off purchasing the entire rear wheel assembly which you can do from the Australian distributors Funtastic for only about $10-$15 more than if you just bought the tire.
To replace the tire you need to use a bench vice which a couple of bolts clamped into it to hold the hub in place.....you then need to remove the sprocket assembly which is a reverse thread......i had to use a hammer and a large flat head screw driver wrapped in a rag so as not to tear up the teeth.
Once you've loosened the sprocket assembly you have to undo the bolts the hold the two sides of the wheel together and the tire will come right off.
All of this would be totally unecessary if they used a tire that you could remove just like any other mini motorcycle tire.
They don;t and so it is what it is.
As I said, next time just buy the whole assemble and then it's very straight forward.
Hope that helps!
Oct 10, 2009 | Electric Razor Pocket Rocket Ride-on...
Razor Bistro Cycle Logo
75 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
David Payne
David Payne
jasiel murphy
Are you a Razor Toy Expert? Answer questions, earn points and help others
