Question about Comfort-Aire BHD-301 Dehumidifier
Bhd-301-c starts up and tehne immmediatly shuts off I have two and they both are doing the same thing
heatman101
  • 43501 Answers
SOURCE: My comfort-aire dehumidifier #BHD-301 just stopped
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on May 18, 2010
walesarumi
  • 6993 Answers
SOURCE: I have a Comfort-Aire BHD-301 dehumidifier that
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again. Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue. This situation will have to be addressed by a qualified technician.
Take care.
Posted on Aug 17, 2010
  • 773 Answers
SOURCE: Comfort Aire Humidifer Model BHD 301-C It will
If the humidity in the air is low, then it will shut off. When you reset the unit it will run until it senses that the humility is at an acceptable lever based on the settings. It is also possible that there is a malfunction. If it is humid in the room, and it will not run then it could be the humidity sensor, or control unit.
If the unit is malfunctioning, and it is no longer under warranty, then it is not worth it to fix it. If it is under warranty then the manufacturer will repair it.
Posted on Oct 16, 2010
  • 794 Answers
SOURCE: Model BHD-301 dehumidifier compressor will
Hi bash123er,
If you're facing these problem that your dehumidifier is not producing water and compressor is shutting off then there are few things that needed to be checked on:
1. The very common problem with most dehumidifiers is the circuit board relay. If this has gone bad then it will require replacement.
2. The compressor has already gone bad. This is the problem if you notice a buzzing sound every now and then from the system.
3. You may also have a refrigerant leak. This happens when the compressor is running but coils are not getting cold at all.
4. There will be cause of low water production if the fan is not running and the compressor does. If fan is not running then you have to replace it. This also will result frozen coil.
5. Check to see also if your coil is blocked. This will also result into no water production.Air needs to be continually moved over the cold coil to get the water out of the air.
If you're not comfortable doing the checking and repair yourself then I would recommend that you contact a repairman.
Hope this helps.
Thank you for using FixYa.
Posted on Jun 03, 2011
  • 4736 Answers
SOURCE: Model BHD-301-D Will run from
There are 5 basic, yet solvable reasons for what you described. Please pay particular attention to numbers 1, 2. & 5.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have a mechanical unit,
set the humidity extraction knob on Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 65 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this helps you to trouble shoot and solve the problem. Thanks for choosing FixYa.
Posted on Aug 06, 2011
Ihave a comfort aire BHD-301. when i turn it on the filter lite keeps blinking and the filter is clean. is there another filter besides the one on the side?
No, there's only one filter. So be sure that you reinstalled the filter properly, so that it is making contact with the filter switch. If that checks out OK, turn the unit OFF & unplug it for 15 minutes.
After the time has elapsed plug the unit in and turn it ON. Hopefully, during that timeout, the electronics reset and reverted back to the original factory settings, If so, you can now set the controls as you desire.
I hope this helped you and thanks for choosing FixYa.
Jul 24, 2011 | Comfort-Aire BHD-301 Dehumidifier
Humidifier gets ice on top of cabinate. It still produces water.
Most dehumidifiers have a defrost cycle that they run through, as needed. But, apparently, your is not functioning. Eventually, yours will stop collecting moisture, if this continues. In the interim, I would suggest turning the Master OnN/OFF Switch to OFF and unplug the unit until it thaws. While it's unplugged, remove and clean the air intake filter on the front of the unit. If it's clogged it causes the unit to strain and may cause it to ice up. Once the filter is clean and the unit is un-thawed. Plug the unit back in and turn the Master ON/OFF Switch to ON and set the controls as you normally do. Hopefully, that period of being unplugged will have allowed the unit to reset itself and work properly.
I have included a link to your Owners Manual that you can download and print for future reference.
aire.com/index.php?option=com_rubberdoc&view=doc&id=436&format=raw">http://www.comfort-
If the above link fails go to the following link below and click on Owner Manual, near the top of the page.
aire.com/room-air-conditioners/149-portable-dehumidifiers/122-bhd-301-g">http://www.comfort-aire.com/room-air-conditioners/149-portable-dehumidifiers/122-bhd-301-g
Hope this helps you solve the problem.
Apr 27, 2011 | Comfort-Aire BHD-301 Dehumidifier
The machine runs for just a few minutes, but then shuts off before taking in any outside water.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
Feb 22, 2011 | Comfort-Aire BHD-301 Dehumidifier
I have had a m old problem in my apt. how can I keep the mold from growing in the dehumidifier? bonita
One thing that I have had good results with on controling mold and bacterial build up is to add a couple of ounces of chlorine bleach every month. You can purchase commercial products to do the same thing at most hvac supply stores. They do smell much better but are not cheap. Hope this helps you. Thanks
Jan 25, 2011 | Comfort-Aire BHD-301 Dehumidifier
When I start the dehumidifier it will run for a few seconds and than shut down. I have unplugged it and re-started and it does the same. Can you help me out
There are many reasons why a dehumidifier will not work or collect water.
heatman101
0-0-0-0-0-0-0-0-0-0-0-0-0-0-0-
Sep 12, 2010 | Comfort-Aire BHD-301 Dehumidifier
I have a Comfort-Aire BHD-301 dehumidifier that runs but does not collect water. What should I do?
Take care.
Aug 09, 2010 | Comfort-Aire BHD-301 Dehumidifier
My comfort-aire dehumidifier #BHD-301 just stopped working. Any suggestions? Should I be doing some kind of regular maintainence?
heatman101
Sep 12, 2009 | Comfort-Aire BHD-301 Dehumidifier
Dehumidifier icing up
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Aug 29, 2008 | Comfort-Aire BHD-301 Dehumidifier
Comfort-Aire BHD-301 Dehumidifier Logo
21 people viewed this question
Top Comfort-Aire Dehumidifiers Experts
Mike Squire
Bill Long
J.D. Browning
J.D. Browning
Are you a Comfort-Aire Dehumidifier Expert? Answer questions, earn points and help others
