Question about Garden
My 1999 polaris sportsman 500 Is popping back thru the carb when accelerating. I had cleaned the carb set the float checked the sir box and filter. Changed the fuel filter and plug nothing changes. It seems to be getting too much fuel. do you have any ideas to try next
    Top Expert:
  • Garden Master
  • 42,784 Answers
I would check the valve clearance settings as it sounds like a inlet valve is being held partially open when it revs.. Check also for broken valve spring
Posted on Jul 29, 2013
2 Suggested Answers
SOURCE: I have 1999 polaris sportsman
check cam shaft for wear on lobes
Posted on Aug 08, 2011
2013 sportsman 500 gas running out the carburetor bowl from bottom. plastic tube to the ground. is the needle seat stuck?
Hi, Christopher and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2012 500 ho leaking gas from carb overflow tube
Polaris fuel leak repair
Polaris 2007 Sportsman 500 EF Service Manual
2013 Polaris SPORTSMAN 500 HO A13MH50AJ AQ AX AZ OEM Parts
Polaris Sportsman 500 HO Owner Manual
Jan 15, 2017 | GAS Motorcycles
I got a polaris sportsman 500 HO I changed stator ignition and spark plug now it cranks fine and idols good but when give has it boggs and back fires can someone help with this
Check air filter make sure its clean, fuel lines are clear and filter clean or new, is the gas old? Carb or injector? if carb possible needs cleaning. could also be fowled plug
Sep 03, 2015 | ATVs
I have a 2004 polaris sportsman 90 atv that leaks fuel
it does sound like the float adjustment is off inside the carb. allowing fuel to overflow the bowl and seep out the carb. if you take the carbeurator off the bike and take it to the dealer they shouldn't charge you too much just to adjust it out for you.
Jun 19, 2010 | Polaris ATV
I have a 1999 polaris sportsman 335 atv and I am getting gas in the air filter
carb needs work possible float or fuel/air mix valve worn
Mar 07, 2010 | Polaris ATV
1998 polaris sportsman 500 losing power when hot
try head gasket as this is very comen on atvs
Dec 24, 2009 | Polaris ATV
I have a 97 sportsman 500 . it starts right up and runs until you give it all the throttel then it bogs down like its not getting enough gas.
Bad gas..clogged jets in carb...very dirty air filter....clogged gas line or gas tank....stuck float in carb.
Oct 07, 2009 | Polaris ATV
1996 500 sportsman, wont go over 15 mph,
Check your air filter,it could be very dirty and need cleaning or replacement.. Check your drive belt, it might be very worn. Get a Haynes or Clymer shop manual for assistance on maintaining your machine.
Aug 09, 2009 | Polaris ATV
Garden Logo
70 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
