Question about Vehicle Parts & Accessories
I have jaguar s type 1999 model driver side rear door can't open from inside or outside
    Master:
  • 966 Answers
1. you may have disabled the locks thru master control on your side.
2. once open check child safety mechanism
Posted on Jul 20, 2013
Door will not open 2002 x type jaguar
The cable that goes to the inside door handle has fallen off, you have to remove the inner panel and look at the back of the handle, you should see a cable, most likely the cable fell off the retaining slot. Just push it back on until it bottoms out and replace the panel. This is common with door slamming, on x-types.
May 25, 2012 | 2002 Jaguar X-Type
Remote control door locks drivers side works but passenger side doesnt open from outside
hi i assuming that it opens from inside if yes
the problem is the linkage or door lock actuator
to see witch one is the problem from inside the cor
press the door lock switch not the remote.if you hear nose
from passenger door put no movement in the lock that means
actuator is working and the problem is in the linkage
now you must tack door panel off to fix by reconnecting linkage
arm to actuator that should be your solution
good lock
Jun 26, 2011 | 2001 Jaguar S-Type
2006 buick lucerne back doors won't open
My friend just had this problem and he reached in and pulled the inside door handle back as far as it would go, and then let it go, allowing it to 'snap' back. For some reason this fixed it. We have no idea why. By doing this on one door, both rear door locks freed up and the rear locks are now working. Before, both rear locks were stuck and you could not open the doors from the inside nor the outside. Not sure why it works, but maybe it will work for you!
Jun 10, 2011 | 2006 Buick Lucerne
I cannot open my drivers side car door from inside of vehicle. It will only open from the outside . . . what is wrong with it? How to fix it?
another jaguar common fault.take the door cover off and you will see the wire from the handle to the lock. replace the clip(plastic)and all should be okay.make sure plastic sheeting is watertight afterwards otherwise you will have another fault(wet carpets)
Mar 04, 2010 | 2002 Jaguar X-Type
Drivers door will not open from outside but opens from inside
I have the opposite problem . . . drivers door will not open from inside but will open from outside . . . How to fix?
2004 jaguar x type 4dr.... drivers door not opening from the outside or iside intermittingly. What could be the problem?
this sounds like the latch assembly wearing out. see if you still have a warranty on this vehicle by calling the dealer, if not replace the latch assembly inside the door.
Jan 28, 2010 | 2004 Jaguar X-Type
Rear passenger side door will not open
Have you tried to open it from the back seat? If you have then you will have to take off the cover on the door and there should be a release button. Most covers are easily removed with a flat head screw driver - If your door requires a motor to operate than that is your problem. Hope this helps.
Apr 29, 2009 | 1999 Jaguar XJ
1999 Volkswagen Passat inside inner door panel
You'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. If needed, you can pull back the weather seal (can't reuse it, but it's not that important) and you will be able to access everything inside the door
Mar 25, 2009 | 1999 Volkswagen Passat
Doors cannot be opened from outside
are these doors electric or stander. u could pull off the door cover and check the mechanical arm inside the door to see if it fell of the lock for the key
Mar 05, 2009 | 2002 Jaguar X-Type
Vehicle Parts & Accessories Logo
46 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
