Question about Dryers
Fisher paykel dryer ed56
I have a Fisher Paykel Ed56 Dryer which started pausing after a few minutes of operating. It makes 1 beep when it pauses & the pause light is flashing, it will start again as soon as I push the pause button. I have check all the basics like dryer is clean & not overloaded. Any ideas? thanks
  • Dryers Master
  • 16,043 Answers
Could be the door switch or temp sensor. To check the door switch put pressure against the door and see if it stops. Check the slot the door hits to see if there is anything loose in there.
Posted on Jul 24, 2013
  • mark Jul 24, 2013
    Thanks Brad,you were spot on as it was the door switch, after I over rid the door switch it worked perfectly, now waiting on a new switch to fix the problem.
  • Nici Walsh
    Nici Walsh Jun 28, 2016
    Fantastic, glad I checked here, I have been having the same problem and now know what I need to do to sort it out, thanks
4 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: Fisher & Paykel Dryer model ED56 constant beep
Diagnostic Mode
Entering the Diagnostic Mode
(a) Turn the power supply to the dryer on.
(b) Press and hold the Auto Dry down button, then press the Power
button.
The dryer is now in level 0 of the diagnostic mode. After initial entry into the
diagnostic mode, the Start/Pause button operates the dryer as normal. Press
the Auto Dry up or down buttons to scroll through the fault levels.
There are several levels of diagnostics, most of which are used in
development and production. These levels may bring on various LEDs, but
the level of use for the service technician is that of the last fault.
Last Fault
To enter the last fault diagnostics, enter the diagnostic mode as described
above, then press the Auto Dry up button three times. The last fault will be
displayed on the drying progress LEDs.
The manual is here
Posted on Sep 08, 2009
SOURCE: Fisher & Paykel ED56 not working
Replace (repair) the exhaust sensor this looks like a transistor with the middle leg cut off. it is situated below the lint filter but can only accessed by removing the back panel, top panel (or rear screws to allow the removal of the drum). drum and then front panel to remove the connector from the mainboard. If you follow the exhaust tube once the back is off you will see a single phillips head screw that is the sensor. check the wires to the circuit board are not broken or dry joints or just replace it. sorry i had a spare machine i scavenged from to fix my problem so i dont know where to buy new.
Posted on Apr 09, 2010
SOURCE: my fisher and paykel dryer ( mod# ED56 ) wont start, power is on
I had this same problem with my Dryer. It is making the few quick beeps because it thinks the door is still open. Near the bottom of the opening to the dryer there is a sensor switch that gets pushed in when you shut the door. Try holding the switch in with a knife or something and then start the dryer with the door open to check if that is the problem.
After i did this, i closed the door and my dryer started as normal.
Posted on Jul 16, 2010
Fisher and Paykel ED56 dryer won't run.
Glad to got it taken care of. Next time be a little more careful, I usually recommend using a leaf blower.
May 10, 2015 | Fisher and Paykel Dryers
F&P ED56 has 2 problems
Yes, (2) certainly sounds like the start/run capacitor has failed. You will see it has a split or bulging case, or a displaced end cap. Replace it with one of the same voltage rating and capacitance.
I can't advise you on (1)
Jun 20, 2013 | Fisher and Paykel Dryers
Mar 06, 2010 | Fisher and Paykel Dryers
Fisher ED56 dryer wont turn off!
HI, this will occur if the timer control module or control board has failed. replacing the timer or control will fix this issue.
thank you,
vijay (vote for me)
Sep 24, 2009 | Fisher and Paykel Dryers
Diagnostic Mode
button.
Last Fault
The manual is here
Sep 08, 2009 | Dryers
My fisher and paykel dryer ( mod# ED56 ) wont start, power is on
Aug 11, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Dryer tries to start - then stops and beeps PLEASE HELP
Check the exhaust hose. If the dryer isn't venting properly it will either stop or the heater will turn off and the clothes will remain wet. If the hose is not clogged check the wall vent tube.
Apr 29, 2009 | Fisher and Paykel Dryers
Fisher & Paykel ED56 Dryer alarm on. Nothing else works
Replaced electric control panel. Looks like power spike fried the works
Feb 27, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Dryers Logo
492 people viewed this question
Top Dryers Experts
