Question about Minka Aire Ceiling Fan
How can a flush mount fan be leveled if the ceiling is at an angle?
My ceiling is at an angle. There is no room for adjustment in your fan installation. Do you make a kit to level it? If not do I have to install the mounting bracket by dropping one side about 1/2" off the electrical bow?
    Genius:
  • Minka Master
  • 1,617 Answers
Flush mount fans are made for Flat ceilings. They are also a waste of money! You won't get any airflow,
Posted on Jul 21, 2013
3 Suggested Answers
mcgyver468
  • 710 Answers
SOURCE: I currently have 2 switches on the wall for a ceiling fan(this was pre-installed when I bought my new home, but my Minka
The red and white should be hot all the time for the fan to run even when the light is not in use. The black and white wires are used for the switch on the wall to turn the light on. Hope this helps.
Posted on Apr 25, 2009
  • 13 Answers
SOURCE: 2 remotes
Yes, If the receiver is the same model number one remote will work for both... (im assuming when you state remote you are referring to a hand held remote? or are you referring to a wall mount remote? Each ceiling fan comes with it's own electrical unit... I currently have some Minka concept fans if your interested in purchasing at a very good price or if I can help you out in any other way please feel free to contact me at payitforwardx2 @ GMAIL . COM I will be happy to help you in any way I can.
Posted on Apr 23, 2010
I wish to install a ceiling fan in my bedroom. The roughing is already installed in my ceiling. The problem is the electrical box is recessed a half inch into the ceiling. Could I mount the ceiling fan if...
a celing fan should only be mounted on a box rated for a ceiling fan. This is a NEC code requirement. You could remove your existing box, and install a new box rated for a ceiling fan. You install the adjustable cross bar, and then attach the box to it. It also has stronger threaded inserts for the fan attaching bolts. Better than having a fan flying through the room.
Jul 25, 2010 | Lamson Electrical Box Extender
Similar problem: Does Hampton Bay Vaulted Ceiling Mount exist?
Ok so here is the deal. No there does not seem to be a Hampton Bay specific mount. The mount that comes standard in most of the Hampton Bay fans can handle the angle of most standard (read: small) angles. I do not know if it will be the case with all Hunter products, but the adapter for the Hunter fan that I replaced, worked with my new Hampton Bay. So now, I have from the downrod up is from the original Hunter fan. Hope this helps.
Sep 16, 2009 | Hunter Vaulted Ceiling Mount - Bright...
Have a habor breeze ceiling fan need a bracket kit for a ceiling that is more than a 45 degree angle
This is going to be a very difficult bracket to find. However, there is another option available, if you don't mind having a small mounting box at the ceiling electrical box.
Arlington Industries makes a nice ceiling fan universal mounting box that can be used in place of having an extreme angle on the downrod. The other benefit of this method is that the fan isn't prone to wobbling and is more secure.
This might require you to cut the drywall away from the joist to install it correctly, but it will work for almost any ceiling angle around.
http://www.aifittings.com/n_4.htm
They also have some other types, so you can check them out.
Hope you find this Very Helpful and best regards!
Aug 28, 2009 | Kitchen Appliances - Others
I want to hang the fan on a cathedral ceiling with a steep slope. Two questions, is the angle of the slope measured from vertical or horizontal,and does anyone make a kit for my fan to hang because the the...
The slope is measured off the horizontal plane. A 45 degree slope would rise 12 inches for every 12 inches of horizontal travel in this example. If the slope is too great try checking kits made by Fanimation. The Fanimation SCK52 - 52 Degree Ceiling Slope Ceiling Fan Kit will go up to a 52 degree angle ceiling and will fit most downrods. The hampton bay fans are very popular and should work just fine with this kit.
-Mark
May 14, 2009 | Hampton Bay 52 In. White Huntington III...
Hampton bay #762425 portland 2 ceiling fan
I suppose you can mount it as close to the ceiling as you want as long as the blades do not hit the ceiling. It being that close will not allow the air to flow as well if it was 6 to 12 inches lower.
Mar 15, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Mounting a Hampton Fan Model 52-CL
hello d,
1. yes, with the proper rod, longer wires(3,4) and the blades must be over 2.5 metres (8 foot) above the floor.2. you need the proper type box; the mount/s and ball; the longer wires (3,4)with slender but connertors; and especially the safety pins, etc. with the proper rod, the fan will hang straight. and about 3 chock hours to do this here task. hope this helps.
Jan 16, 2009 | Hampton Bay 52 In. 5-Blade Fan, Aged...
How to convert ceiling fan into wireless ceiling fan
Can a wireless remote control kit be added to a flush mount ceiling fan? Is there enough room for the receiver?
Jul 21, 2008 | Dryers
2 remotes
Jun 24, 2008 | Minka Concept II Flush 44 Ceiling Fan by...
Minka aire concept II flushmount
try buying a wall mount remote. it must be made to be able to be programed
Jun 13, 2008 | Minka Concept II Flush 44 Ceiling Fan by...
Minka Aire Ceiling Fan Logo
90 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
