Question about Hardware & Accessories
CLOCK MOTOR for T 1000 4RT3 - Hardware & Accessories
I have a MODEL T1471BR TIMER THAT THE CLOCK QUIT WORKING WHAT IS THE PART # FOR A REPLACEMENT CLOCK
Look on clock motor for part number:
Ignore suffix for example WG430-10 ... ignore -10
http://waterheatertimer.org/How-to-replace-Intermatic-clock-motor.html
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#clock-motor
156T3085A Skipper screw
156T1948A trippers
WG1380 120Volt clock motor 60Hz
WG1383 208-240Volt clock motor 60Hz
WG430 120Volt clock motor 60Hz
Apr 09, 2013 | Intermatic T1471BR Timer 4PST 40A 125V...
Clock dial doesn't move
You posted under Intermatic outdoor sprinkler timer.
Intermatic clock motors can be replaced.
Clock motor has identifying numbers printed on motor.
Tip mechanism out of box using thumb spring located inside box at top.
Google search for that motor number, for example WG1573 is 240V clock motor for T104 timers.
Aplus sells Intermatic clock motors:
http://www.aplussupply.com/intermatic/timermotors.htm
Electric supply sells clock motors
http://www.electricsupplyonline.com/prod/intermatic-motors.php
Intermatic online store is expensive option:
http://www.intermaticstore.com/
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 10, 2011 | Intermatic T8845PV - Sprinkler-Irrigation...
I have intermatic timer T30003R. How do I change the timer motor
My understanding is this timer uses typical T100 series 120Volt clock motor.
The motor has identifying numbers printed on it.
T100 series 120V clock motor is available at Grainger:
http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK1?Pid=search
Selection of Intermatic clock motors are available on-line:
To replace motor:
Timer mechanism snaps out of box using a thumb-spring located at top of mechanism.
Clock is located on back of mechanism, and is held by 2 star-screws.
You can buy star screwdriver bit at auto parts store or hardware.
Clock motor has two white wires that are connected to terminals on front of timer.
Be sure to tighten terminals screws very tight after replacing clock motor.
Jan 10, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
Timer not working. the rotating timer stops at the setting
Sounds like the clock motor has gotten weak.
You can replace Intermatic clock motors.
Snap out insides of timer and clock motor is located on back.
Motor has numbers printed on it that identify specific clock motor.
Motor is removable with small star screwdriver bit.
Clock motor has white wires that attach to terminals on front of mechanism.
Re-attach new clock to same terminals and tighten screws very tight.
If you have T101 or T103 timer, Grainger sells 125V clock for $16
If you have T104 timer, Grainger sells 208-277V clock for $16
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
You can google search your specific clock motor number:
Clock motors also appear on links below:
Dec 24, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
I have Intermatic timer WG 1573 208/277V 60Hz 3W stamped on the case. I would like to chage this unit to a 110V timer system if possible. (In other words just be able to switch clock motors) If this is...
WG1573 is a 240 Volt clock motor for T100 series timers.
This means you have T-104 timer.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Image shown on link above is T104R outdoor timer.
T104 indoor timer is the same except door does not have rubber gasket.
Terminals are labeled A 1 2 3 4
If this is not your timer, then add a comment.
Following instructions will convert T104 240V timer to T103 120V timer
Clock motor can be replace with identical 120V clock motor from Grainger
Timer mechanism snaps out and clock motor is located on back.
Remove clock motor with star screwdriver tip
Connect new clock motor wires to DIFFERENT terminals than before.
Old clock was connected to terminals 1 and 3
New 120V clock motor is connected to terminals A and 1
Wiring for 120V T103 is shown on link below.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
White neutral wire must connect to terminal A
Black hot wire must connect to terminal 1
Dec 19, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
My Intermatic timer is not working. I replaced the WG1573-10D motor but still it does not work. The manual override works so the power supply is ok. Any suggestions welcome.
Your question doesn't provide enough information.
You have 240Volt T104 Intermatic timer?
A) WG1573 is for 240 volt timer. If you have T101 or T103 timer, it takes 125V clock motor.
B) This is new installation? and clock motor only worked when override was ON, so you bought new clock motor. But actual problem is that wires from Load and Breaker are reversed.
C) Your timer worked fine in past years, but dial stopped rotating so you bought new clock motor?
You replaced clock motor.
Manual override works.
--And then your information ends.
Does clock motor work? Does the dial turn? Are your on-off trippers on the dial?
Are tripper worn down?
Buy new trippers.
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
If clock motor does not work, and circuit is 240Volts, then I suspect you connected clock motor to wrong terminals>? Clock motor connects to terminals 1 and 3.
Add a comment and fill in details so we can properly troubleshoot.
Dec 04, 2010 | RTO Intermatic Inc Wg1573-10d Replacement...
The dial on the intermatic water heater timer is not rotating on it's own and is easy to turn in either direction-without pulling it out and setting the time. The unit is only 1 year old..Can I replace the...
You can replace clock motor on many Intermatic timers:
Snap mechanism loose using metal spring top inside box.
Tip mechanism out and get clock motor number off motor.
Google search specific clock motor number.
Aplus sells many clock motor:
Electric supply online sells clock motors
Grainger carries inexpensive clock motors for T101, T103, T104 timers.
T101 and T103 use 125v motor
T104 uses 240v motor
http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK2?Pid=search
Dec 01, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Where do I get a replacement motor for the 7008-00?
Intermatic clock motors are everywhere, but Paragon and Tork clock motors are a mystery.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#7000
Shows manuals and resources
According to Paragon accessory chart:
http://www.paragontimecontrols.com/parts_accessories.htm
7000 series 240V clock motor M3193-71
7000 series 120V clock motor M3099-00
7008-00 is listed as 120V clock motor
http://waterheatertimer.org/pdf/Paragon-7000-series-manual.pdf
I cannot find M3099 120V clock motor on internet
Now Paragon has contact-us page for customer service:
http://www.paragontimecontrols.com/contact/default.aspx
I will also contact Paragon, and post results here if Paragon responds.
Nov 17, 2010 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
Time wheel stopped moving.
You posted under the Intermatic T-101
Troubleshoot:
Check if manual override turns Load on and off
If manual override snaps clean and crisp, and Load operates correctly, then you can replace the clock motor.
If manual override does not work very well, then you can buy another T-101 and swap out insides without changing box.
If manual override snaps clean and crisp, but Load does not come on, then check your electricity at breaker and check if wires are tight inside the timer.
Clock Motor
T-101: replace with T100series 120Volt clock motor
T-103: replace with T100series 120Volt clock motor
T-104: T100 series 240V clock motor
Where to buy clock motor:
How to replace clock motor:
Turn off power.
Take a photo of your wiring so you have a record of how wiring looks.
There are two small white wires that go to clock motor.
Inside box, there is a release lever located top of box.
Push release lever up and timer mechanism tips out.
Lift mechanism up slightly, and then tip all the way out.
Clock motor is held by tiny screws or tiny star-screws
Swap motors.
Attach clock motor wires on front terminals in exact location they were connected before.
Turn screw terminals very tight against copper wire.
Nov 04, 2010 | Intermatic T101 - 24 Hr. Dial Time Switch...
Replacing timer motor
T-104 has 240Volt clock motor
WH-40 water heater timer has same 240Volt clock motor
T-103 has 120Volt clock motor
T-101 has 120Volt clock motor
T-100 series 120Volt and 240Volt clock motors sell at Grainger for $16
See large image of clock motor on back of Intermatic timer
http://waterheatertimer.org/images/Back-of-T-104-800.jpg
To replace clock motor you need 6-sided star-screwdriver from auto parts store or hardware
You may also need tweezers or magnetic screwdriver if tiny screws fall down behind timer when replacing
Steps:
Order 120 or 240 volt clock motor
Turn off power to timer
Remove plastic cover over screw terminals
Take photo of wiring or make a drawing
Note exactly which terminals the clock wires connect to
Clock motor wires can connect to either terminal, there is not a plus or minus wire to clock
Loosen screws on front of timer to remove white-colored clock motor wires
Push the spring retainer located inside box at top ... this will release timer mechanism from box
Tip timer out and then lift up to release timer
Replace clock motor that is held by 2 screws
Keep clock wires away from other timer parts on back of timer
Snap timer back into box
Re-attach wires to terminals just like they were before
Tighten screws very tight against copper wires
Turn on power
Check that dial is rotating as time passes
See more
Oct 17, 2010 | Intermatic T-104R3 220v timer in a rain...
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
