Question about Garden
431 massey ferguson 431 serial by19119 hard to start
You have to flood it with fuel to start
  • 86 Answers
SOURCE: Operator's manual for a Massey Ferguson 65 tractor
Go to google search engine and type in your tractor most of the time it will give you lots of web sites to look at.
Posted on May 12, 2009
  • 4 Answers
SOURCE: I have massey ferguson 383 tractor that sat for 3
I would check to make sure that you are not getting air into the fuel system. With a tractor sitting that long I would also be concerned with 1. bad fuel, 2. bad fuel injector pump, 3. clogged fuel filter, 4. water in fuel system, 6. intake/exhuast valves siezed. You will just have to start with a process of elimination.
Posted on Aug 19, 2010
  • 5 Answers
SOURCE: I have a 1959 Massey
http://www.masseyfergusontractorparts.com/
Try this web site
Posted on May 18, 2011
SOURCE: Tractor engine starts but shuts off when put into gear
John deer sx75 starts run but shuts down as soon as pto or it's put into gear
Posted on May 03, 2012
  • 6468 Answers
SOURCE: My MF 1428v tractor engine stalls when I put it in gear
you are going in the right direction the first switch to look at is the one on the clutch/brake pedal try and jump it with a paper clip to test it
Posted on Jun 21, 2012
1997 sl2 satun started with rough idol now won't start . cranks over and floods. has new fuel filter & air filter
Check the fuel pressure regulator. Pull the vacuum hose off it, If it smells of gas, Replace the regulator. Diaphragm broke and is flooding the engine threw that vacuum line. You'll also need to replace the spark plugs. Gas will foul them out also.
Dec 31, 2016 | Cars & Trucks
How do you wire Massey Ferguson 230 diesal ? With 3 wire delco alternator. Along with oil pressure switch , ammeter, neutral safty switch, fuel,water. 12 volts.
    mages for wire diagram Massey Ferguson 230 diesel
    More images for wire diagram Massey Ferguson 230 diesel
    230 MF - wiring diagram - SSB Tractor
    www.ssbtractor.com/wwwboard/view_all.cgi?bd=massey&msg=10416
    Allen Stewart, I need the wiring diagram of the dash area. Does anybody have this? Allen Stewart, wiring diagram is needed for Massey Ferguson 230 diesel.
    [PDF]MASSEY-FERGUSON - MyeDocs.com
Jan 01, 2016 | Toys
Lookup serial numbers
Hi, here's a link to these specs. It looks like however that you did also find this info. Perhaps you'd comment if this was helpful. Thanks and good luck!
Just in case:
TractorData.com Massey Ferguson 362 tractor information
http://www.tractordata.com/farm-tractors/000/7/8/784-massey-ferguson-362.html
Aug 30, 2014 | Garden
Trying to find out what year a Massey ferguson tractor is the serial # is 9 A 108154
1971 and appears to be one of these models. Massey Ferguson Model MF-135, MF-150, MF-165, MF-175 and MF-180
Mar 06, 2014 | John Deere Tractor 1020, 1520, 1530,...
Where would i find the chassis number on a massey ferguson 3115
Climb up into the tractor's seat. Look below the lower left-hand side and lower right-hand side of the steering wheel panel for the serial number. Certain older Ferguson tractors have the serial number stamped to a plate that is mounted to one of these areas of the steering wheel panel.
Serial Number Plate:
http://old20tractorparts.com/mf-165-tinwork-parts/1356-massey-ferguson-165-serial-number-plate.html
Inspect the left- and right-hand sides of the tractor's main frame. Certain older Ferguson tractors have the serial number stamped to a plate on the outside of one of these areas of the main frame.
Inspect the top of the transmission housing for the serial number. Certain older Ferguson tractors have the serial number stamped to a plate that is mounted to the top of the transmission housing.
Jan 27, 2014 | Aprilia Pegaso 650 i.e Motorcycles
Engine flooding
Check the fuel pressure. The pressure regulator may have gone bad and is delivering too much pressure to the fuel rail, thereby flooding the engine.
Dec 07, 2013 | Cars & Trucks
Fluids out when you try to start
double posted, and fluids? you mean FLOODS.
see previous post,
there are other ways to flood any motor.
one other is (iSC /IAC devices are stuck closed) gummed up.
this cause no starting air, no air means flooding.
I cant see your car, and see if starting with 10% throttle solves the flood, but you can.
also WOT cranking, cuts all fueling and can not flood and will start any flooded engine.
but if this still floods,now, that is bad injectors. leaking.
WOT cuts injection pulses dead, and no fuel flows, cranking.
knowing these facts on EFI makes finding causes easy.
Sep 20, 2013 | 1995 Honda Passport
Hard to start Chevy 2000 Silverado 1500 .2nd or 3rd time it starts up Runs great but hard to start
hard starts.
1: needs a tune up. spark plugs then filters
2: are you running winter fuel, how cold is it? where are you?
Alaska or Miami.? (important that)
3: fast cranking speeds, is it, normal, only you know that.
4: ECT not reading wrong.
5: bad fuel, water in fuel.
6: ISC stuck closed, (they can gum up and prevent proper fresh air for staring, and will cause cold start flooding.
I always make sure my ISC is opening for startup.
the check my plugs to see if cold starts are due to flooding
or fuel starvation. test fuel proves this too.
and with fuel injection, one injector can leak , and overnight
the next morn, one cyl is flooded.
this takes careful testing to find.
8 cyclinders, check them all for flooding is the path for that.
Aug 22, 2013 | Garden
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
