Question about Danby DPC6012BLS
My refrigerator will not cool/brand new - Danby DPC6012BLS
Won't work on any power source
If the RV is level and the rear coils of the cooling unit are warm, then you will require a replacement cooling unit. Changing the cooling unit is something that can be done by the end user such as yourself. Check out Arcticold Cooling Units.here ArctiCold Refrigeration We keep it cold or give them a call toll free 1-888-782-6665
By replacing the cooling unit with an aftermarket one, it will save you you money (vs buying a new fridge) and increase the performance and durability of your fridge. Arcticold cooling units can be purchased on ebay Dometic RM2611 Brand New Manufactured Cooling Units LIFETIME WARRANTY... The RM 2611 cooling unit is the same as the RM2620 28c4e1ea-6951-42e3-827e-9b9809f394fb.jpg
Mar 09, 2014 | Dometic RM2620 Refrigerator
Refer will not cool
The blue wire you are referring to, does not plug into anything. It should have a shrink wrapped rubber on the end of it. As for your fridge not cooling I will need for info.
If your fridge is level and on electric the rear coils of the cooling should be warm. If they are warm and the fridge is still not cooling then you will more then likely need a new cooling unit. Check out ArctiCold Refrigeration We keep it cold and Dometic RM2652 Brand New Manufactured Cooling Units LIFETIME WARRANTY b838627c-cded-4581-a279-7ad685492c50.jpg 71841806-db73-4fb1-ab23-6e77deb169b9.jpg
Jan 22, 2014 | Dometic RM2652 Refrigerator
I have a Dometic rm3801 it was working fine on 120v and abruptly quit cooling all lights come on compressor and cooling fan don't run. I aam unable to try it on lpg. Fridge is level and cooling fins are...
If the rear cooling coils are warm and the refrigerator is level and there is still no cooling, then you more then likely will need to replace your cooling unit. It takes a couple of hours to do but you dont need any specialized tools. Check out ArctiCold Refrigeration We keep it cold Your unit can be found on ebay at under half the price of a new fridge. Link Below 11d6ec30-092e-426d-853a-24315c5d73c1.jpg Dometic RM3801 Brand New Manufactured Cooling Units LIFETIME WARRANTY...
Sep 25, 2013 | Dometic Refrigerators
It was working fine it was unplugged to be moved now it wont work on electric or gas its a rm 760 gas or electric domestic
When operating on Electric, if the rear of the cooling coils get warm and the fridge is level, but the refrigerator does not get cold then it is more then likely your cooling unit that has failed. Visit ArctiCold Refrigeration We keep it cold for info on replacement cooling units.... I have also attached a video with tips on diagnosing the RV fridge,
Arcticold New replacement cooling units can be purchased from Ebay Dometic RM760 Brand New Manufactured Cooling Units LIFETIME WARRANTY
Sep 16, 2013 | Dometic Refrigerators
Dometic rm4223 model does not run on 12v when traveling
You could contact me and I'll buy your old broken fridge, or you could buy my brand new rm4223 that is missing parts (but the cooling unit and cabinet are brand new, never used.
Sep 08, 2013 | Dometic WA3210 Compact Refrigerator
My frigidaire refrigerator does not seem to cool no freeze
If you have a sxs refrigerator then you have an issue with the damper door/switch not letting cool air from the freezer section to the refrigerator section. If you have a top mount freezer refrigerator unit, then you have a problem with the top venting system from the cabinet's ceiling.
Jul 27, 2012 | Refrigerators
My fridge isnt cold freezer is our friend gave it to us she has no idea its our grage fridge fridigdare elite not brand new
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 10, 2011 | Maytag MFD2560HES Bottom Freezer French...
Brand new Amana French Doors Refrigerator is too cold.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Dec 11, 2008 | Amana 25" Cu Ft French Doors Bottom...
Danby DPC6012BLS Logo
18 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
