Question about Dryers
Remove top panel of kenmore dryer 110.66002010
I am trying to replace the door switch, but do not know how to remove top panel of dryer.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,095 Answers
Most 110 series has a simple Hinge along the back and snaps on the front corners. Tap a large screwdriver in the one corner and lift.. it should pop. then do the other corner
Posted on Jul 21, 2013
3 Suggested Answers
canbruce75
  • 1776 Answers
SOURCE: how to remove top panel of kenmore dryer model
Check the video at the following link and see if you find the information helpful in changing the door switch. Sure hope it does and best wishes.
http://www.youtube.com/watch?v=fC8SY3cU1Yc&feature=PlayList&p=A8EAB62928245279&playnext=1&playnext_from=PL&index=61
Posted on Oct 01, 2009
  • 3074 Answers
SOURCE: Need to replace element, switch
remove the front panel and you will be able to access everything. Unplug the dryer,open door and remove all screws, with a flat tip screw driver pry gently on the top corners. Gently move the panel forward and disconnect door switch. sit panel aside and lift top up and back, it should rest on its clips. then heating coil is in the back right corner. Good Luck Tim
Posted on Sep 11, 2010
How do i replace door switch on kenmore 11085088401
the switch is on the front panel. the top needs to be removed and then the front
Apr 27, 2014 | Kenmore Elite HE4 Electric Dryer
Need to replace element, switch and thermostat on Kenmore Elite Oasis 110.67042600 dryer...but don't know how to remove the panels or which panels to remove.
Sep 11, 2010 | Dryers
I need to know how to get to the belt on the kenmore 600 dryer
i'am assuming it has a top filter,remove top filter,remove the 2 filter screws,pull the whole top toward you and lift up,disconnect the door switch,remove the 2 screws on the top inside front panel-your in-mike
Jan 31, 2010 | Kenmore 63942 Dryer
How to remove top panel of kenmore dryer model
Oct 01, 2009 | Dryers
My Kenmore Series 90 dryer won't run as it appears the door does not hit the actuator. It would appear either the door has moved to a lower position or the actuator has moved up into the dryer. May I ask...
The door switch or actuator is broken. A common problem. On most Kenmore dryers this is replace by lifting the top. Since you haven't given the whole model number I will discuss raising the top on the most common model.
If your model has a lint filter at the top the slide show below should show you how to raise the top.
Kenmore Dryer
Disconnect power to unit. Lift the cover from the lint filter or if yours is the one with a filter and cover together, remove the whole filter. You will see 2 screws under the cover/filter, remove them. Now, you will need a putty knife or a thin shafted straight screw driver to remove the top panel. Push the putty knife or screw driver to "pop" the front top clips. The top panel will hinge back towards the wall and can be left there. Just inside the top of the front panel, you will see 2 screws, remove them. You will see the wires for the door switch on the right side. *** the top of the front panel toward you to gain access to the switch for replacement.
Reverse process for reassembly. Good Luck
Sep 19, 2009 | Kenmore Dryers
Dryer
#1 Unplug the dryer
#2 Use a putty blade under the corners of the Console and flip it back
#3 Remove 3 screws along back of top that were under the console (Might just be 2)
#4 Slide the top forward and remove
You will now have full access to the switch. Disconnect the harness and replace the switch.
#5 Reverse the above proceedure to replace the top
Good Luck,
Eric
Jun 08, 2009 | Kenmore 64902 Electric Dryer
Access to replace door switch
Depending on the type of door the dryer has, is how you approach the access of these dryers. Mostly though you yank out the filter first.Remove the 2 screws in the filter housing on top.Then use a putty knife to pop the top. Remove the screws holding the front panel on. VERY IMPORTANT! Raise the front up an inch before pulling forward or the panel clips will break! Some models have a panel on bottom. If they do then this panel must come off first. Then you remove the door springs and back off the screws holding down the bottom of the door panel. Then pop the top and remove the screws on top to get the panel out so you can replace the door switch and actuator assembly:
Jan 04, 2009 | Dryers
I am trying to replace the belt but the drum is still attached to the back (I have taken every visible screw out). Should I try from the front? Is there a way of getting the drum unsecured from the back?
Dryers do not open from the back
the screws removed secure parts to the inside of the case
carefully replace them.
to opent the front of the dryer
unplg dryer
type I: maytag:kenmore stackable:speedqueen:
  • remove 2 screws from bottom of front panel, swing front panel out at bottom and unhook from dop
  • remove door switch wires from switch
  • remove front panel set aside
type II: Kenmore:whirlpool:ge:frigidaire
  • remove lint filter
  • remove 2 screws in lint filter holder
  • with putty knife or other blunt blade
    depress spring catches at corners of top cover
  • lift top cover at front
  • remove 1screw each side 1/3 way down
dryer internals are exposed and easily repairable
examine back panel to ensure that nothing is detached from screw removal
assemble in reverse order
Note:
while the dryer is disassembled, examine felts rollers and glides for wear, most common cause of belt breakage, if there is any wear, replace.
examine fan, fan housing and ducting for lint that got past the filter screen.
Oct 28, 2008 | Dryers
Kenmore Laundry Center #417.90802990
unplug it drop the panel between easher dryer remove the metal panel behind it remove 2 screws each side controls panel reomve control panel unplug the switch going to dryer door let panel hang down remove 2 screws bottom door panel one each side remove 4 screws on the top front panel with door will fall in your hands oyt seals on it let dry
Feb 28, 2008 | Dryers
Dryers Logo
234 people viewed this question
Top Dryers Experts
