Question about Intercure RESPeRATE Ultra Duo User
Faulty sensor belt
The Intercure Model RS-109 sensor belt on my Ultra resperate unit is defective. If I manipulate the belt it will work but it has a loose contact and needs to be replaced.
  • 21 Answers
Http://manuals.harborfreight.com/manuals/67000-67999/67212.pdf
Posted on Jul 27, 2013
The sensor belt on my resperate machine appears to be faulty. Constantly tells me that belt is loose.
I think you could
use this manual method instead.. My nephew used it to repair my car and it's perfectly fine now. Here's the website he bought it from. www.reliable-store.com
Mar 06, 2018 | Cars & Trucks
I Have error code E000007 - 001 on Canon C9060 pro
Fixing belt full displacement error (Displacement
direction is unknown.)
Full displacement of the fixing belt was detected, but the
displacement direction (front, rear) was unknown.
1. Forgot to clear the counter at the fixing belt
replacement -> clear the counter
2. Check physical relationship between the fixing belt
position sensor 1, 2 (PS71, 72) and the sensor flag
A. In case that both sensors are blocked from light
A-1. Faulty fixing belt unit -> replace the fixing belt
unit
A-2. Faulty fixing belt displacement control drive ->
replace the displacement control drive assembly
B. In case that both sensors are not blocked from light
B-1. The connector on the fixing belt position
sensor 1, 2 (PS71, 72) is physically removed,
or the cable is disconnected -> connect the
connector, or replace the harness
B-2. Faulty fixing belt position sensor 1, 2 ->
replace the sensor
B-3. Faulty fixing belt unit -> replace the fixing belt
unit
B-4. Faulty fixing feed driver PCB -> replace teh
B-5. Connection error of drawer connector (J8023)
-> clean or replace drawer connector
B-6. Short-circuit or open-circuit of harness
between fixing feed driver and DC controller
PCB -> replace harness
Jan 02, 2018 | Canon Office Equipment & Supplies
Error code in konica minolta c200 p 21
Relevant parts
Black PC drive main sensor (PS16)
Black PC drive sub sensor (PS18)
Main drive unit
Printer control board (PRCB)
Step Action
1 Perform the faulty sensor check procedure. *1
2 Check the sensor, for which a faulty condition has been checked, for installed position and
proper connector connection.
3 Wipe the sensor, for which a faulty condition has been checked, clean of dirt if any.
4 If P-12 persists, change the main drive unit.
5 Change PRCB.
Relevant parts
Transfer belt unit
PH unit
Step Action
1 Check the flat cable for proper connection and correct as necessary.
2 Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty.
3 Change the image transfer belt unit if the transfer belt is damaged.
4 Change the PH unit.
5 Change PRCB.
Aug 21, 2014 | Office Equipment & Supplies
Error cs548 in ricoh mp c4500
SC548
Fusing unit rotation error
The fusing belt sensor does not detect change in the actuator for 0.5
seconds after the fusing/paper exit motor has turned on.
* Defective fusing/paper exit motor
* Deformed actuator for the fusing belt sensor
* Defective fusing belt sensor
* Broken connection between IH inverter and IOB
* Incorrectly set fusing unit
1. Check if the fusing unit is correctly set.
2. Check or replace the actuator for fusing belt sensor.
3. Replace the fusing belt sensor.
4. Replace the IH inverter.
5. Check the connection between IH inverter and IOB.
Jul 14, 2014 | Gestetner DSm645 Digital Imaging System
P1332
Possible sources of fault code are as follows. The code is a fault in the VVT system (variable valve timing)
Faulty position
-camshaft belt has jumped out of place on the cogs
-defective reset valve
-mechanical fault in the Variable valve timing (VVT) unit
Faulty control
-defective camshaft position (CMP) sensor
Control too slow
-low oil pressure
-poor oil quality
Mar 27, 2014 | 2001 Volvo C70
Car dont start turns but dont run
Juan, this is straight from the book. Check these all out.
Make sure you have gas.
Make sure the battery is holding a charge.
You may have a leaking fuel injector, faulty fuel pump, or pressure regulator.
It may be a broken timing belt/chain.
Ignition components damaged or damp.
Worn, faulty spark plugs/coils
Broken, loosen, or disconnected wire in starting unit.
Broken loosen, or disconnected wire in ignition system.
Defective cam sensor, crank sensor, or PCM.
Mar 04, 2011 | 2004 Dodge Stratus
What is meant by error code SC 403 of RICHO AFICIO 2035E
SC 403 is a Transfer belt position sensor error
The transfer belt position sensor does
not activate even if the transfer belt
contact clutch has been switched on
twice and rotated once. Pls check if
Main motor/drive, Transfer belt contact clutch if defective, Transfer belt position sensor
if defective. or your Photo sonductor drum/PCU carriage unit does not turn or stock up or not inserted properly.
Jan 20, 2010 | Ricoh Aficio 2035 Copier
Codigo C7760 de una Kyocera kilometros 1635
C7410 C7800 C7810 C8010 C8030 Drum unit connector insertion problem • Absence of the drum unit is detected continuously for 1500 ms while there is no error on the copier. Broken external temperature thermistor wire • The input voltage is above 4.5 V. Short-circuited external temperature thermistor • The input voltage is below 0.5 V. Finisher* paper conveying motor problem • The paper conveying motor lockup signal is detected for 0.5 s or longer. Finisher* paper conveying belt problem • An on-to-off or off-to-on state change of the paper conveying belt home position sensor is not detected within 2 s of the paper conveying belt clutch turning on. Drum unit connector inserted incorrectly. Defective drum unit connector. Poor contact in the humidity sensor PCB connector terminals. Defective external temperature thermistor. Poor contact in the humidity sensor PCB connector terminals. Defective external temperature thermistor. Poor contact in the paper conveying motor connector terminals. The paper conveying motor malfunctions. Defective finisher main PCB. The paper conveying belt is out of phase. The paper conveying belt clutch malfunctions. The paper conveying belt home position sensor malfunctions. The paper conveying belt home position sensor connector makes poor contact. The internal tray is incorrectly inserted. Reinsert the drum unit connector if necessary. Replace the drum unit. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Replace the humidity sensor PCB. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Replace the humidity sensor PCB. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Replace the paper conveying motor and check for correct operation. Replace the finisher main PCB and check for correct operation. Adjust the paper conveying belt so that it is in phase and check for correct operation. Replace the paper conveying belt clutch and check for correct operation. Replace the paper conveying belt home position sensor and check for correct operation. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Check whether
Jan 19, 2010 | Office Equipment & Supplies
Have error code sc457 on copier, have received detailed instructions on how to fix it, but I need to know how to open it?
SC457 Position error for the image transfer belt’s cleaning unit
- Timing & Condition
• When the belt cleaning section touches the image transfer belt, but the belt cleaning sensor signal remains LOW.
• When the belt cleaning section releases from the image transfer belt, but the belt cleaning sensor remains HIGH.
• Dirty Sensor
• Defective sensor
• Defective belt cleaning shift clutch
• Defective drum peripheral component motor
• Defective I/O control board
• Defective main control board
1. Pull out and re-insert the image transfer belt unit.
2. Clean the image transfer belt cleaning H.P. sensor.
3. Replace the sensor. (Input Check: 5-803-012)
4. Replace the belt cleaning shift clutch.(Output Check: SP5-804-036)
5. Replace the drum peripheral component motor.
6. Replace the I/O control board.
7. Replace the main control board. [Signal Check]
• H.P.: CN219-B2 or TP108 on the I/O control board
The above information are taken from the service manual.
Good Luck!!!!!!!!!!!!!
Sep 20, 2009 | Office Equipment & Supplies
Ricoh color aficio 6513
The following is taken from the service manual I hope it helps Thanks J
the image
transfer belt’s
cleaning unit
section touches the
signal remains LOW.
remains HIGH.
• Dirty Sensor
• Defective sensor
shift clutch
• Defective drum
motor
board
board
belt unit.
H.P. sensor.
012)
motor.
[Signal Check]
control board
Jan 06, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
Intercure RESPeRATE Ultra Duo User Logo
242 people viewed this question
Top Intercure Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Intercure Health and Beauty Expert? Answer questions, earn points and help others
