Question about Garden
JobMate 1500 pressure washer wand
Do you know where you can get a new wand for a Job Mate 1500 power washer as mine as sprung a leak.
  • Joanne Gregory Jul 20, 2013
    or is there a way to fix it.
  • 41 Answers
Just replace O-rings or your local pressure washer co. in your city
Posted on Jul 23, 2013
5 Suggested Answers
  • 10 Answers
SOURCE: pressure washer stalls out when wand nozzle is released
common for not starting unless trigger engaged as you are turning the pump as well as engine creating pressure,as for stalling pump has unloader valve which is probably in need of grease(use good silicone grease)this allows water to ciculate when trigger released.
Posted on Apr 20, 2009
  • 104 Answers
SOURCE: Karcher K 3.68M Electric Pressure Washer. Wand trigger Locks Up.
Sounds like the pressure valve is broken thats why you cant depress the trigger , the valve is on the pump , i would suggest taking it to a repair shop as they are fiddly things to fix
Posted on Jun 05, 2009
  • 18 Answers
SOURCE: cleaning solution isn't siphoning to washer wand
you need to use i believe the black tip where there in least pressure it does not work with pressure
Posted on Jun 27, 2009
geterrollin
  • 277 Answers
SOURCE: Craftsman gas powered pressure washer
The unloader/bypass valve is jamming or defective. When you are not pressing the button the water is directed through the unloader valve/check valve to recirculate.It is common for them to corrode or for the spring to break.If it has an adjustment screw on the unloading valve for unloading pressure make sure you count the turns before disassembling it to make sure you dont over pressurize it.It is not opening causing the engine to choke out.Please let me know if this helps
Posted on Jan 19, 2011
Where can I get parts for jobmate 1500 pressure washer ?
This is from a Google search:
https://www.google.com/#q=jobmate+1500+pressure+washer+replacement+parts
Ebay is pretty good and you may get a gun extension that would fit and be more affordable.
Jul 03, 2016 | Garden
Water leaking from pressure washer wand
Yes possible orange damage, could be the threads are comprised too.. also alot of times they are not tightened enough, I usually grab 2 sets of pliers and tighten mine that way... U can also use some Teflon tape on the threads ala plumbing ..
Nov 19, 2015 | Garden
Pressure wand is leaking at the out let end, and pump has a small surge when setting at a idle
Sounds like water is leaking past the shutoff valve on the wand. Check your owners manual parts diagram to see if there is a washer or o-ring to replace.
Apr 16, 2015 | Greenworks 1700 PSI 1.4 GPM Electric...
How to fix 12POE-150 power washer leaking gun wand
There are no parts available for the inside of the guns. All you can do is replace the gun.
see parts in link.
http://www.ppe-pressure-washer-parts.com/12POE-150-power-washer-parts
May 01, 2014 | FAIP 1500 PSI Electric Power Washer
I have a pro 1600pwa no22049022491 and it leaks from the gun i took gun apart to find that the small tube comes up the handle inside bends then gos on the end of the trigger in the bend ther is a small...
No parts for the gun. I'm not sure what model you have for sure, I don't recognize 1600 PWA, see link.
http://www.ppe-pressure-washer-parts.com/job-mate-1600-power-washer-parts
Apr 19, 2014 | Garden
Weak Pressure. I have the power washer running for a few minutes, then I go to pull the trigger on the wand and I only get about 1-2 seconds of full force pressure. The machine is still running (not as...
Check for a clog.
take the hose off the washer pump and start it. if you have good water pressure then you may have something on the hose or the wand. I had a lizard in mine that caused that problem before.
Sep 11, 2013 | Karcher Garden
My karcher pressure washer 520 M is leaking water from the hand gun
You should watch the video on this blog. This is a very common problem, because the original gun/wand on many pressure washers is the same! However, Prism Teachings observed something that you should know about its design: http://electricreplacementgun.blogspot.com/
May 22, 2012 | Karcher K2.26 Electric Power Washer
My Snap-On 2000 PSI pressure washer is leaking through the trigger handle. I have no pressure coming out of the wand but the motor runs.
The fitting for the trigger is cracked. It happened to mine because I did not make sure the wand and hose was drained before winter came. The water left in the wand expanded and cracked the trigger housing. The problem is that the trigger piece is easily replaceable, but it is not available. Alltrade makes you buy the complete wand.
May 12, 2011 | Garden
Jobmate 3 gallon air compressor parts list/diagram
Good luck on this one. I own 2 jobmate compressors, one I bought and used very little before it blew apart and another a freind gave me to use for parts. Guess what the same part failed on both and I know of at ;east three more that also failed the same way.
I gave up trying to deal with Canadian Tire and Jobemate and junked them, as though they weren't junk to begin witn. You get what you pay for. I have a new Hausefield compressor and it is fantastic.
Feb 23, 2010 | Air Tools & Compressors
Karcher K 3.97M electric presuure washer cycles on/off.
Hi;
It has an internal water leak or a seal or valve is leaking air. These machines are warrantied for 2 years and that is about all you can expect from them. Having it repaired professionally would cost about 75% the price of a new machine. If you are handy enough to get into it yourself, e-mail me and I will send you a diagram. (firehead@rogers.com) Part prices are expensive in Canada but not bad in the US. I don't know about other countries.
Sep 09, 2009 | Karcher K2.26 Electric Power Washer
Garden Logo
262 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
