Question about Chevrolet Vehicle Parts & Accessories
Truck will start with key will not start with remote only turn over
    Top Expert:
  • Chevrolet Master
  • 42,159 Answers
Check the condition of the battery in the key. IF the battery is bad it will not activate the engine immobiliser and unless the immobiliser can read the key unit it will not allow the engine to fire up
Posted on Jul 21, 2013
What other test can I perform??
What kind of remote start module ? Seams to me if the vehicle starts with remote start disconnected then doesn't start with it connectected it's a problem with the remote start electronics . Is it aftermarket junk ?
Jun 10, 2017 | 1990 GMC K2500
My 2010 ram will not start with the key in the ignition.. only with the remote start???
Sounds like the Remote has Bypassed the Security System and once started, the Immobilizer is then become inoperative seeing that it got it's input from the Remote System itself.
Now when you attempt to start the truck with the KEY ONLY, it will not start. Look at the "Security" light when you are turning it over... Is it flashing or does it turn On or is it Completely Off?
Here is what I would do... Try your Other Key, if the SECOND KEY works, then your key has failed. If NEITHER KEY works, then your Immobilizer CODE is gone and for some reason as the REMOTE has bypassed the system it is allowing your to operate the truck.
When did the problem start to occur?
Apr 05, 2013 | 2010 Dodge Ram Pickup 1500
My truck wont start when i use the remote. the power in the tuck turn on but the truck never turns over. 2006 ford f-150
Sounds as if your immobilizer bypass is malfunctioning. To test, remote start vehicle. Check vehicle cluster (gages). If the immobilizer bypass is the issue, there will be car/lock symbol flashing rapidly. To confirm, put the key in the ignition(do not turn), remote start the vehicle. It should start. If the vehicle starts, remove key, remote start again without key. If the vehicle does not start, have the immobilizer serviced. If the vehicle does not remote start with the key in the ignition, the issue may be with the remote starter's starter output.
Jul 25, 2011 | Prestige Remote Start
Remote control has stopped working. Have tried changing the battery of the remote control but that did not work.
Does the red light on the remote light up when you push any of the button
if no, replace remote
if yes, then try repograming the remote to the car again.
-Have remotes' ready. if you have two then fob#1 and fob#2 (doesn't matter which one is #1 or #2)
-each step has to be done within 5 sec or it will not work, but don't do it super fast.
1.turn key just to the "on" position (not starting) and push "lock button " on fob#1 once and release
2.turn key off
3.turn key just to the "on" position (not starting)and push "lock button " on fob#1 once and release
4.turn key off
5.turn key just to the "on" position (not starting)and push "lock button " on fob#1 once and release
6turn key off
7.turn key just to the "on" position (not starting) and push "lock button " on fob#1 twice (if you only have one fob, then stop here and go to step 8)and push the "lock button" on fob#2 twice.
8.turn key off and remove key from ignition.
if you did it right, remotes' should work again.
good luck
Dec 17, 2010 | 2003 Honda Accord
Both key fobs for honda pilot 2006 no longer works. Do I need new keys or is it something internal such as a fuse?
First thing, does the red light on the remote light up when you push any of the button
if no, then replace battery inside remote
-Have both remote ready. fob#1 and fob#2 (doesn't matter which one is #1 or #2)
2.turn key off
4.turn key off
6turn key off
7.turn key just to the "on" position (not starting) and push "lock button " on fob#1 twice (if you only have one fob, then stop here and go to step 7)and push the "lock button" on fob#2 twice.
if you did it right, remotes should work again.
good luck
Dec 17, 2010 | Honda Pilot Cars & Trucks
Envoy is getting power on key turn, but it will not turn over. I know it is not the battery. I was installing a remote start and once I started it,with key, it ran rough so I took all remote start parts...
Most likely you either connected one of the wires in the steering column/ignition switch wrong or didn't connect one of them. The start circuit has contacts to make sure the transmission is in either Park or Neutral, and also has contacts on the ignition switch. Since you probably didn't disturb any wires on the starter or solenoid when you wired the remote start, the best place to look first is the places where you added the remote start.
Dec 31, 2009 | 2006 GMC Envoy
All of a sudden my alarm started going off and the only way to turn it off is to start up my truck. Well I tried but it won't start with the remote or the key. My truck battery is fine, I have an opti
There should be a Valet/emergency override switch, you must turn the key to the on position and switch the switch ... the LED should come on solid, try that, if no go .... Call the people who installed the system ... it is malfunctioning .... If you have RF key ... it may be being interfeared with buy the security override system that is required to remote start the car ...
Apr 29, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Vehicle Parts & Accessories Logo
52 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
