Vizio tv601i remote stop working
Replaced batteries and tried suggested troubleshooting. Remote works on our other Vizio Tv. What could cause the TV not to receive signal? There ia nothing blocking Tv.
    Champion:
  • 247 Answers
If the vizio tvs are of different model numbers but same type name they may not work with same remote as they say, product subject to change without prior notification.....solution.....get the exact remote for that particular vizio model
Posted on Jul 20, 2013
  • James Hasara Jul 20, 2013
    I am using the correct remote for the TV 601i. Just tried on the other TV to see if perhaps it would work there, Just trying everything to get an idea if its the remote or tv
  • bobby caesar Jul 20, 2013
    u will need a tech to open the tv replace the infra red diode receiver on the tv or check for obstruction inside the tv or open pins on the infra red receiver diode
VOTIT
  • 2071 Answers
SOURCE: VIZIO REMOTE CODES
JUST TRY THIS PROCEDURE;
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Sep 02, 2008
SOURCE: finding remote code to control my vizio tv
In my Vizio manual it says to try 1758 or 0178. I tried both and the 0178 worked for my rc-681m remote
Posted on Dec 22, 2007
SOURCE: VIZIO vx37l tv remote control code for cox tv remote
0178 will work but you have to keep the set-up button pressed down for more than a few seconds after you press TV on your cox remote. (You will see the tv button light up 2 or 3 times after pressing it and holding the set-up button down)
Posted on Feb 19, 2008
  • 4 Answers
SOURCE: code for Vizio tv
Unfortunately, those remotes only take a 3 digit code. I bought 2 new remotes, which do take 4 digit codes, but the code(s) for the Vizio do not work (or partially). I found that the 4 digit codes for the Goldstar and LG work better than those provided for the Vizio, but still not as good as the original Vizio remote.
Posted on Apr 01, 2009
SOURCE: vizio remote control not working
Wow, I feel stupid! Solution #2 did it! There are 2 Tv buttons, one on the top right and one on bottom right. You have to press the bottom one!! THANK YOU PPL!!!
Posted on May 25, 2009
REMOTE CONTROL IS INOPERABLE TO MY VIZIO 32 INCH FLAT SCREEN SERIES: E320B2
I assume you've replaced the batteries. Sometimes the remotes can go bad, especially if it's been dropped or had something spilled on it. I would suggest buying a cheap programmable remote control, and see if you can get it to work. If so, buy a new vizio remote off eBay. If you are unable to get any remote to work, it'll be the TV and will take far too long to troubleshoot over this chat. I hope that helps.
Jun 16, 2014 | Vizio L32 32 in. LCD HDTV
My tv [vizio vf550m] won't respond to a remote.
Vizio is famous for having main board issues. If you have replaced the IR board the only two other items it could be is a broken wire from the IR to main or the main board has an issue. Nothing else can stop the remote from working provided the remote is working properly.
Nov 02, 2012 | Vizio VF550M 55 in. LCD HDTV
I've gone through 3 remotes on my Vizio XVT553SV 55 in. LCD TV. The first one that came with the TV in the box quit working so I called and ordered a replacement. During the meantime, I went and bought a...
Ur universal remote have codes problems,low in batteries or replacement batteries have problems with codes.Re enter the codes again,for ur tv model.
Dec 09, 2010 | Vizio XVT553SV 55 in. LCD TV
The remote on my Vizio 47" LCD TV sort of stopped working. It still does volume and basic things, but power doesn't work and neither does changing the input...it's incredibly frustrating. I swapped in...
Try website 1-800-remotes Factory original.Buy an exact remote.Ur old remote is dead,main CPU chip is sorted.Can't repair this olny replaced with a new remote.
Mar 18, 2010 | Vizio SV470XVT 47 in. LCD TV
Remote stop working
You should verify if the remote has failed. Contact the support for Vizio, or ask your dealer where you can buy original replacement accessories.
Visio Tech Support:
http://www.vizio.com/support.aspx?id=1586
Most of the time, we've seen the remote fail. Sometimes we are able to service the remote. Sometimes, the IR LED and or the crystal fails in the remotes. If it is more than this, it is impossible to have internal service parts for most remotes. It takes service experience to be able to change these parts.
On rare occasions the IR remote sensor and remote processor area in the set can have a failure. It is best to try another remote to verify this before sending the set for service.
The most common causes of failure of a remote controller is dropping, rough handling, getting food and drink inside, or putting the batteries in backwards.
Jerry G.
Apr 25, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio remote control not working
Apr 04, 2009 | Vizio VO47L 47 in. LCD TV
Hi, I had the same problem. My vizio remote for my 42 inch 2 month old vizio also seemed to stop working. Here's what I did: My vizio remote (like most remote's nowadays) was designed for multiple components (tv, dvd, vcr, etc). All you need to do to make the remote work again is set it back to tv. Now, the confusing thing about vizio remotes is that they actually have TWO places where you can switch the remote to the appliance you want to control. One is on top of the remote, the other is on the BOTTOM. Switch it back to TV using the BOTTOM. My remote had stopped working because I had inadvently switched it to another component on the BOTTOM component switch.
Mar 14, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vx37l stopped working with FiOS remote
I read in another forum where Vizio sometimes uses Vidtech codes. I got 0205 to work on my new Vizio V037L with my Verizon FiOS remote (Phillips RC144).
Oct 02, 2008 | Vizio VX37L Television
Need vizio code for Samsung remote!!
I have a 37 inch vizio and had the same problem. After a little web research, I came across a suggestion that the LG codes might work. I tried it and found that the code 19 worked. You might try that. If 19 doesn't work for you, one of the other LG codes might (they are 06, 21, 22, 23 or 78).
Jul 25, 2008 | Zenith ZEN700 Remote Control
Televison & Video Logo
233 people viewed this question
Top Televison & Video Experts
