How do you change the string?
SOURCE: can't figure out how to put on new string after i took off the old string
I figured it out. Went on YouTube and watched a couple videos and did it myself. Thanks!
SOURCE: replaceing string spool
if its the newer weedeater brand
All you need to do is grab the bump knob end and pull it straight off no turning
wind your line in the direction the arrows on the spool shows you
to put back insert line or lines into the holes and snap back on
be sure the spool is able to move up and down freely after install
SOURCE: Don't know how to advance cutting wire.
Did you try bumping the head on the ground? Also, the head could be dirty, keeping the string from feeding. Or maybe the previous owner tried putting a larger size string in the head. Check to see what the proper size is for your trimmer.
Both of these suggestions could cause this.
Jim
SOURCE: I need to know how to load a two string trimmer
most of these use 2 wires coming out of 2 holes on opposite sides roll the firstwire clockwise, then the 2nd counterclockwise so that when the spool turns the string comes out its not hard
SOURCE: how to change string on weedeater trimmer electric
Check out the link that I am providing and see if the video helps you out. Sure hope so and best wishes.
http://www.youtube.com/watch?v=SuGfDNH6fXk
