Question about Pyle Plcd11mrkt Waterproof Marine Cd/Mp3 Receiver With Speakers
Disconnected wires pulled out of a waterproof speaker
    Champion:
    New Friend:
  • 227 Answers
Junk it
Posted on Dec 19, 2013
Broken speaker wire
Hello, Get some black electrical tape for ace, lowes or home depot and put around the exposed wires.
Apr 08, 2014 | X-1 x Interval 4G Waterproof Headphone...
Microphone wire jack replacement
While you could solder something up, why not just get an adapter to take the single 3.5mm 3 conductor to two 3.5 plugs, One Ear and the other mic. Should work if I understood the application correctly.
Feb 20, 2018 | Uniden Radio Communications
I have a JBL GTO 7001, it switches in an out of protection mode. i pulled out the amp, an noticed that the positive wire from the speaker was pulled out. so i disconnected the power scorce an reconnected...
Make sure that your positives and negatives are lined up correctly. This happened to me during my latest install and the problem was I had one positive speaker wire plugged into a negative speaker terminal. This switches the amp on after a few seconds and then back to protect mode once it detects a faulty speaker wire. Hope this helps!
Oct 07, 2010 | JBL GTO7001 Car Amp
Is there a product you can buy to waterproof speakers?
There is not really. Not waterproof. The best solution for that is to buy Marine grade audio equiptment. JBL Marine Audio is the best stuff out there.
Jul 19, 2009 | Car Audio & Video
No sound output - pioneer DEHP6700MP
Sounds like a grounded speaker, disconnect each speaker and see if the sound comes back on through the remaining speakers connected. Its sounds like it is just in protection mode from a chssis ground. I hope this helps!
May 30, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Is there a skin or something i can use to waterproof speakers
WATERPROOF SPEAKERS ARE MANUFACTURE WITH SPECIALLY COATED OR TREAT PARTS, U HAVE TO PURCHASE MARINE AUDIO COMPONENTS
Aug 28, 2008 | Car Audio & Video
I have a word titled "PROTECT" on my kdc mp333, how do I get it to function properly again? Pls reply asap.
When the stereo goes into PROTECT mode it is due to a speaker wire having a short circuit or is touching the car chassis somewhere.
Check all speaker wires from the unit to the speakers.
First check that each pair of speaker terminals at the speaker end is not touching. Or, a wire fell of 1 terminal to rest on another.
Best way to check if it's a blown speaker or a wiring short, is to disconnect all speaker connections ( at the speaker end ) making sure the disconnected wires don't touch each other or any metal in the car. press the reset on the unit and power up. If the unit powers up ok, then its a blown speaker.
Otherwise it's a short in the wiring.
If it's a blown speaker, you can connect 1 speaker at a time and the blown 1 will send the unit into protect mode again.
If it's the wiring, disconnect the unit from the wiring and use and ohm meter to check each pair of cables. A reading suggests a short.
If you don't have an ohm meter a battery and bulb will do. This method usually works on a short.
If you have no joy with either method, take each speaker wire in turn and check with a source of earth (anything metal connected directly to the body of the car, cigar lighter main body when pulled slightly out is good)
Regards
Philip
Jul 20, 2008 | Kenwood Car Audio & Video
When i turn on the cd player the sound from the components vuts off but the sound coming through the subwoofer stays on??
The Sub gets it's output from the pre-amp circuit, whereas the components get their output from the main amp circuit in the unit.
Sounds like it could be a short in the speaker wiring or a blown speaker. Check all wiring to the speakers.
Regards
Philip
Jul 20, 2008 | Car Audio & Video
98 jetta
pop the speaker grills out by using a small screwdriver, be easy don't want to ruin the grills, three or four screws should be holding each speaker, unscrew, pull out gently, for the side speakers, then disconnect speaker wires, for the rear speakers if you have woofers, the woofer pulls out from the trunk side, disconnect speaker wires before taking the woofers out.
when your ready to put new speakers in reverse the process.
Jun 17, 2008 | 1998 Volkswagen Jetta
Pyle Plcd11mrkt Waterproof Marine Cd/Mp3 Receiver With Speakers Logo
Top Pyle Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Pyle Boating Expert? Answer questions, earn points and help others
