Question about John Deere Garden
Gas in the oil pan, Why? - John Deere Garden
    Novelist:
  • 212 Answers
Stuck float on carburetor allowing gas to seep into crankcase. Or if their is a wire going to bottom of carb this is a solenoid plunger to stop gas flow, this could be bad too (if equipped). Have your carb cleaned then make sure to shut gas of at tank when not in use.
Posted on Jul 22, 2013
Gas in the oil pan?
IIT has a mechanical furl pump check it
Feb 15, 2015 | 1993 Ford Explorer Limited
Fuel pump stays on in 1994 gmc sonoma
for sum reason it is not building pressure could be rubber line inside of gas tank.It could be pumping gas into oil pan because of bad regulator be sure your oil pan is not full of gas
Oct 01, 2014 | 1994 GMC Sonoma
1989 corvete tpi gas getting in oil pan change the fuel reulatorstill getting fuel in oil pan is this a fireing problem
Check fuel pressure regulator vacuum hose if it's got gas in it the
fuel pressure regulator is bad and will need replaced. Will get into oil through vacuum hoses
Apr 08, 2014 | Cars & Trucks
Gas in oil pan
sounds like the float in the carburetor or needle valve is failing and gas fills up the bowl, rides down the cylinder and into the oil pan.
Do you notice gas pouring out into the air cleaner?
Aug 04, 2013 | Yamaha 2006 Kodiak 400 Auto 4x4
How do you replace or fix ticking lifters
I,m going to share something with you that i found out my van had ticking lifters and all i did was clean the oil pan filter
1. drain all the oil from oil pan
2. take oil pan off
3. once that is done you will see a long tube comming down by the crank.
4. remove the 1 or 2 bolts that hold the filter on
5. once removed you can give it a good rinse out with a gas/2stroke oil mix
6. once fully dry replace back to original location
7 put new oil pan gasket on
8 put oil pan back on
9 torque bolts down to 12.5 foot pounds
10 full with oil
11 start vehicle and let run
Let me know how it turns out
Sep 10, 2011 | 2002 Dodge Durango
1988 f-250 (460 7.5 liter gas) timing chain cover gsk,do you need to remove oil pan?
No, you can loosen a view of the oil pan bolts towards the front of the oil pan and drop it down a bit to get clearance to remove the timing cover.
May 02, 2010 | 1988 Ford F 250
I lose oil pressure when i push the gas down. when setting there it has pressure
I have seen this at my repair shop, what you need to do is remove oil pan clean or replace oil pick up tube screen, also replace oil pan gasket before reinstalling oil pan.
Jan 22, 2010 | 1999 Ford Explorer
Gas in the oil pan
no it you piston rings
Nov 17, 2008 | 1997 Pontiac Trans Sport
Garden Logo
24 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
